Development GEM
From GRASS-Wiki
Jump to: navigation, search
Should be moved to Trac Wiki as a historical document; better name is need.
- Applies to GRASS Version 6 (but only pre 6.4) -
GRASS add-on structure using GEM
(copy from e-mail to dev List)
The following options are a sum-up of ideas concerning the GEM repository so that the GEM add-on structure plus svn(?) can be properly set-up.
Nomenclatur
  • main: path to GRASS-main code (restricted to GRASS-main developers)
  • add-on: path to additional function (moderated "public" develop.)
  • commands: well, single commands ...
  • packages: bunch of commands dealing with a certain issues
software constraints
  • migration to svn is necessary to have restricted/selective access for main and add-on
add-on manager (person)
  • an add-on manager who checks incoming commands/packages for their quality (code, help, man-pages)
  • a status for fresh commands would be good (fresh commands vs. "officially" accepted commands) -> how does R deal with it? Automated builds could be done on grass.itc.it along with a status page
GEM
  • packages installed via UI or CI via WWW or local
  • packages updated via UI or CI
  • packages afterwards permanently loaded in certain location/mapset and not in others
  • package removal from location/mapset
add-on structure
(I orientate myself on the R structure, because I am familiar with it and like it, if anybody else has different ideas, please feel free to discuss it)
  • setup of different packages for different topics (classif., hydro., landscape ecol., spatial model. etc. see below)
  • every command is assigned to a package, even the "old" one, just to keep the structure consistent (?) - assigned to package "base"?
  • r.*, v.*, i.* commands might be together in one package and installed simultaneously - no splitting between r./v./i. commands in separate packages
  • after loading in UI:
raster/package_name->command vector/package_name->command --> no merge inside "base" commands but in separate dir in UI
  • broad package topics for starting point; in the future further splitting might be necessary to keep it simple:
    • data handling
    • Geo-Statistics
    • GIS tasks
    • image classification
    • hydrology
    • spatial modelling
    • landscape ecology
    • fire modelling
    • bathymetry
    • data enhancement
I would suggest to list all commands in the man pages with their package affiliation in brackets and not to list them only if package is loaded or in separate directory. An idea could be to assign 5 keywords to each command/man page from a list of key words (semi-automate?)
