Sqlite malformed database
From GRASS-Wiki
Jump to: navigation, search
Sometimes can happen to get this error using vector data
DBMI-SQLite driver error:
Error in sqlite3_step():
database disk image is malformed
To solve this you can only recreate the database in a new one.
You have to move in the directory of SQLite database inside your GRASSDATA/LOCATION/MAPSET/sqlite, access sqlite.db and run
sqlite> .mode insert
sqlite> .output dump_all.sql
sqlite> .dump
Now you have to rename sqlite.db to something else (e.g. sqlite.db.old). Create a new empty database called sqlite.db, access it and run
sqlite> .read dump_all.sql
