Convert lines to areas
From GRASS-Wiki
Q: Is there a way to construct a vector polygon map from closed line rings?
A: Yes, to convert a lines map into an area map, do:
Requirement: the line rings must be closed.
  • run v.type to convert from line type to boundary type
  • run v.centroids to add missing centroids to closed boundaries
Example:
 v.type input=map_l output=map_b type=line,boundary
 v.centroids input=map_b output=map_polygons
See also
