FUTURES land-change modeling for evaluating innovative conservation scenarios
From GRASS-Wiki
Jump to: navigation, search
This is material for US-IALE 2019 workshop FUTURES land-change modeling for evaluating innovative conservation scenarios held in Fort Collins, Colorado, April 9, 2019. This workshop introduces GRASS GIS and FUTURES urban growth modeling framework.
Workshop introduction
r.futures.* is an implementation of the FUTure Urban-Regional Environment Simulation (FUTURES)[1] which is a model for multilevel simulations of emerging urban-rural landscape structure. FUTURES produces regional projections of landscape patterns using coupled submodels that integrate nonstationary drivers of land change: per capita demand (DEMAND submodel), site suitability (POTENTIAL submodel), and the spatial structure of conversion events (PGA submodel).
[1] Meentemeyer, R. K., Tang, W., Dorning, M. A., Vogler, J. B., Cunniffe, N. J., & Shoemaker, D. A. (2013). FUTURES: multilevel simulations of emerging urban-rural landscape structure using a stochastic patch-growing algorithm. Annals of the Association of American Geographers, 103(4), 785-807
Software
There are a number of software requirements to run FUTURES that will need to be download and installed. Required software includes:
Installation
We use the R statistical software for our calculation of site suitability (i.e. development potential) in FUTURES. R is a free software environment for statistical computing and graphics. If you don't have R, or you have older an version, please download and install the software from install R and be sure to additionally add these required packages:
install.packages(c("MuMIn", "lme4", "optparse", "rgrass7"))
Note: If you use MS Windows, make sure you first install R and then GRASS GIS, that will enable you to easily use R from GRASS GIS.
Use the instructions bellow to install GRASS GIS.
MS Windows
We will be using GRASS GIS 7.6.1 that can be found here in the OSGeo4W package manager. Please install the latest stable GRASS GIS 7 version and the SciPy Python package using the Advanced install option. A guide with step by step screen shot instructions is available here.
In order for GRASS to be able to find R executables, R must be on the PATH variable. If you install GRASS after you installed R, GRASS automatically looks for R executable, so you should be fine. If not, follow this solution to make R accessible from GRASS permanently. A simple but temporary solution is to open GRASS GIS and paste this in the black terminal (adjust the version):
set PATH=%PATH%;C:\Program Files\R\R-3.0.2\bin
This has to be repeated after restarting GRASS session.
Ubuntu Linux
Install GRASS GIS from packages:
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
sudo apt-get install grass
Mac OS X
Install GRASS GIS 7.6.0 from downloads page and follow the instruction. For latest Mojave, see also this known issue affecting addons installation.
Note: If r.futures.potential won't run for you despite R being installed, open new terminal and run:
which Rscript
and then append the printed path to PATH variable and run this command in GRASS GIS terminal:
export PATH="$PATH:/usr/local/bin/"
Then run r.futures.potential from GRASS command line (you may need to change directory to wherever you have your files).
FUTURES
Once GRASS GIS is installed, required addons needed for the workshop can be downloaded and installed from a GRASS GIS session. You can do this step once you are more familiar with GRASS after going through the GRASS GIS introduction in the next section:
g.extension r.futures
g.extension r.sample.category
Workshop data
The data that we will be using for the workshop can be download here: sample dataset.
The dataset is prepared as GRASS GIS Location (part of GRASS GIS Database) and it includes data from the following sources:
  • digital elevation model (NED)
  • NLCD 2001, 2006, 2011
  • NLCD 1992/2001 Retrofit Land Cover Change Product
  • transportation network (TIGER)
  • county boundaries (TIGER)
  • protected areas (Secured Lands)
  • cities as points (USGS)
In addition, download population information as text files.
These text files containing county population past estimates and future projections were prepared based on (nonspatial) data available from NC OSBM.
Here we provide an overview of the GRASS GIS project: grass.osgeo.org that might be helpful to review if you are a first time user. For this exercise it's not necessary to have a full understanding of how to use GRASS GIS. However, you will need to know how to place your data in the correct GRASS GIS database directory, as well as some basic GRASS functionality. Here we introduce main concepts necessary for running the tutorial:
Setting up GRASS for the tutorial
GRASS uses unique database terminology and structure (GRASS database) that are important to understand for the set up of this tutorial, as you will need to place the required data (e.g. Location) in a specific GRASS database. In the following we review important terminology and give step by step directions on how to download and place you data in the correct location.
Important GRASS directory terminology
  • A GRASS database consists of directory with specific Locations (projects) where data layer are stored
  • Location is a directory with data related to one geographic location or a project. All data within one Location has the same coordinate reference system.
  • Mapset is a collection of maps within Location, containing data related to a specific task, user or a smaller project
Creating a GRASS database for the tutorial
You need to create a GRASS database with the Mapset that we will use for the tutorial before we can run the FUTURES model. Please download the GRASS Location for the workshop, noting where the files are located on your local directory. Now, create (unless you already have it) a directory named grassdata (GRASS database) in your home folder (or Documents), unzip the downloaded data into this directory. You should now have a Location futures_ncspm in grassdata.
Launching and exploring data in GRASS
Now that we have the data in the correct GRASS database, we can launch the Graphical User Interface (GUI) in Mapset practice1. The GUI interface allows you to display raster, vector data as well as navigate through zooming in and out. Advanced exploration and visualization, like many popular GIS software, is also possible in GRASS (e.g. queries, adding legend). The print screens below depicts how you can add different map layers (left) and display the metadata of your data layers.
GRASS functionality
One of the advantages of GRASS is the diversity and number of modules that let you analyze all manner of spatial and temporal. GRASS GIS has over 500 different modules in the core distribution and over 230 addon modules that can be used to prepare and analyze data layers.
Prefix Function Example
r.* raster processing r.mapcalc: map algebra
v.* vector processing v.clean: topological cleaning
i.* imagery processing i.segment: object recognition
db.* database management db.select: select values from table
r3.* 3D raster processing r3.stats: 3D raster statistics
t.* temporal data processing t.rast.aggregate: temporal aggregation
g.* general data management g.rename: renames map
d.* display d.rast: display raster map
Command line vs. GUI interface
GRASS modules can be executed either through a GUI or command line interface. The GUI offers a user-friendly approach to executing modules where the user can navigate to data layers that they would like to analyze and modify processing options with simple check boxes. The GUI also offers an easily accessible manual on how to execute a model. The command line interface allows users to execute a module using command prompts specific to that module. This is handy when you are running similar analyses with minor modification or are familiar with the module commands for quick efficient processing. In this workshop we provide module prompts that can be copy and pasted into the command line for our workflow, but you can use both GUI and command line depending on personal preference. Look how GUI and command line interface represent the same tool.
Task: compute aspect (orientation) from provided digital elevation model using module r.slope.aspect using both module dialog and command line.
  • How to find modules? Modules are organized by their functionality in wxGUI menu, or we can search for them in Search modules tab. If we already know which module to use, we can just type it in the wxGUI command console.
  • Modules can be found in wxGUI menu
  • You can search modules by name, description or keywords in Search modules tab
  • By typing prefix r. we make a list of modules starting with that prefix to show up.
Computational region
Computational region - is an important raster concept in GRASS GIS. In GRASS a computational region can be set, subsetting larger extent data for quicker testing of analysis or analysis of specific regions based on administrative units. We provide a few points to keep in mind when using the computational region function:
  • defined by region extent and raster resolution
  • applies to all raster operations
  • persists between GRASS sessions, can be different for different mapsets
  • advantages: keeps your results consistent, avoid clipping, for computationally demanding tasks set region to smaller extent, check your result is good and then set the computational region to the entire study area and rerun analysis
  • run g.region -p or in menu Settings - Region - Display region to see current region settings
Simple ways to set computational region from GUI. On the left, set region to match raster map. On the right, select the highlighted option and then set region by drawing rectangle.
Modeling with FUTURES
Initial steps and data preparation
First we will set the computational region of our analyses to an extent covering our study area that aligns with our base landuse rasters. Like explained in the instructions above, you simply need copy and paste these commands into the command prompt of GRASS or open g.region dialog.
g.region raster=landuse_2011 -p
The FUTURES model uses the locations of development and new development to predict when and where new urban growth will occur. This requires longitudinal data on urban land use. We will derive urbanized areas from NLCD dataset for year 1992, 2001, 2006 and 2011 by extracting categories category 21 - 24 into a new binary map where developed is 1, undeveloped 0 and NULL (no data). The NULL area is important in simulating urban growth as it precludes these are from becoming development. For this exercise we assume that water, wetlands and protected areas can not be developed, setting them to NULL.
First we will convert protected areas from vector to raster. We set NULLs to zeros (for simpler raster algebra expression in the next step) using r.null. Copy line by line into GUI command console and press Enter after each command.
v.to.rast input=protected_areas output=protected_areas use=val
r.null map=protected_areas null=0
And then create rasters of developed/undeveloped areas using raster algebra:
r.mapcalc "urban_1992 = if(landuse_1992 >= 20 && landuse_1992 <= 24, 1, if(landuse_1992 == 11 || landuse_1992 >= 90 || protected_areas, null(), 0))"
r.mapcalc "urban_2001 = if(landuse_2001 >= 21 && landuse_2001 <= 24, 1, if(landuse_2001 == 11 || landuse_2001 >= 90 || protected_areas, null(), 0))"
r.mapcalc "urban_2006 = if(landuse_2006 >= 21 && landuse_2006 <= 24, 1, if(landuse_2006 == 11 || landuse_2006 >= 90 || protected_areas, null(), 0))"
r.mapcalc "urban_2011 = if(landuse_2011 >= 21 && landuse_2011 <= 24, 1, if(landuse_2011 == 11 || landuse_2011 >= 90 || protected_areas, null(), 0))"
FUTURES is a multi-level modelling framework meaning that we model population projections for subregions and assume that these subregions are influenced differently by the factors that influence where development happens. This requires defining subregions for model implementation. For this exercise we use the county level, which is the finest scale of population data that is available to us. We therefore need to convert vectors of counties to a raster with the values of the FIPS attribute which links to population file:
v.to.rast input=counties type=area use=attr attribute_column=value output=counties
Before further steps, we will set our working directory so that the input population files and text files we are going to create in the following section are saved in one directory and easily accessible. You can do that from menu SettingsGRASS working environmentChange working directory. Select (or create) a directory and move there the downloaded files population_projection.csv and population_trend.csv.
Potential submodel
Module r.futures.potential implements the POTENTIAL submodel as a part of FUTURES land change model. POTENTIAL is implemented using a set of coefficients that relate a selection of site suitability factors to the probability of a place becoming developed. This is implemented using the parameter table in combination with maps of those site suitability factors (mapped predictors). The coefficients are obtained by conducting multilevel logistic regression in R with package lme4 where the coefficients may vary by county. The best model is selected automatically using dredge function from package MuMIn.
First, we will derive possible predictors of urban growth using GRASS modules.
Predictors
Slope
Slope possibly influences urban growth as steep areas are difficult to build on. We will derive slope in degrees from digital elevation model using r.slope.aspect module:
r.slope.aspect elevation=elevation_30m slope=slope
Distance from lakes/rivers
Distance to lakes or rivers may contribute to an amenity draw where people would like to build a house in a location where they can view water. First we will extract category Open Water from 2011 NLCD dataset:
r.mapcalc "water = if(landuse_2011 == 11, 1, null())"
Then we compute the distance to water with module r.grow.distance and set color table to shades of blue:
r.grow.distance input=water distance=dist_to_water
r.colors -n map=dist_to_water color=blues -e
Distance from protected areas
Like water protected areas can attract urban growth as people enjoy living near scenic areas. We will use raster protected of protected areas we already created, but we will set NULL values to zero. We compute the distance to protected areas with module r.grow.distance and set color table from green to red:
r.null map=protected_areas setnull=0
r.grow.distance input=protected_areas distance=dist_to_protected
r.colors map=dist_to_protected color=gyr -e
Forests
Forest may influence urban growth in different ways. On the one hand it might be costly for developments as tree will need to be removed. On the other hand, people may want to live near forests. We calculate the percentage forest for a 0.5 km pixel to test forest influence, see NLCD categories Forest. We derive the percentage of forest also for year 1992.
r.mapcalc "forest = if(landuse_2011 >= 41 && landuse_2011 <= 43, 1, 0)"
r.mapcalc "forest_1992 = if(landuse_1992 >= 40 && landuse_1992 <= 43, 1, 0)"
r.neighbors -c input=forest output=forest_smooth size=15 method=average
r.neighbors -c input=forest_1992 output=forest_1992_smooth size=15 method=average
r.colors map=forest_smooth,forest_1992_smooth color=ndvi
Distance to main urban centers
Concentrated population and economic activities around main urban centers are important drivers of development. To calculate this influence we will compute distance to urban centers with more than 200,000 inhabitants:
r.grow.distance input=city_center distance=dist_to_city_center
Road density
Dense road construction often occurs in suburban areas where much much development occurs in U.S. cities. To capture this influence we can calculate road density based on the road network. We rasterize roads and use a moving window analysis (r.neighbors) to compute road density for a 1 km area:
r.neighbors -c input=roads output=road_dens size=25 method=average
Development pressure
Development pressure (computed by r.futures.devpressure) visualized as 3D surface with binary development map draped as color (orange developed, grey undeveloped).
Development pressure is an important variable in the FUTURES model that is always included as a dynamic variable reinforcing the pressure of past development. We assume that urban development in one location will increase the chance of development in near proximity. New simulated development is incorporated into calculating this development pressure every time step that FUTURES simulates urban growth. To estimate the influence that this local development pressure has, we include the development pressure r.futures.devpressure in our initial model estimates. Development pressure is based on number of neighboring developed cells within a specified search distance, weighted by distance. Its special role in the model allows for path dependent feedback between predicted change and change in subsequent steps.
When gamma increases, development influence decreases more rapidly with distance. Size is half the size of the moving window. When gamma is low, local development influences more distant places. We compute development pressure for development in 1992 for Potential model to estimate how much development pressure influenced new development between 1992 and 2011. Then, we compute it also for 2011 for future projections.
r.null map=urban_2011 null=0
r.null map=urban_1992 null=0
r.futures.devpressure -n input=urban_1992 output=devpressure_30_05_01_92 method=gravity size=30 gamma=0.5 scaling_factor=0.1
r.futures.devpressure -n input=urban_2011 output=devpressure_30_05_01_2011 method=gravity size=30 gamma=0.5 scaling_factor=0.1
Rescaling variables
First we will look at the ranges of our predictor variables by running a short Python code snippet in GUI Python shell (right click and select Paste Plus):
for name in ['slope', 'dist_to_water', 'dist_to_protected',
             'forest_smooth', 'forest_1992_smooth', 'dist_to_city_center',
             'road_dens', 'devpressure_30_05_01_92', 'devpressure_30_05_01_2011']:
    minmax = grass.raster_info(name)
    print name, minmax['min'], minmax['max']
We will rescale some of our input variables:
r.mapcalc "dist_to_water_km = dist_to_water / 1000"
r.mapcalc "dist_to_protected_km = dist_to_protected / 1000"
r.mapcalc "dist_to_city_center_km = dist_to_city_center / 1000"
r.mapcalc "road_dens_perc = road_dens * 100"
r.mapcalc "forest_smooth_perc = forest_smooth * 100"
r.mapcalc "forest_1992_smooth_perc = forest_smooth * 100"
Sampling
To build multilevel statistical model describing the relation between predictors and observed change, we randomly sample predictors and response variable. Our response variable is new development between 1992 and 2011.
r.mapcalc "urban_change_92_11 = if(urban_2011 == 1, if(urban_1992 == 0, 1, null()), 0)"
To sample only in the analyzed counties, we will clip the layer:
r.mapcalc "urban_change_clip = if(counties, urban_change_92_11)"
To help estimate the number of sampling points, we can use r.report to report number of developed/undeveloped cells.
r.report map=urban_change_clip units=h,c,p
We will sample the predictors and the response variable with more random points in undeveloped areas than in newly developed areas:
r.sample.category input=urban_change_clip output=sampling sampled=counties,devpressure_30_05_01_92,slope,road_dens_perc,forest_1992_smooth_perc,dist_to_water_km,dist_to_protected_km,dist_to_city_center_km npoints=5000,1000
The attribute table can be exported as CSV file (not necessary step):
v.db.select map=sampling columns=counties,devpressure_30_05_01_92,slope,road_dens_perc,forest_1992_smooth_perc,dist_to_water_km,dist_to_protected_km,dist_to_city_center_km separator=comma file=samples.csv
Development potential
Now we find best model for predicting urbanization using r.futures.potential which wraps an R script.
We can run R dredge function to find "best" model. We can specify minimum and maximum number of predictors the final model should use. WARNING: can take some time to run.
r.futures.potential -d input=sampling output=potential.csv columns=counties,devpressure_30_05_01_92,slope,road_dens_perc,forest_1992_smooth_perc,dist_to_water_km,dist_to_protected_km,dist_to_city_center_km developed_column=urban_change_clip subregions_column=counties min_variables=4
You can then open the output file potential.csv, which is a CSV file with tabs as separators.
For this tutorial, the final potential is created with:
r.futures.potential input=sampling output=potential.csv columns=devpressure_30_05_01_92,road_dens_perc,forest_1992_smooth_perc,dist_to_water_km,dist_to_city_center_km developed_column=urban_change_clip subregions_column=counties --o
FUTURES site suitability modeled by r.futures.potential and computed by r.futures.potsurface
We can now visualize the suitability surface using module r.futures.potsurface. It creates initial development potential (suitability) raster from predictors and model coefficients and serves only for evaluating development Potential model. The values of the resulting raster range from 0 to 1.
r.futures.potsurface input=potential.csv subregions=counties output=suitability
r.colors map=suitability color=byr
Demand submodel
Per capita development for one county derived by r.futures.demand using logarithmic2 method
First we will mask out roads so that they don't influence into per capita land demand relation.
r.mask raster=roads maskcats=0
We will use r.futures.demand which derives the population vs. development relation. The relation can be linear/logarithmic/logarithmic2/exponential/exponential approach. Look for examples of the different relations in the manual.
  • linear: y = A + Bx
  • logarithmic: y = A + Bln(x)
  • logarithmic2: y = A + B * ln(x - C)        (requires SciPy)
  • exponential: y = Ae^(BX)
  • exp_approach: y = (1 - e^(-A(x - B))) + C        (requires SciPy)
The format of the input population CSV files is described in the manual. It is important to have synchronized categories of subregions and the column headers of the CSV files (in our case FIPS number). How to simply generate the list of years (for which demand is computed) is described in r.futures.demand manual, for example run this in Python console:
','.join([str(i) for i in range(2011, 2036)])
Then we can create the DEMAND file:
r.futures.demand development=urban_1992,urban_2001,urban_2006,urban_2011 subregions=counties observed_population=population_trend.csv projected_population=population_projection.csv simulation_times=2011,2012,2013,2014,2015,2016,2017,2018,2019,2020,2021,2022,2023,2024,2025,2026,2027,2028,2029,2030,2031,2032,2033,2034,2035 plot=plot_demand.pdf demand=demand.csv separator=comma method=logarithmic
In your current working directory, you should find files plot_demand.pdf and demand.csv.
If you have SciPy installed, you can experiment with other methods for fitting the functions:
r.futures.demand ... method=linear,logarithmic,logarithmic2,exp_approach
If necessary, you can create a set of demand files produced by fitting each method separately and then pick for each county the method which seems best and manually create a new demand file.
When you are finished, remove the mask as it is not needed for the next steps.
r.mask -r
Patch calibration
Patch calibration can be a very time consuming computation. Therefore we select only one county (Wake):
v.to.rast input=counties type=area where="value == 37183" use=attr attribute_column=value output=calib_county
g.region raster=calib_county zoom=calib_county
to derive patches of new development by comparing historical and latest development. We can keep only patches with minimum size 2 cells (1800 = 2 x 30 x 30 m).
r.futures.calib development_start=urban_1992 development_end=urban_2011 subregions=counties patch_sizes=patches.txt patch_threshold=1800  -l
We obtained a file patches.txt (used later in the PGA) - a patch size distribution file - containing sizes of all found patches.
We can look at the distribution of the patch sizes:
from matplotlib import pyplot as plt
with open('patches.txt') as f:
    patches = [int(patch) for patch in f.readlines()]
plt.hist(patches, 2000)
plt.xlim(0,50)
plt.show()
At this point, we start the calibration to get best parameters of patch shape (for this tutorial, this step can be skipped and the suggested parameters are used).
r.futures.calib development_start=urban_1992 development_end=urban_2011 subregions=calib_county patch_sizes=patches.txt calibration_results=calib.csv patch_threshold=1800 repeat=10 compactness_mean=0.1,0.3,0.5,0.7,0.9 compactness_range=0.05 discount_factor=0.1,0.3,0.5,0.7,0.9 predictors=road_dens_perc,forest_2011_smooth_perc,dist_to_water_km,dist_to_city_center_km demand=demand.csv devpot_params=potential.csv num_neighbors=4 seed_search=2 development_pressure=devpressure_30_05_01_2011 development_pressure_approach=gravity n_dev_neighbourhood=30 gamma=0.5 scaling_factor=0.1
FUTURES simulation
We will switch back to our previous region:
g.region vector=counties align=landuse_2011 -p
Now we have all the inputs necessary for running r.futures.pga:
The entire command is here:
r.futures.pga subregions=counties developed=urban_2011 predictors=road_dens_perc,forest_smooth_perc,dist_to_water_km,dist_to_city_center_km devpot_params=potential.csv development_pressure=devpressure_30_05_01_2011 n_dev_neighbourhood=30 development_pressure_approach=gravity gamma=0.5 scaling_factor=0.1 demand=demand.csv discount_factor=0.1 compactness_mean=0.1 compactness_range=0.05 patch_sizes=patches.txt num_neighbors=4 seed_search=2 random_seed=1 output=final output_series=step
Example of resulting pattern of r.futures.pga
Quick description
The command parameters and their values:
  • raster map of counties with their categories
... subregions=counties ...
  • raster of developed (1), undeveloped (0) and NULLs for undevelopable areas
... developed=urban_2011 ...
  • predictors selected with r.futures.potential and their coefficients in a potential.csv file. The order of predictors must match the order in the file and the categories of the counties must match raster counties.
... predictors=road_dens_perc,forest_smooth_perc,dist_to_water_km,dist_to_city_center_km devpot_params=potential.csv ...
  • initial development pressure computed by r.futures.devpressure, it's important to set here the same parameters
... development_pressure=devpressure_30_05_01_2011 n_dev_neighbourhood=30 development_pressure_approach=gravity gamma=0.5 scaling_factor=0.1 ...
  • per capita land demand computed by r.futures.demand, the categories of the counties must match raster counties.
... demand=demand.csv ...
  • patch parameters from the calibration step
... discount_factor=0.1 compactness_mean=0.1 compactness_range=0.05 patch_sizes=patches.txt ...
  • recommended parameters for patch growing algorithm
... num_neighbors=4 seed_search=2 ...
  • set random seed for repeatable results or set flag -s to generate seed automatically
... random_seed=1 ...
  • specify final output map and optionally basename for intermediate raster maps
Color table
FUTURES results animated
To highlight newly developed areas, we can set the following color ramp of raster final using r.colors. Copy and paste the following color ramp specification into tab Define, option rules:
-1 180:255:160
0 200:200:200
1 255:100:50
24 255:255:0
Animating results
Follow a tutorial how to make an animation from the results.
Scenarios
Scenarios involving policies that encourage infill versus sprawl can be explored using the incentive_power parameter of r.futures.pga, which uses a power function to transform the evenness of the probability gradient in POTENTIAL. You can change the power to a number between 0.25 and 4 to test urban sprawl/infill scenarios.
Lower power leads to urban sprawl behavior. Here is an example:
r.futures.pga subregions=counties developed=urban_2011 predictors=road_dens_perc,forest_smooth_perc,dist_to_water_km,dist_to_city_center_km devpot_params=potential.csv development_pressure=devpressure_30_05_01_2011 n_dev_neighbourhood=30 development_pressure_approach=gravity gamma=0.5 scaling_factor=0.1 demand=demand.csv discount_factor=0.1 compactness_mean=0.1 compactness_range=0.05 patch_sizes=patches.txt num_neighbors=4 seed_search=2 random_seed=1 output=final_sprawl output_series=step_sprawl incentive_power=0.25
Higher power leads to urban infill behavior, where new development is promoted close to existing developed areas. Here is an example:
r.futures.pga subregions=counties developed=urban_2011 predictors=road_dens_perc,forest_smooth_perc,dist_to_water_km,dist_to_city_center_km devpot_params=potential.csv development_pressure=devpressure_30_05_01_2011 n_dev_neighbourhood=30 development_pressure_approach=gravity gamma=0.5 scaling_factor=0.1 demand=demand.csv discount_factor=0.1 compactness_mean=0.1 compactness_range=0.05 patch_sizes=patches.txt num_neighbors=4 seed_search=2 random_seed=1 output=final_infill output_series=step_infill incentive_power=4
We can use parameter constrain_weight to decrease the probability p of development in a specified area. Input is a raster with values from 0 to 1 where 1 does not change the probability. Resulting probability = p * constrain_weight.
To increase the probability that certain area develops we can use parameter stimulus. Input is again raster with values between 0 and 1, where value 0 does not influence the probability. Resulting probability = p + stimulusp * stimulus.
Task: pick one scenario and rerun analysis. You can use vector digitizer to digitize area for increasing or decreasing probability.
Parallel processing
To be able to evaluate the effect of scenarios on landscape, we will run several stochastic runs of each scenario. We will use r.futures.parallelpga to run the simulation on multiple CPUs. Addon r.futures.parallelpga wraps r.futures.pga and so it has the same parameters, but adds two more, nprocs to specify number of parallel processes and repeat to specify number of random runs. Omit random_seed parameter (handled by r.futures.parallelpga) and add your selected scenario parameter.
Select appropriate values for your computer, do not specify high number of cores unless you have plenty of memory.
r.futures.parallelpga nprocs=2 repeat=10 ...
In your computer does not have sufficient memory, you can use flag -d flag, which runs the simulation per subregion and merges the results together. This however can cause small discontinuities along subregion boundaries.
r.futures.parallelpga -d nprocs=2 repeat=10 ...
GRASS GIS Python API
Introduction to the GRASS GIS 7 Python Scripting Library
Python shell in GRASS GIS GUI
The GRASS GIS 7 Python Scripting Library provides functions to call GRASS modules within scripts as subprocesses. The most often used functions include:
  • run_command: most often used with modules which output raster/vector data where text output is not expected
  • read_command: used when we are interested in text output
  • parse_command: used with modules producing text output as key=value pair
  • write_command: for modules expecting text input from either standard input or file
Besides, this library provides several wrapper functions for often called modules.
Calling GRASS GIS modules
We will use GRASS GUI Python Shell to run the commands. For longer scripts, you can create a text file, save it into your current working directory and run it with python myscript.py from the GUI command console or terminal.
Tip: When copying Python code snippets to GUI Python shell, right click at the position and select Paste Plus in the context menu. Otherwise multiline code snippets won't work.
We start by importing GRASS GIS Python Scripting Library:
import grass.script as gscript
Before running any GRASS raster modules, you need to set the computational region using g.region. In this example, we set the computational extent and resolution to the raster layer elevation_30m.
gscript.run_command('g.region', raster='elevation_30m')
The run_command() function is the most commonly used one. Here, we apply the focal operation average (r.neighbors) to smooth the elevation raster layer. Note that the syntax is similar to bash syntax, just the flags are specified in a parameter.
gscript.run_command('r.neighbors', input='elevation_30m', output='elev_smoothed', method='average', flags='c')
If we run the Python commands from GUI Python console, we can use AddLayer to add the newly created layer:
AddLayer('elev_smoothed')
Calling GRASS GIS modules with textual input or output
Textual output from modules can be captured using the read_command() function.
gscript.read_command('g.region', flags='p')
gscript.read_command('r.univar', map='elev_smoothed', flags='g')
Certain modules can produce output in key-value format which is enabled by the -g flag. The parse_command() function automatically parses this output and returns a dictionary. In this example, we call g.proj to display the projection parameters of the actual location.
gscript.parse_command('g.proj', flags='g')
For comparison, below is the same example, but using the read_command() function.
gscript.read_command('g.proj', flags='g')
Certain modules require the text input be in a file or provided as standard input. Using the write_command() function we can conveniently pass the string to the module. Here, we are creating a new vector with one point with v.in.ascii. Note that stdin parameter is not used as a module parameter, but its content is passed as standard input to the subprocess.
gscript.write_command('v.in.ascii', input='-', stdin='%s|%s' % (283730, 208920), output='point')
AddLayer('point')
Convenient wrapper functions
Some modules have wrapper functions to simplify frequent tasks. For example we can obtain the information about a raster layer with raster_info which is a wrapper of r.info.
gscript.raster_info('elevation_30m')
Another example is using r.mapcalc wrapper for raster algebra:
gscript.mapcalc("forest_2011 = if(landuse_2011 >= 41 && landuse_2011 <= 43, 1, null())")
Function region is a convenient way to retrieve the current region settings (i.e., computational region). It returns a dictionary with values converted to appropriate types (floats and ints). Paste line by line if using GUI Python shell.
region = gscript.region()
print region
# cell area in map units (in projected Locations)
region['nsres'] * region['ewres']
We can list data stored in a GRASS GIS location with g.list wrappers. With list_grouped, the map layers are grouped by mapsets (in this example, raster layers):
gscript.list_grouped(type=['raster'])
gscript.list_grouped(type=['raster'], pattern="landuse*")
Here is an example of a different g.list wrapper list_pairs which structures the output as list of pairs (name, mapset). We obtain current mapset with g.gisenv wrapper.
current_mapset = gscript.gisenv()['MAPSET']
gscript.list_pairs('raster', mapset=current_mapset)
Post-processing with Python
We will show you some examples how we can use Python to process the results of our stochastic runs efficiently.
Developed land
In this example, you will compute how much forest and farmland (in average for all stochastic runs) is projected to be developed. Use list_grouped, r.mapcalc, r.stats in the following Python code. We suggest to first become familiar with modules' options and test them separately.
import numpy as np
# list maps computed by r.futures.parallelpga for one scenario
# ------ FILL IN HERE -------
# maps =
forest = []
agriculture = []
other = []
for each in maps:
    # compute landcover in 2035 by updating landcover 2011 with the simulation results:
    # gscript...
    # get information about how many cells there are of each land use category, use r.stats
    # res = gscript...
    for line in res.strip().splitlines():
        cat, cells = line.split()
        cat = int(cat)
        cells = int(cells)
        # developed
        if 21 <= cat <= 24:
            developed.append(cells)
        # agriculture
        elif cat == 81 or cat == 82:
            agriculture.append(cells)
        # forest
        elif 41 <= cat <= 43:
            forest.append(cells)
        # other land use
        else:
            other.append(cells)
# convert to NumPy arrays
forest = np.array(forest)
agriculture = np.array(agriculture)
other = np.array(other)
developed = np.array(developed)
print "forest: {mean} +- {std}".format(mean=np.mean(forest), std=np.std(forest))
print "agriculture: {mean} +- {std}".format(mean=np.mean(agriculture), std=np.std(agriculture))
print "other: {mean} +- {std}".format(mean=np.mean(other), std=np.std(other))
print "developed: {mean} +- {std}".format(mean=np.mean(developed), std=np.std(developed))
Forest fragmentation
Forest fragmentation computed with addon r.forestfrag
In the next example we show how we can quantify forest fragmentation for our stochastic runs. We will use addon r.forestfrag. You can install it with:
g.extension r.forestfrag
We will run the fragmentation only for a small extent, because it's computationally demanding:
g.region n=214800 s=210390 w=275580 e=280020 -p
Fill in the missing steps in the workflow and run:
# we will first define function which needs as input new landcover 2035 from previous example and
# 1. converts the landuse to binary forest map (categories 41 - 43)
# 2. compute forest fragmentation, use -a flag and set window=25 for example
# 3. remove temporary maps with g.remove
def forest_fragmentation(landuse):
    # 1.
    # 2.
    result = gscript.parse_command('r.stats', input='fragment', flags='cn',
                                   parse=(gscript.parse_key_val, {'sep': ' ', 'val_type': int}))
    # 3.
    return result
# then we will use this function:
landuse_maps = gscript.list_grouped('raster', pattern="landuse_2035_*")[current_mapset]
# we limit our computation to first 5 so that we don't wait too long
landuse_maps = landuse_maps[:5]
for landuse in landuse_maps:
    result = forest_fragmentation(landuse)
    print result
Forest fragmentation run in parallel
Now we will do the same, but run it in parallel. We will use Python multiprocessing package. We have to make couple adjustments to the previous code, for example generate intermediate maps with unique names. Don't run the code from Python shell, that won't work, but run it as Python script.
from multiprocessing import Pool
    forest_name = 'forest_2035_' + landuse
    fragmentation = 'fragment_' + landuse
    gscript.mapcalc("{forest} = if({landuse} >= 41 && {landuse} <= 43, 1, 0)".format(landuse=landuse, forest=forest_name))
    gscript.run_command('r.forestfrag', flags='a', input=forest_name, output=fragmentation, window=25)
    result = gscript.parse_command('r.stats', input=fragmentation, flags='cn', parse=(gscript.parse_key_val, {'sep': ' ', 'val_type': int}))
    gscript.run_command('g.remove', type='raster', name=[forest_name, fragmentation], flags='f')
    return dict(result)
if __name__ == '__main__':
    nprocs = 5
    pool = Pool(nprocs)
    p = pool.map_async(forest_fragmentation, landuse_maps)
    print p.get()
See also
