R statistics
From GRASS-Wiki
(Redirected from GRASS and R)
Overview
High quality statistical analyses in GRASS GIS are possible thanks to an interface to one of the most powerful statistical analysis packages around: R (https://www.r-project.org). This R ←→ GRASS GIS interface is provided by the rgrass R package. The possibility to directly interact with R strongly increases the statistical and geospatial analysis capabilities of GRASS GIS. See CRAN Task View: Analysis of Spatial Data for an overview of the R packages and functions that can be used for reading, visualizing, and analyzing spatial data.
R can be used in combination with GRASS GIS in different ways:
  • Running R 'on top of' GRASS: which involves transferring GRASS data to R to run statistical functions on the imported data, and possibly write the results back to GRASS. GRASS raster and vector data can be imported in R using the read_VECT() and read_RAST() functions provided by rgrass. Similarly, results can be written back using the write_RAST() and write_VECT() functions. When we read GRASS maps into R, they become R objects stored in memory, more specifically terra objects, i.e., SpatRaster and SpatVector objects that can then be coerced to other types of R spatial objects.
  • Using R as a scripting language in GRASS: GRASS functions can be run from R using the execGRASS() function in the rgrass package. R scripting tools, such as powerful string-processing tools, can be used to 'glue' different functions and tools together.
  • Using GRASS GIS as a geospatial library in R: GRASS GIS can be used to extend the geospatial capabilities of R by: (1) offering an extensive and robust set of geospatial tools, and (2) providing a way to work with very large (larger-than-memory) spatial data sets. See Using 'GRASS GIS functionality within an R session' below for more information.
In practice, one will often combine different approaches, with scripts running GRASS functions, reading resulting maps into R for further analysis, modeling and visualization, and creating new layers in R that are imported back into GRASS.
Current State
R Windows binary packages distributed by the Comprehensive R Archive Network (CRAN) using OSGeo software (chiefly PROJ, GDAL and GEOS) use custom built binaries compatible with the build train used by R and are static linked; at present both 32-bit and 64-bit binaries are deployed. CRAN packages for macOS are also static linked to custom built binaries, again using the build train used by R. Static linkage is used to avoid having to deploy a package manager for external software on which R packages depend, since CRAN as a package manager already supports over 15000 packages with three binary versions (devel, release, old release) for Windows and macOS.
Installation
Installation of R core software
(see also R statistics/Installation)
Note: the ...-devel packages are needed if you want to install extra packages incl. rgrass on your computer.
Fedora:
 sudo dnf install R
 # further packages needed in order to locally compile "rgrass"
 sudo dnf install proj-devel proj-data gdal-devel sqlite-devel xml2 libxml2-devel udunits2-devel
Ubuntu:
 sudo apt-get install r-base
 sudo apt-get install proj-bin proj-data libproj-dev libgdal-dev libsqlite3-dev libxml2-dev r-base-dev
Installation of the rgrass package
To install the R package rgrass on newer versions of R, you simply start R and install the package directly with:
install.packages("rgrass", dependencies = TRUE)
This will install rgrass and all its dependencies. To use the package, you first need to load it:
library(rgrass)
If you are using Rstudio, you can install the rgrass package in the usual way (tool → packages). For further instructions and for troubleshooting, see R_statistics/Installation.
How to use
Using R within a GRASS GIS session
If you are primarily a GIS user who wants to run e.g., some statistical tests not available in GRASS, you probably want to run R from within a GRASS GIS session. To do so, first start GRASS GIS and then start R (or RStudio) from the GRASS GIS command line. For more information and examples, see R_statistics/rgrass.
Using GRASS GIS functionality within an R session
If you are primarily an R user who wants to take advantage of the geospatial functions in GRASS, you probably want to use GRASS GIS within an R session. To connect to a GRASS GIS database from within R (or Rstudio), see the instructions on R_statistics/rgrass. If you are a first time GRASS GIS user, you may want to check out the information for first time users.
Examples
Getting help
Manual pages
If you are in R and have loaded the rgrass package, you can get help by typing:
?rgrass
Similarly, to get help for a specific function, e.g., for the function read_RAST(), you type:
?read_RAST
You can also start the R help page in your browser:
help.start()
Now, to get the information about the package, select the Packages entry and then rgrass.
Support from the community
Primary support for R + GRASS and the rgrass package is through the grass-stats mailing list.
Useful links
R
Related
Articles & books
Older (but still useful) links
