GDAL related problems
From GRASS-Wiki
Question
I got an error message like this one:
error while loading shared libraries: libgdal.so.1: cannot open shared object file: No such file or directory
Answer
This happens, when GDAL isn't installed properly. Possible solutions:
- Check if GDAL is installed (locate gdal). If not, install GDAL.
- Check if the directory which contains your libgdal is listed in your
/etc/ld.so.config
. If not, add the directory with a text editor to the file and runldconfig
as root. - Check if the right version of
libgdal
is installed. If there's a newer version, you can just create a symbolic link to the new version, e.g.
ln -s YOURINSTALLEDlibgdal.so.XXXX libgdal.so.1
