Talk:GRASS GIS Community Sprint Autumn 2017
From GRASS-Wiki
Photos of the event
Summary
To be added
Participants and Reports
Changes in trac: see here
Veronica Andreo
  • Add/enhance descriptions of tasks for Google Code-in (GCI) in shared spreadsheet
  • Discussions about GRASS GIS GCI tasks with Luca Delucchi
  • Create list of core modules and add-ons missing examples and screenshots (by means of: check_examples_screenshots.py)
  • Add new and improved modules to NewFeatures74 page and re-write it nicely
  • Upload of GRASS GIS flyer in Spanish with help of MN and svg support of Vincent Bain: svg, pdf
  • Test r.hants and r.series.lwr after r71682, see trac #2790
  • Closed ticket trac #3301
  • (re)Tweeting as https://twitter.com/GRASSGIS
  • Text and screenshot update of lib/init/helptext for trunk and release branch
  • Told MN about Add-ons manuals outdated and missing or wrong description in meta-pages (r.li, r.modis, r.green)
  • Discussions about the new website
  • Add missing height of figures in r.series.lwr and r.seasons add-ons manual pages
  • Discussions about GRASS GIS startup with MN, MM and ML: location wizard prevents new-users to actually see the software and creates confusion, a possible solution being start GRASS directly into NC location or into a global lat-long location
Markus Neteler
  • GRASS GIS 8 discussions: improvements in the raster library: tile support
  • Assist in production and upload of GRASS GIS flyer in Spanish with VA
  • manual: fix missing height HTML tags according to https://trac.osgeo.org/grass/wiki/Submitting/Docs#Images
  • Told Nikos about an ultra-fast and cool cmd line search tool (so much faster than "grep"): https://github.com/ggreer/the_silver_searcher
    • Search for a function in the source code: ag grass_to_osr
    • Search for a function in the source code restricted to C files only: ag --cc grass_to_osr
    • ag --list-file-types
  • various module manual fixes and ticket cleanup
  • Re(Tweeting) to https://twitter.com/GRASSGIS (a bit of marketing :-)
  • GRASS GIS 7.4.x release branch has been created in r71701
    • Remember that trunk is now called 7.5.svn, i.e. the trunk binary is called "grass75" and no longer "grass73".
    • many updates of grass72 --> grass74 in relbranch74
  • Web site:
    • cronjobs for G74 created and activated
    • a few Web pages updated for new upcoming release
  • Discussions about GRASS GIS startup with VA, MM and ML: location wizard prevents new-users to actually see the software and creates confusion
    • Solution: Startup into main menu with Lat-Long predefined, then show import wizard || switch projection || change location
    • Alternative: start GRASS in last location+mapset, then ask if GRASSDB/location/mapset should be changed.
Markus Metz
  • Some discussions about raster format and grass 8
  • made NULL file compression the default
  • fixing 7.4-tagged bugs:
    • fix vector support in GCP manager
    • r.out.gdal: export inf values
    • r.out.gdal: +option to add overviews
    • work on datum check at data import
  • more, see trac list
Moritz Lennert
  • Added tests to r.object.geometry and fixed a bug noticed through the test ;-)
  • Bug triaging
  • 7.4 release preparation:
  • Work on improving r.neighborhoodmatrix
  • Discussions on new web site
  • (unsuccessful) attempts at debugging g.gui.iclass
Nikos Alexandris
  • Minor assistance in adding new/improved modules at NewFeatures74
  • Implemented suggested tests for NULL file compression trac #2750 (see comment 66, see also https://github.com/NikosAlexandris/test_r_compress) | Thank you Moritz, Markus M
  • Basic structure for an r.estimap addon, implementation of an algorithm for producing (European) recreation potential and opportunity maps | For the moment, still in a private repository. Will open once... ready!
  • I suggest https://getgrav.org/, a flat-file CMS
