Dbase (DBF)
From GRASS-Wiki
Jump to: navigation, search
Some ML-Threads
Is there a simple way to join some attribute data in a comma separated text file to an existing GRASS vector map?
The data in the CSV file does not have any coordinates but a primary key field that also exists in the polygon map it needs to be joined to.
  1. Answer 1:
    • use rdbms as data backend (including for the map you want the data to be connected to)
    • db.in.ogr
    • create view combining map attribute table with new table from csv-file (using key)
    • v.db.connect -o map table=NewView
  2. Answer 2:
    • install SQLite (it does not need setup but works out of the box)
    • set the DBMI settings with db.connect (see manual page for copy-paste example)
    • use v.db.join
    • use g.copy or db.copy to easily transform from DBF (or whatever to SQLite).
  3. Answer 3:
    • identify names and types of columns in csv file
    • v.db.addcol the relevant columns
    • for each line in csv file: v.db.update
Is there a tool which can convert a dBase file into a ASCII or CSV file?
  1. Answer 1:
  2. Answer 2:
    • ogr2ogr -f CSV output world.shp world
  3. Answer 3:
    • db.out.ogr
  4. Answer 4:
  5. Answer 5:
  6. Answer 6:
  7. Answer 7:
    • dbview command line utility for converting to a flat ascii table
Is it safe to edit the DBF-table outside of GRASS in another program?
For instance in OpenOfficeCalc? Or even as a CSV with Python, IDL, etc.?
  1. Answer:
    • Yes. You can actually create whatever dbf you want, wherever you want as long as it contains a column with the id's of the objects. Then you can connnect your vector map to this dbf with v.db.connect.
I need to do some calculations on my attribute tables. What is the corresponding command in GRASS for this?
  1. Answer:
    • v.db.addcol
    • v.db.update
