Using Eclipse 4.5 (Mars) on Windows 7
From GRASS-Wiki
Introduction
After completing these installation instructions, you will have an IDE for GRASS that will allow you to perform the following development tasks:
Workbench
  • Switch between C/C++, Python, Debug and SVN perspectives
Browsing
  • Navigate the GRASS source code trunk
  • Edit source code
  • Select a symbol and go to to its declaration
Building
  • Build the entire GRASS system
  • Build an individual GRASS module
Editing
  • Syntax highlighting
  • Code completion assistance
Running
  • Run GRASS modules and Python scripts
Debugging
  • Set breakpoints
  • Single step through source code
  • View variables and memory values
Versioning
  • Commit source code to the SVN repository
  • Update source code from the SVN repository
Install TortoiseSVN
Download and install from the TortoiseSVN website.
During installation, include the "entire command line tools" so that "svn up" can be run from a Windows Command Prompt or MSYS shell.
The following path should have been added to PATH:
C:\Program Files\TortoiseSVN\bin
From Command Prompt, enter the following command:
>where svn
To run "svn up" from a Command Prompt, enter the following commands:
>cd C:\OSGeo4W\src\grass7_trunk
>svn up
To run "svn up" from a MSYS shell, enter the following commands:
$ export PATH=$PATH:/c/"Program Files"/TortoiseSVN/bin
$ cd /c/OSGeo4W/src/grass7_trunk
$ svn up
Install OSGeo4W Runtime and Development Framework
Download and install the 32bit version from the OSGeo4W website.
It will be installed in this directory:
C:\OSGeo4W
Checkout GRASS Source Code and Make Debug Build
Checkout the GRASS development branch using the SVN command from the GRASS Download website.
Open a MSYS shell.
$ cd /c/OSGeo4W/src
$ which svn
$ svn checkout https://svn.osgeo.org/grass/grass/trunk grass7_trunk
Run a 'debug' build.
$ export CFLAGS='-g -Wall'
$ ./mswindows/osgeo4w/package.sh
This will take some time to complete.
Build activity is logged to this file:
C:\OSGeo4W\src\grass7_trunk\mswindows\osgeo4w\package.log
In addition to building and installing GRASS, which can be run using the created Windows desktop icon, the Eclipse workbench will be able to use these artifacts that are created during a GRASS build:
  • Top-level Makefile
  • Module-level Makefiles
  • Symbol tables added to runtime binaries
Makefiles allow the Eclipse workbench to re-build the entire GRASS system or to re-build individual GRASS modules after source code editing.
Symbol tables allow the Eclipse debugger (GDB) to set break-points in source code, single step through source code, and view the values of source code variables and structures.
Install Doxygen and Make Documentation
Install latest Doxygen binary distribution for Windows.
Download and install from the | Doxygen website.
Install latest Graphviz binary distribution for windows.
Download and install from the | Graphviz website.
Install latest basic TeX/LaTeX system for Windows.
Download and install from the | MikTeX website.
After the TeX/LaTeX system is installed, and during the first time "make pdfdocs" is run, expect to be prompted for additional packages that must be installed to complete the TeX/LaTex system.
Open a MSYS shell.
$ export PATH=$PATH:/c/"Program Files"/doxygen/bin
$ export PATH=$PATH:/c/graphviz-2.38/release/bin
$ export PATH=$PATH:/c/"Program Files (x86)"/"MiKTeX 2.9"/miktex/bin
$ echo $PATH
$ cd /c/OSGeo4W/src/grass7_trunk/
$ make htmldocs
$ make pdfdocs
Open the HTML formatted documentation using a web browser:
file:///C:/OSGeo4W/src/grass7_trunk/html/index.html
Install GRASS Database
In your Windows Home directory, create a directory named 'grassdata'.
Example:
C:\Users\Ruth\grassdata
Download one or more GRASS 7 datasets from the GRASS GIS sample data download website to the 'grassdata' directory and decompress.
This tutorial uses the 'complete NC location' dataset.
After the 'complete NC location' has been decompressed in the 'grassdata' directory, you should see this sub-directory:
nc_spm_08_grass7
Install Eclipse Mars
Download and install the 32bit version of Java SE Runtime Environment (JRE) from the Java Download website.
Download and install the 32bit version of Eclipse IDE for C/C++ Developers from the Eclipse Mars Download website.
This tutorial installed Eclipse in this directory:
C:\eclipse-4.5-mars-32bit
Install PyDev Plug-In
Start Eclipse.
Help -> Install New Software...
Select "Add..".
Enter "PyDev" in the "Name: field.
Enter "http://pydev.org/updates/" in the Location" field.
"OK"
Check the "PyDev" option.
"Next"
"Next"
Accept the license agreement.
"Finish"
Restart Eclipse.
Install SVN Plug-In
Start Eclipse.
Install SVN plug-in.
Set "Work with:" to "Mars - http://download.eclipse.org/releases/mars".
Expand "Collaboration".
Scroll down and put a check mark in the "Subversive SVN Team Provider option.
"Next"
"Next"
"Finish"
Restart Eclipse.
When "Subversive Connector Discovery" prompts you for a selection, check "SVN Kit 1.8.10".
"Finish"
"Next"
"Next"
"Finish"
"OK" to the "security Warning".
Restart Eclipse.
Make SVN visible.
Window → Perspective → Customize Perspective...
Select the "Action Set Availability" tab.
Check the "SVN" option under "Available action sets".
"OK"
Select the "Shortcuts" tab.
Check the "SVN" option under "Shortcut Categories".
Select the "Menu Visibility" tab.
Check the "SVN" option under "Menu Structure".
Select the "Tool Bar Visibility" tab.
Check the "SVN" option under "Tool Bar Structure".
"OK"
You should now see "SVN" on the main tool bar and the SVN tool bar available under the main toolbar.
Setup Eclipse GRASS Environment
We will start Eclipse from a Windows batch file. This will provide the opportunity to set environment variable required by both the GRASS runtime modules and the Eclipse workbench.
1. Exit Eclipse.
File -> Exit
2. Install eclipse.bat.
Using a text editor, create a Windows batch file named eclipse.bat in the top-level directory where Eclipse is installed.
The top-level Eclipse directory used in this tutorial is:
Copy the contents from eclipse.bat to the eclipse.bat file you created.
Modify the contents for your particular Windows and GRASS development environment.
Save and exit eclipse.bat.
Reference: Working with GRASS without starting it explicitly
3. Update Eclipse Icon Properties.
Update the Properties of the Eclipse startup icon that is on your Windows desktop.
Right-click on the desktop icon and change the Target field to something like this:
C:\Windows\System32\cmd.exe /D /C  C:\eclipse-4.5-mars-32bit\eclipse.bat
Select 'OK' to save the change.
Configure Eclipse Settings
Enable C/C++ Perspective
Window -> Perspective -> Open Perspective
Select 'Other...'
Select 'C/C++'
'OK'
Enable Python Perspective
Select 'Other...'
Select 'PyDev'
'OK'
Enable Debug Perspective
Select 'Other...'
Select 'Debug'
'OK'
Enable SVN Perspective
Select 'Other...'
Select 'SVN Repository Exploring'
'OK'
Insert Spaces for Tabs
Window -> Preferences -> General -> Editors -> Text Editors
Set 'Displayed tab width' to 4.
Check 'Insert spaces for tabs'.
'Apply'
'OK'
Window -> Preferences -> C/C++ -> Code Style -> Formatter
Select the 'New' button to create a new profile.
Enter 'GRASS' in the 'Profile name' field.
Select 'OK'.
Select the 'Indentation' tab.
Under 'General settings', set Tab policy to 'Spaces only'.
'OK'
Uncheck Build Automatically
'Project' -> 'Build Automatically' to uncheck this option.
Change Color of Python Comments
Expand 'PyDev'.
Select 'Editor'.
In the 'Appearance color options' window:
  Scroll down to 'Comments' and select.
  Click on the 'Color' button to bring up options.
  Select the green color that is located in the 3rd column from the left and 4th row from the top.
'OK'
'Apply'
'OK'
Create C/C++ Project
Create a C++, Makefile, Empty project
"File" -> "New" -> "Project..."
Expand "C/C++" option.
Select "C++ Project"
"Next"
Uncheck 'Use default location'.
Browse to 'C:\OSGeo4W\src\grass7_trunk'.
'OK'
Enter 'grass7_trunk' in the "Project name" field.
Expand 'Makefile project' under 'Project type'.
Select 'Empty Project' under 'Project type'.
Select 'MinGW GCC' under 'Toolchains'.
"Next"
Click on 'Advanced settings...'
Click on 'C/C++ Build'.
Click on the 'Behavior' tab.
Leave 'Build (Incremental Build)' Checked.
Enter 'default' in the text box next to 'Build (Incremental Build)' replacing any text that is already there (e.g., 'all').
'Apply'
'OK'
'Finish'
The 'grass7_trunk' project will appear in the 'Project Explorer' view.
The 'C/C++ Indexer' operation will take some time. Its progress can be monitored in the lower right-hand corner of the screen. Click on the rectangles in the corner to display progress details.
Note: This results in creating the Eclipse .project, .cproject, and .settings files in the top-level directory of the GRASS source code installation.
C:\OSGeo4G\src\grass7_trunk
Create Top-Level Make Targets
 Right-click on 'grass7_trunk' in the 'Project Explorer' view.
 Select "Make Targets"
 Select "Create..."
 Enter 'default' in the 'Target name' field.
 'OK'
Do the same for each of the following targets:
install
clean
distclean
libs
libsclean
cleandistdirs
cleanscriptstrings
manifests
Run a GRASS Python Script
Open Project.
Click on 'Open Project'.
The Indexer and SVN cache updates will take a moment to complete.
Switch to 'PyDev' Perspective.
Click the 'PyDev' button on the 'Perspective' tool bar.
Configure Script.
Click on 'Run' on the main task bar.
Hover over 'Run As' and select 'Run configurations...' from the pop-up list.
Right-click on 'Python Run' and select 'New'.
Enter 'm.proj.py' in the 'Name' field.
Click the 'Project' 'Browse...' button.
Select 'grass7_trunk'.
'OK'
Click the 'Main Module' 'Browse...' button.
Scroll down and enter the 'scripts' -> 'm.proj' folder and select 'm.proj.py'.
'OK'
Select the 'Arguments' tab.
Enter the following string in the 'Program arguments' window:
coordinates=-111d30,45d15.551666667N proj_out="+proj=utm +zone=10 +datum=NAD27" proj_in="+proj=latlong +datum=NAD83" --v
'Apply'
'Run'
Output from the run will be displayed in the 'Console' window.
Run Script.
'Run' -> 'Run'
Change the run focus.
 'Run'
 Click on 'Run configurations...'.
 Select a configured script under 'Python Run'.
 'Run'
Note: The first time a run configuration for a Python script is performed, Eclipse discovers that it must add the Python (PyDev) 'nature' to the project. This results in creating .pydevproject and updating .project in the top-level directory of the GRASS source code installion.
Run a GRASS C/C++ Module
Open Project.
Switch to 'C/C++' Perspective.
Click the 'C/C++' button on the 'Perspective' tool bar.
Configure Module.
Select 'Run configurations...' from the pop-up list.
Right-click on 'C/C++ Application' and select 'New'.
Enter 'r.univar' in the 'Name' field.
'OK'
Click the 'C/C++ Applications' 'Search Project...' button.
Scroll down and select 'r.univar.exe'.
'OK'
'Apply'
map=aspect@PERMANENT
'Apply'
'Run'
Run Module.
'Run' -> 'Run'
 'Run'
 Select a configured application under 'C/C++ Application'.
 'Run'
Train Eclipse
Eclipse needs to discover all the C/C++, Python and Make symbols used to build GRASS. This requires that a complete GRASS system build be performed from the Eclipse workbench. This is accomplished using the following procedure:
Start Eclipse.
Open the 'grass7_trunk' project.
Click on the project to highlight it.
Select 'Project' on the main task bar.
Hover over 'Make Targets' and select 'Build...' from the pop-up list.
Select the 'clean' option that has an empty field under the 'Location' column.
'Build'
Select the 'default' option that has an empty field under the 'Location' column.
'Build'
Click on the icon (stacked rectangles) in the lower right-hand corner of the workbench to view progress.
Build a GRASS C/C++ Module
A GRASS C/C++ module is built and copied to the distribution directory.
Open Project.
Right-click on 'grass7_trunk'.
Select 'Open project'.
Expand the source code tree.
Scroll down to the module.
'grass7_trunk' -> 'raster' -> r.univar
Right-click on the module folder to access its context menu.
Right-click on 'r.univar'.
Hover over 'Make Targets' and select 'Create...'.
'OK'
Enter 'clean' in the 'Target name' field.
'OK'
Hover over 'Make Targets' and select 'Build...'.
'OK'
'OK'
Build results will be displayed in the 'Console' window.
The executable is output to the distribution directory:
'grass7_trunk' -> 'dist.i686-pc-mingw32 -> 'bin'
You can right-click on r.univar.exe' in the distribution directory and select 'Properties' to get the 'Last modified' date and time.
Build a GRASS Python Script
A GRASS Python script is not built like a GRASS C/C++ module because it is an interpreted language. The Makefile located in the directory of the script is used to install the script in the distribution directory.
Open Project.
Scroll down to the script.
'grass7_trunk' -> 'scripts' -> m.proj
Right-click on the script folder to access its context menu.
Right-click on 'm.proj'.
'OK'
'OK'
The script is installed in the distribution directory:
'grass7_trunk' -> 'dist.i686-pc-mingw32' -> 'scripts'
You can right-click on 'm.proj.py' in the distribution directory and select 'Properties' to get the 'Last modified' date and time.
Debug a GRASS C/C++ Module
Switch to C/C++ perspective.
Run 'r.univar' (configured using the 'Run a GRASS C/C++ Module' instructions).
Run -> Run Configuration...
Select 'r.univar' under 'C/C++ Application.
'Run'
Open the C/C++ code to be debugged.
Double-click on:
grass7_trunk -> raster -> r.univar -> r.univar_main.c
Switch to Debug perspective.
On the top task bar:
Run -> Debug
The module will execute and stop at the 1st line in main().
Scroll down to this line:
G_get_window(&region);
After this line, set a breakpoint by double-clicking on the line number. You will see a green button appear next to the line number.
On the debug task bar:
Click on the green arrow ( Resume (F8) ).
The module will execute and stop at the breakpoint.
Hover over any variable to bring up a pop-up window to view its value.
The state of variables executed up to this point will be displayed on the 'Variables' view tab.
Debug a GRASS Python Script
Switch to PyDev perspective.
Run 'm.proj.py' (configured using the 'Run a GRASS Python Script' instructions).
Select 'm.proj.py' under 'Python Run.
'Run'
Open Python code to be debugged.
Double-click on:
grass7_trunk -> scripts -> m.proj -> m.proj.py
cmd = ['cs2cs'] + copyinp + outfmt + in_proj.split() + ['+to'] + out_proj.split()
After this line, set a breakpoint by double-clicking on the line number. You will see a green push-pin appear next to the line number.
Run -> Debug
The script will execute and stop at the breakpoint.
Help
| Eclipse Mars Online Help
  • Workbench User Guide
  • C/C++ Development User Guide
| PyDev Manual
| Subversive User Guide
