Converting Bash scripts to Python
From GRASS-Wiki
Jump to: navigation, search
This page contains some notes for the users who are converting their Bash script to Python.
User break
In Bash:
# what to do in case of user break:
 g.remove rast=$TMP1 > /dev/null
# shell check for user break (signal list: trap -l)
trap "exitprocedure" 2 3 15
In Python:
import sys
import atexit
import grass.script as grass
def cleanup():
                      rast = tmp1)
def main():
    return 0
if __name__ == "__main__":
    options, flags = grass.parser()
Discard warning/error messages
In Bash:
g.remove rast='map' 2>/dev/null
In Python:
import os
nuldev = file(os.devnull, 'w+')
grass.run_command('g.remove', rast = 'map', stderr = nuldev)
Note: In GRASS 6.5+ set
export GRASS_MESSAGE_FORMAT=silent (in Bash)
os.environ['GRASS_MESSAGE_FORMAT'] = 'silent' (in Python)
