GSoC 2026 Add Spatio-Temporal dataset support to datacatalog in GUI
| Student Name | Saket Kumar Mall |
| Organization | NumFOCUS |
| Mentors Name | Anna Petrasova, Stefan Blumentrath |
| GitHub Fork | View Repo |
| LinkedIn Profile | View LinkedIn |
Abstract
Before this project, the GRASS Data Catalog queried only standard spatial maps and bypassed the temporal database entirely. Space-time datasets (STDS) were therefore not visible in the GUI and could only be managed from the command line. Maps that were already registered in an STDS were listed as ordinary standalone maps, with no indication that they belonged to a dataset.
In this project I extended the Data Catalog to support STDS natively. STRDS, STVDS and STR3DS are now listed inside their respective mapset trees alongside the standard spatial maps, registered maps are shown inside the dataset they belong to, and dedicated context menus let users create, inspect, modify and remove datasets and their registered maps directly from the GUI. Alongside the GUI work I also improved, tested and fixed the core temporal tools that the Data Catalog relies on.
Background
GRASS handles time series through its temporal framework. Maps are registered in space-time datasets, which are stored in a temporal database maintained per mapset. Three dataset types exist:
- STRDS — space-time raster dataset
- STR3DS — space-time 3D raster dataset
- STVDS — space-time vector dataset
These datasets are created and manipulated with the t.* tools (t.create, t.register, t.list, and others). Because the Data Catalog did not query the temporal database, none of this structure was visible in the GUI: users could see the individual maps, but not the datasets they belonged to, and every temporal operation required leaving the GUI for the command line.
Project goals
The goals below come from my accepted project proposal. The status column reflects the state of the work at the end of the coding period.
| Goal | Status |
| Show STRDS, STVDS and STR3DS under each mapset in the Data Catalog | Implemented |
| Nest registered maps inside their STDS | Implemented |
| Add context menu operations (create, rename, delete, register/unregister, metadata, export, …) | Implemented |
| Make the Data Catalog search aware of STDS | Implemented |
| Lazy loading for large datasets | Superseded — replaced by the temporal database queries described in Loading strategy and performance |
Enhancements to core temporal tools (format/JSON output, t.list options, bug fixes) |
Implemented, see Temporal tool enhancements |
Implementation
All Data Catalog work is contained in a single pull request, OSGeo/grass#7608, which I developed as a draft from Week 4 onwards and opened for review in Week 10.
Dataset listing and tree structure
- STRDS, STVDS and STR3DS are listed per mapset, at the same level as the existing raster, 3D raster and vector map listings. The dataset types are not grouped under a separate node; users distinguish them by their icons.
- Maps registered in a dataset are shown inside the corresponding dataset node.
- Maps that are already registered in an STDS are hidden from the regular map listing of the mapset. They remain accessible from inside the dataset node.
- I kept the existing Data Catalog hierarchy. Restructuring the whole tree was discussed with my mentors and deliberately rejected (see Design decisions).
Icons
New icons were added for the three dataset types. Each one reuses the existing raster, vector or 3D raster map icon with a clock drawn on top of it, so the dataset type stays recognisable and the temporal nature is immediately visible.
Datasets and their registered maps are loaded as follows:
t.connectis run once to determine which mapsets have a temporal database connection.- For those mapsets, the datasets and the maps registered in them are fetched through the
grass.temporal.gui_supportfunctionstlist_grouped()andregistered_maps_grouped(), which query the temporal database.
registered_maps_grouped() returns a nested dictionary of dataset type → dataset id → registered maps, where each map carries its id, start time, end time and, for relative time, its unit. Maps are ordered by start time, and time stamped maps that are not registered in any dataset are not included. This is what makes it possible to hide already registered maps from the standalone map listing.
The result is one set of queries per mapset instead of one t.*.list call per dataset, which is considerably faster on mapsets holding many datasets.
Two earlier approaches were replaced during development:
- Search path manipulation. At the very start, retrieving datasets from all mapsets required temporarily extending the search path with
g.mapset, runningt.list, and restoring the user's original search path. This was a workaround and was dropped oncet.listsupported themapsetoption (#7631), and later became unnecessary altogether. - Per-dataset listing with lazy loading. Up to Week 7, only the datasets were listed initially and their maps were loaded with
t.*.listwhen a dataset node was expanded. This worked but was slow on larger mapsets and complicated mapset reloading and keeping the tree in sync. Thegui_supportqueries described above made the per-dataset calls unnecessary and simplified the reload logic.
I added context menus for three nodes.
Mapset node
| Action | Description |
| Create temporal dataset | Creates a new STDS in the selected mapset. |
STDS node
| Register maps | Registers maps in the dataset. |
| Unregister maps | Unregisters maps from the dataset. |
| Merge dataset | Merges datasets; cross-mapset merges are supported when the target mapset is in the search path. |
| Update metadata | Updates the dataset metadata. |
| Delete dataset only | Deletes the dataset. |
| Delete dataset and maps | Deletes the dataset together with the maps registered in it (-fd flags).
| Rename dataset | Renames the dataset. |
| Export dataset | Exports the dataset. |
| Show metadata | Displays the dataset metadata. |
| Display temporal extent | Shows the temporal extent of the dataset. |
Map node inside an STDS
| Unregister map | Unregisters the map from its dataset. |
| Copy | Copies the map. |
| Copy name | Copies the map name. |
| Display layer | Adds the map to the current map display. |
| Show metadata | Displays the map metadata. |
Import options
I added the t.*.import tools to the Data Catalog toolbar under "Select another import option", so temporal import is reachable from the same place as the other import tools.
The Data Catalog search was extended to cover STDS, so datasets are found together with the standard spatial maps.
Auto refresh
STDS entries are refreshed automatically across the GUI when datasets are created or modified through context menu, so the tree stays consistent with the temporal database without a manual reload.
Module dialogs
Context menu actions that run a GRASS tool open the corresponding module dialog on top of the existing GUI, instead of launching a separate module window through the --ui option. This keeps the interaction inside the GUI the user is already working in.
Part of this work prepared the temporal tools for the GUI integration, since the Data Catalog depends on them; the rest improved the temporal framework independently.
| Tool | Change | Pull request |
t.list |
Added output format options | #7466 |
t.list |
Added test files | #7482 |
t.list |
Added a check on the temporal database connection so that a temporal database is no longer created for mapsets that have none. This first approach was later replaced by a more robust solution. | #7580 |
t.list |
Added the mapset option, which accepts the current mapset ("."), all mapsets in the search path ("*"), or a comma-separated list of mapsets, together with tests |
#7631 |
t.list |
Added support for listing multiple dataset types in one call (e.g. type=strds,stvds), making the interface consistent with g.list |
#7731 |
t.rast.univar |
Added format options | #7495 |
t.rast.univar |
Added the range to the output and corrected the cells values | #7529 |
t.rast3d.list |
Added pytest files | #7498 |
t.rast3d.list |
Added further checks and fixed the issues they exposed | #7527 |
t.rast3d.list |
Added the format option and tests |
#7531 |
t.rast3d.univar |
Added format options and tests | #7582 |
t.connect |
Added format options | #7535 |
t.connect |
Added pytest coverage | #7573 |
t.vect.db.select |
Added format options | #7530 |
t.vect.db.select |
Added pytest files | #7574 |
| temporal framework | Replaced the use of g.mapset during import with a temporary GISRC environment |
#7434 |
| temporal test suite | Removed needs_solo_run from t.vect.list and fixed typos in the t.vect.list and t.rast.list tests |
#7636 |
Design decisions
- Data Catalog hierarchy kept unchanged
- Changing the overall hierarchical structure of the Data Catalog was discussed with my mentors. After weighing the advantages and disadvantages, we kept the existing structure and built the STDS support on top of it.
- Datasets at the same level, distinguished by icons
- Instead of collecting the three dataset types under a separate group node, they are listed at the same level and told apart by their icons. This keeps the tree flat and consistent with how the existing map types are presented.
- One map, one place in the tree
- Maps registered in an STDS are hidden from the regular map listing rather than shown twice, and remain reachable inside their dataset node.
Current state
- The Data Catalog work described above is complete. It is contained in #7608.
- The temporal tool enhancements listed above are merged.
Reports
| Period | Timeline | Tasks | Pull requests |
| Community Bonding Period |
May 1 – May 24, 2026 |
| Week 1 |
May 25 – May 31, 2026 |
| Week 2 |
June 1 – June 7, 2026 |
| Week 3 |
June 8 – June 14, 2026 |
| Week 4 |
June 15 – June 21, 2026 |
| Week 5 |
June 22 – June 28, 2026 |
| Week 6 |
June 29 – July 5, 2026 |
| Week 7 |
July 6 – July 12, 2026 |
| Week 8 |
July 13 – July 19, 2026 |
| Week 9 |
July 20 – July 26, 2026 |
| Week 10 |
July 27 – August 2, 2026 |
| Week 11 |
August 3 – August 9, 2026 |
| Week 12 |
August 10 – August 16, 2026 |
Additional material:
- GSoC blog: Blog link
Future work
envsupport in the temporal framework — allow an environment to be passed tograss.temporal, e.g.tgis.init(env=env). I started this during the coding period and paused it because it affects several parts of the framework.- Appending to an existing STDS — modify
t.rast.algebra,t.rast.aggregateand similar tools so that their output can be appended to an existing dataset instead of always creating a new one. - Temporal import fixes — resolve issues in the temporal import workflow, such as
t.rast.importfailing when a new project is created and an STRDS is imported into it. - Further temporal tool enhancements — continue the work on format/JSON output and tool options started during the project.
- Usability issues in the temporal workflow — address open issues that make common temporal tasks easier for users.
Pull requests
Data Catalog and GUI
- #7608 — wxGUI/datacatalog: Add STDS in datacatalog
- #7677 — wxGUI: Share watchdog Observer to fix FSEvents RuntimeError
- #7811 — wxGUI/animation: Fix freeze and descriptor exhaustion on large datasets
- #7820 — wxGUI/tplot: Make the window resizable
- #7823 — wxGUI/animation: Integrate g.gui.animation into the GUI as a tab
- #7824 — wxGUI/datacatalog: Add db path tooltip to nodes
Temporal tools and framework
- #7434 — temporal: Use temporary GISRC env instead of g.mapset for import
- #7466 — t.list: Add output format options in t.list
- #7482 — t.list: Add tests files to t.list
- #7495 — t.rast.univar: Add format options in t.rast.univar
- #7498 — t.rast3d.list: Add pytest files
- #7527 — t.rast3d.list: Add checks and some fixes
- #7529 — t.rast.univar: Add range and correct cells values
- #7530 — t.vect.db.select: Add format options
- #7531 — t.rast3d.list: Add format option and tests
- #7535 — t.connect: Add formats
- #7573 — t.connect: Add pytest
- #7574 — t.vect.db.select: Add pytest files
- #7580 — t.list: Check connection to prevent creating temporal database
- #7582 — t.rast3d.univar: Add format options and tests
- #7631 — t.list: Add mapset options for t.list
- #7636 — temporal: Remove needs_solo_run from t.vect.list and fix typos in t.vect.list & t.rast.list tests
- #7731 — t.list: Add support for listing multiple dataset types
- #7825 — temporal: Remove SQLite < 3.33 workaround
Earlier contributions to GRASS
Contributions made before the GSoC coding period.
- #6719 — docs: Fixed broken tutorials link in README
- #6745 — mkdocs: Fixed incorrect URL replacement in view source button
- #6824 — wxGUI: Fixes UTM hemisphere selection in location wizard
- #6864 — MkDocs: Fixes missing Parameter tabs in documentation
- #6875 — v.profile: Add JSON output format
- #6906 — MkDocs: Add title field to frontmatter and remove H1 headings
- #6929 — v.profile: Fix compilation error when GEOS is not installed
- #6949 — v.profile: Fixes incorrect quoting in JSON output
- #6977 — r.kappa: Switch to JSON output using Parson library
- #6979 — lib: Add wrapper for JSON output handling
- #6985 — r.kappa: fix wrong reference data order in testcase
- #6990 — wxGUI/datacatalog: Add database aliases for easier identification
- #7031 — grass.script: Scan GRASS_ADDON_BASE in get_commands()
- #7076 — v.db.select: Rewrite JSON output using parson library
- #7107 — wxGUI/datacatalog: Add copy path option for databases and projects in datacatalog
- #7122 — r.geomorphon: Rewrite with parson and add json test
- #7297 — wxGUI/datacatalog: Add EPSG statusbar button and data catalog context menu options
- grass-tutorials#117 — Tutorials: fix broken link in time series tutorials
