Ps.map multi pane example
(Redirected from Psmap multi pane example)
If you want to show a number of raster maps side by side in a paneled figure you will have to do it in a two step process. The first step is to create each panel as an EPS file, the second step is to include these EPS files in the ps.map command file. In this example the GRASS 6.3 d.out.file module is used to create the intermediary Encapsulated PostScript files using the GRASS PostScript driver. You can just as well use ps.map with the -e flag to create the EPS files.
This example uses the Spearfish, South Dakota sample dataset.
Create a shaded relief map
g.region rast=elevation.dem
r.shaded.relief map=elevation.dem shad=elev.shad_relf
Create the EPS components
export GRASS_WIDTH=640
export GRASS_HEIGHT=480
d.mon x0
d.erase
d.his h=elevation.dem i=elev.shad_relf brighten=50
echo "A" | d.text -b color=black size=10 at=93,5
d.out.file output=elevation format=eps size=950,720
d.erase
d.his h=slope i=elev.shad_relf brighten=40
echo "B" | d.text -b color=black size=10 at=93,5
d.out.file output=slope format=eps size=950,720
d.erase
d.his h=landcover.30m i=elev.shad_relf brighten=55
echo "C" | d.text -b color=black size=10 at=93,5
d.out.file output=landcover format=eps size=950,720
d.erase
d.his h=trn.sites i=elev.shad_relf brighten=15
echo "D" | d.text -b color=black size=10 at=93,5
d.out.file output=training format=eps size=950,720
Create the ps.map map
ps.map -r out=fourmaps.ps << EOF
paper a4
end
maploc 1.6 1
border
color white
end
eps 25% 75%
epsfile elevation.eps
scale 0.25
end
text 25% 53% Elevation
fontsize 16
end
eps 75% 75%
epsfile slope.eps
scale 0.25
end
text 75% 53% Slope
fontsize 16
end
eps 25% 25%
epsfile landcover.eps
scale 0.25
end
text 25% 3% Landcover
fontsize 16
end
eps 75% 25%
epsfile training.eps
scale 0.25
end
text 75% 3% Training Areas
fontsize 16
end
end
EOF
Convert PostScript to PDF (ps2pdf comes with the gs-common Debian package)
ps2pdf13 fourmaps.ps
