MacOSX and X11
From GRASS-Wiki
Collecting FAQ, in case someone can answer them ...
Questions
- Hi, I've just tried to install Grass Gis 6.0.1 on my G4 IBook, but it doesn't work and I don't know where else to find help. I'm running MAc Os X and I have installed X11 as good as I could - but every time I start grass61cs - as described in the installation guide - I get the same error: "Couldn't launch application: X11". Any ideas ? thanks, --fxk 15:27, 5 July 2006 (CEST)
Michael wrote
If you can't find x11.app in the /Applications/Utilities folder, it is not installed. It is NOT installed by default as part of the Xcode package. You need to go back to the installation disks. It is on disk 2. I can't remember exactly where it is, but you do a custom installation and check a box to explicitly install x11.
I'm having a similar problem on my Macbook Pro, and I had already installed x11 to run GIMP. When I got the first error message, I thought that I might have to be currently running X11, so I opened it. I still got the 'missing apple x11' error. thanks, schyler523
