SVN hosting
From GRASS-Wiki
Jump to: navigation, search
Historical document, please keep it.
The goal is to move to SVN infrastructure for GRASS 7. The hosting of SVN needs to be discussed. A new repository has to be created in any case, despite its physical location.
October 2007: It has been decided to open the SVN at OSGeo
See also bug Tracking.
See also
MediaWiki is available at OSGeo, so this shouldn't be needed. (and I prefer MediaWiki ;-) --HB)
Note: there is now also the Mediawiki converter plugin installed at osgeo.org (but I tend to agree with HB) -- MN
What does that plugin do? TracWiki->Mediawiki?
yes -- MN
If so Mw->Tw->Mw would be lossy & better to copy Mw->Mw? (??) --HB
Sure, if we keep MW, we'll simply dump it and import -- MN
SVN repository with GForge at Intevation
GRASS GForge Server: http://wald.intevation.org/tracker/?group_id=21
Pro:
  • continuity for GRASS
  • GForge includes different SCMs, like CVS, SVN, Mercurial, ...
    • GForge-SVN-Browser (example)
    • As GForge-Wiki "phpwiki" is potentially available.
    • more?
Contra:
  • GForge is not really accepted by GRASS developers, low usage (much lower than with old RT). Important developers are not even registered at all
  • more GForge bugs
SVN repository with Trac at OSGeo
OSGeo SVN/Trac Server: http://trac.osgeo.org/ . There are several SVN/Trac instances running, e.g. the GDAL SVN/Trac Server.
Main servers are at Peer1 colocation site, adminstered by the OSGeo System Administration Committee (OSGeo-SAC).
Pro:
  • Integrated infrastructure with other OSGeo projects (GDAL, ...)
  • SVN and Trac nicely integrated, also Wiki integrated (Wiki example)
  • Trac shows patches/diffs in SVN (example1, example2)
  • login (signon) embedded in OSGeo LDAP: single signon for OSGeo infrastructure
  • Trac advantages
  • potential new translation portal of OSGeo would integrate, too (we suggest pootle)
  • integration with BuildBot (automated multi-platform test builds)
Contra:
  • some time already invested in Intevation's GForge
