Build SQLite extension on Linux
From GRASS-Wiki
Problem: SQLite lacks by default log(), sqrt(), and other functions.
Solution: In v.db.update there is the following option:
   sqliteextra=name
   Name of SQLite extension file for extra functions (SQLite backend only)
For build SQLite extension for Linux follow these steps:
  • Install a compiler like "gcc"
  • Install the SQLite development package (named "sqlite-dev" or "sqlite-devel")
  • Download extension-functions.c from here:
 wget -c "https://sqlite.org/contrib/download/extension-functions.c/download/extension-functions.c?get=25" -O extension-functions.c
  • Compile the file to get the SQLite extension function library:
    • You can simply save this convenient Makefile (note: indentation must the done with <tab>!) into the same directory in which extension-functions.c is stored (for example, $HOME/software/sqlite_extra):
# https://sqlite.org/contrib/download/extension-functions.c
default:
	gcc -fPIC -lm -shared extension-functions.c -o libsqlitefunctions.so
	@echo "Usage:"
	@echo "  sqlite> SELECT load_extension('/path/to/libsqlitefunctions.so');"
	@echo "  sqlite> select value, log(value) from test;1|0.0"
clean:
	@rm -f libsqlitefunctions.so
    • To compile then just run "make" within the directory where you saved extension-functions.c and the Makefile. If all went fine, you now also have the libsqlitefunctions.so in the directory.
Now libsqlitefunctions.so is built and can be used by v.db.update:
   # Windows
   g.copy vect=precip_30ynormals,myprecip_30ynormals
   v.db.addcolumn myprecip_30ynormals column="logjuly double precision"
   v.db.update myprecip_30ynormals column="logjuly" query_column="log(jul)" \
     sqliteextra=C:\OSGeo4Wdev\src\sqliteextension\libsqlitefunctions.dll
   # Linux
     sqliteextra=$HOME/software/sqlite_extra/libsqlitefunctions.so
See also
