GRASS-QGIS relevant module list
From GRASS-Wiki
Jump to: navigation, search
GRASS modules available in the QGIS toolbox
List of GRASS modules relevant to QGIS
Status Templates
Present in QGIS:
Available
Present in QGIS but shouldn't be
Not present in QGIS - High Priority:
Missing - Hi
Not present in QGIS - Low Priority:
Missing - Lo
Not relevant to QGIS:
Not Relevant
  • "Status" is for modules currently present in qgis source code dir src/plugins/grass/modules-*/
  • Color coding indicates availability of module in the GRASS Toolbox
Database modules
db.*
Module Status Icon Comments
db.columns
Missing - Lo
Is this really useful? Seems better to use standard QGIS commands for this
db.connect
Available
Db-connect.png Db-connect-schema.png login; generic, schema, which
db.copy
Available
db.describe
Missing - Lo
db.drivers
Missing - Lo
db.dropcol
Missing - Lo
db.droptable
Missing - Lo
db.execute
Available
db.in.ogr
Available
db.login
Available
db.out.ogr
Available
db.select
Available
db.tables
Missing - Hi
To be realy useful, it should not be an additional command, but be added as an option to v.db.connect and similar commands (requires additional C++ coding)
db.test
Missing - Lo
General modules
g.*
Module Status Comments
g.access
Not Relevant
Not relevant
g.ask
Not Relevant
Not relevant
g.copy
Not Relevant
Not relevant
g.dirseps
Not Relevant
Not relevant
g.extension
Not Relevant
Not relevant
g.filename
Not Relevant
Not relevant
g.findetc
Not Relevant
Not relevant
g.findfile
Not Relevant
Not relevant
g.gisenv
Missing - Lo
g.gui
Not Relevant
Not relevant
g.list
Not Relevant
Handled in the Toolbox
g.manual
Available
g.mapset
Not Relevant
Not relevant
g.mapsets
Not Relevant
Not relevant
g.message
Not Relevant
Not relevant
g.mkfontcap
Not Relevant
Not relevant
g.mlist
Not Relevant
g.mremove
Not Relevant
g.parser
Not Relevant
Not relevant
g.pnmcomp
Not Relevant
Not relevant
g.proj
Available
generic, ascii, geo, print, proj
g.region
Available
save, zoom, multi-rast multi-vect
g.remove
Not Relevant
g.rename
Not Relevant
g.setproj
Missing - Hi
Better to add it as an option to the "Create new location" wizard (requires additional C++ coding)
g.tempfile
Not Relevant
Not relevant
g.transform
Not Relevant
g.version
Not Relevant
Not really relevant
Imagery modules
Essentially these are raster modules that deal with satellite or aerial photography.
i.*
i.atcorr
Missing - Lo
Seems too complicated to be added - help needed (comment: see tutorial)
i.cca
Missing - Lo
i.class
Not Relevant
i.cluster
Missing - Lo
i.fft
Available
common
i.fusion.brovey
Available
common
i.gensig
Missing - Lo
i.gensigset
Missing - Lo
i.group
Missing - Lo
i.his.rgb
Available
common
i.ifft
Available
common
i.image.mosaic
Available
common
i.in.spotvgt
Available
i.landsat.rgb
Available
common
i.maxlik
Missing - Lo
i.oif
Available
common
i.ortho.photo
Not Relevant
Not possible
i.pca
Missing - Lo
i.points
Not Relevant
Not possible
i.rectify
Not Relevant
i.rgb.his
Available
common
i.smap
Missing - Lo
i.spectral
Not Relevant
i.target
Missing - Lo
i.tasscap
Available
common x3
i.vpoints
Not Relevant
Not possible
i.zc
Available
common
Miscellaneous modules
m.*
m.cogo
Available
common
m.proj
Available
common
Paint modules
These have been abandoned in GRASS 6.
p.*
p.out.vrml
Not Relevant
old & renamed; not for QGIS
PostScript modules
ps.*
ps.map
Not Relevant
QGIS has its own map composer, so this probably isn't needed.
Raster modules
r.*
r.average
Available
common
r.basins.fill
Available
common
r.bilinear
Available
modules-6.4 Please use "r.resamp.interp" instead.
r.bitpattern
Available
common
r.blend
Available
common
r.buffer
Available
common
r.carve
Available
common
r.category
Available
common
r.cats
Not Relevant
Wrapper script for backwards compatibility.
r.circle
Available
common
r.clump
Available
common
r.coin
Available
common
r.colors
Available
common x4, generic, rast, rules, table
r.colors.stddev
Available
modules-6.4
r.composite
Available
common
r.compress
Available
common
r.contour
Available
common x2
r.cost
Available
common
r.covar
Available
common
r.cross
Available
common
r.describe
Available
common
r.digit
Not Relevant
Not possible
r.distance
Available
r.drain
Available
common
r.external
Available
modules-6.4 x3
r.fill.dir
Available
common
r.fillnulls
Available
common
r.flow
Missing - Lo
r.grow
Available
6.4/common
r.grow.distance
Available
r.gwflow
Missing - Lo
ground water flow modeling
r.his
Available
common
r.horizon
Missing - Lo
r.import
Missing - Hi
New since Community sprint in Como as a modified version of r.in.proj
r.in.arc
Available
common
r.in.ascii
Available
common
r.in.aster
Available
common
r.in.bin
Available
common
r.in.gdal
Available
common x4, generic, loc, qgis.loc, qgis
r.in.gridatb
Available
common
r.in.mat
Available
common
r.in.poly
Available
common
r.in.srtm
Available
common
r.in.wms
Available
common, somewhat brittle
r.in.xyz
Available
common
r.info
Not Relevant
r.kappa
Available
common
r.lake
Available
common x3, generic, seed, xy
r.le.setup
Missing - Hi
Creates configuration for r.le.* analysis modules. Requires a dedicated GUI.
r.le.patch
Missing - Hi
r.le.pixel
Missing - Hi
r.le.trace
Missing - Hi
r.li.setup
Missing - Hi
Creates configuration file for r.li.* analysis modules. Requires a dedicated GUI.
r.li.cwed
Missing - Hi
Done, but needs r.li.setup.
r.li.dominance
Missing - Hi
r.li.edgedensity
Missing - Hi
r.li.mpa
Missing - Hi
r.li.mps
Missing - Hi
r.li.padcv
Missing - Hi
r.li.padrange
Missing - Hi
r.li.padsd
Missing - Hi
r.li.patchdensity
Missing - Hi
r.li.patchnum
Missing - Hi
r.li.richness
Missing - Hi
r.li.shannon
Missing - Hi
r.li.shape
Missing - Hi
r.li.simpson
Missing - Hi
r.los
Available
common
r.mapcalc
Available
common
r.mapcalculator
Available
common, gui wrapper (need both?)
r.mask
Available
common
r.median
Available
common
r.mfilter
Available
common
r.mfilter.fp
Available
r.mode
Available
common
r.neighbors
Available
common
r.null
Available
common x4, null, to, val, r.to.null?
r.out.arc
Available
common
r.out.ascii
Available
common
r.out.bin
Available
r.out.gdal
Available
common x2 generic, GeoTiff
r.out.gdal.sh
Missing - Lo
old full map extent version
r.out.gridatb
Available
common
r.out.mat
Available
common
r.out.mpeg
Available
common
Available
common, important once transparency and Worldfile gets backported from 6.5svn
(for OpenLayers/KML tile source)
r.out.pov
Available
common POVray
r.out.ppm
Available
common
r.out.ppm3
Available
common
r.out.tiff
Available
common, visual RGB output, not data values (use r.out.gdal for that)
r.out.vrml
Available
common
r.out.vtk
Available
common
r.out.xyz
Available
common
r.param.scale
Available
common
r.patch
Available
common
r.plane
Available
common
r.profile
Missing - Lo
Python plugin available to find transect profile
r.proj
Available
common
r.quant
Available
common
r.quantile
Missing - Lo
r.random
Available
r.random.cells
Available
common
r.random.surface
Missing - Lo
r.reclass
Available
common x2, generic, file
r.reclass.area
Available
common x3, generic, greater, lesser
r.recode
Available
common
r.region
Available
Oversold?, common x6, generic, rast, vect, region, edge, alignTo
r.regression.line
Available
common
r.report
Available
common
r.resamp.interp
Available
common
r.resamp.rst
Available
common
r.resamp.stats
Available
common
r.resample
Available
common
r.rescale
Available
common
r.rescale.eq
Missing - Lo
r.ros
Missing - Lo
r.series
Available
common
r.shaded.relief
Available
common
r.sim.sediment
Missing - Lo
r.sim.water
Missing - Lo
r.slope.aspect
Available
common x2, slope, aspect, but not others
r.spread
Missing - Lo
r.spreadpath
Missing - Lo
r.statistics
Available
common
r.stats
Missing - Lo
r.sum
Available
common
r.sun
Missing - Hi
r.sunmask
Available
common x2, date_time, position
r.support
Available
common
r.support.stats
Available
common, maybe not needed
r.surf.area
Available
common
r.surf.contour
Available
common
r.surf.fractal
Available
6.3/6.4
r.surf.gauss
Available
common
r.surf.idw
Available
common, faster
r.surf.idw2
Available
common, supports floating point
r.surf.random
Available
common
r.terraflow
Missing - Lo
r.terraflow.short
Not Relevant
Not needed
r.texture
Available
common x2, generic, bis
r.thin
Available
common
r.tileset
Not Relevant
r.timestamp
Not Relevant
r.to.rast3
Missing - Lo
r.to.rast3elev
Missing - Lo
r.to.vect
Available
common x3, point, line, area
r.topidx
Available
common
r.topmodel
Missing - Lo
r.transect
Available
common
r.univar
Available
common
r.univar.sh
Not Relevant
Not needed
r.volume
Available
common
r.walk
Available
r.water.outlet
Available
common
r.watershed
Available
common
r.what
Not Relevant
Handled in the QGIS GUI
r.what.color
Not Relevant
3D raster modules
r3.*
r3.cross.rast
Missing - Lo
r3.gwflow
Missing - Lo
r3.in.ascii
Missing - Lo
r3.in.v5d
Missing - Lo
r3.info
Missing - Lo
r3.mapcalc
Missing - Lo
r3.mapcalculator
Missing - Lo
r3.mask
Missing - Lo
r3.mkdspf
Missing - Lo
r3.null
Missing - Lo
r3.out.ascii
Missing - Lo
r3.out.v5d
Missing - Lo
r3.out.vtk
Missing - Lo
r3.stats
Missing - Lo
r3.timestamp
Missing - Lo
r3.to.rast
Missing - Lo
r3.univar
Missing - Lo
Vector modules
v.*
v.buffer
Available
6.3/6.4, https://trac.osgeo.org/grass/ticket/994
v.build
Available
see specific modules
v.build.all
Available
common
v.build.polylines
Available
common
v.category
Available
common x4, add, del, sum, change
v.centroids
Available
common
v.class
Missing - Lo
Fuctionality supplied in QGIS Vector symbology
v.clean
Available
common x13
v.colors
Not Relevant
v.convert
Not Relevant
For loading in old GRASS 4/5 vector data format. Not needed by QGIS.
v.convert.all
Not Relevant
v.db.addcol
Available
Table-field-create.png common
v.db.addtable
Available
Table-create.png common
v.db.connect
Available
Db-connect.png common, v.db.sconnect? v.db.what.connect?
v.db.dropcol
Available
Table-field-delete.png modules-6.4
v.db.droptable
Available
Table-delete.png common
v.db.join
Available
common
v.db.reconnect.all
Available
common
v.db.renamecol
Available
common
v.db.select
Available
6.3/6.4 x2
v.db.univar
Available
common
v.db.update
Available
common x4, const, op, op query, query
v.delaunay
Available
common x2, line, area
v.digit
Not Relevant
Not possible
v.dissolve
Available
common
v.distance
Available
common
v.drape
Available
common
v.edit
Missing - Hi
Requires an ad hoc GUI (more C++ coding)
v.external
Missing - Lo
v.extract
Available
common, list, where
v.extrude
Missing - Lo
v.generalize
Available
common, complicated
v.hull
Available
common
v.import
Missing - Hi
New since Community sprint in Como as a modified version of v.in.proj
v.in.ascii
Available
Added in r14546
v.in.db
Available
common
v.in.dxf
Available
common x2, generic, multi
v.in.e00
Available
common
v.in.garmin
Available
common, only for old serial models
v.in.geonames
Available
modules-6.4
v.in.gns
Available
modules-6.4
v.in.gpsbabel
Available
common
v.in.lines
Available
Only in 6.5svn, new wrapper script around v.in.mapgen with more obvious name
v.in.mapgen
Available
common
v.in.ogr
Available
common x7
v.in.region
Available
common
v.in.sites
Not Relevant
v.in.sites.all
Not Relevant
v.in.wfs
Missing - Hi
Requires curl (not always available); errors with some servers
v.info
Not Relevant
Functionality supplied in Toolbox
v.kcv
Available
common
v.kernel
Available
common
v.krige.py
Missing - Hi
Available only from GRASS 6.5
v.label
Not Relevant
Functionality supplied in QGIS GUI
v.label.sa
Not Relevant
v.lidar.correction
Missing - Lo
v.lidar.edgedetection
Missing - Lo
v.lidar.growing
Missing - Lo
v.lrs.create
Missing - Lo
Python plugin for Linear Referencing available
v.lrs.label
Missing - Lo
v.lrs.segment
Missing - Lo
v.lrs.where
Missing - Lo
v.mkgrid
Available
common, by region (by coord is a custom graticule creator)
v.neighbors
Available
common
v.net
Available
common
v.net.nodes
Available
v.net.alloc
Available
common
v.net.allpairs
Missing - Lo
v.net.bridge
Missing - Lo
v.net.centrality
Missing - Lo
v.net.components
Missing - Lo
v.net.connectivity
Missing - Lo
v.net.distance
Missing - Lo
v.net.flow
Missing - Lo
v.net.iso
Available
common
v.net.path
Available
common
v.net.salesman
Available
common
v.net.spanningtree
Missing - Lo
v.net.steiner
Available
common
v.net.timetable
Missing - Lo
v.net.visibility
Available
common
v.normal
Missing - Lo
common
v.out.ascii
Available
common
v.out.dxf
Available
common
v.out.gpsbabel
Missing - Lo
v.out.ogr
Available
6.3/6.4/common x4, shapefile, generic, gml, mapinfo; 6.x: PostgreSQL
v.out.pov
Available
common
v.out.svg
Available
common
v.out.vtk
Available
common
v.outlier
Available
common
v.overlay
Available
common x4, and, or, not, xor
v.parallel
Available
common
v.patch
Available
common
v.perturb
Available
common
v.proj
Available
common
v.qcount
Missing - Lo
v.random
Available
common
v.rast.stats
Available
common
v.reclass
Available
common x2, attr, file
v.report
Available
common
v.sample
Available
common
v.segment
Available
common
v.select
Available
common, v.select.overlap
v.split
Available
common
v.support
Available
common
v.surf.bspline
Available
common
v.surf.idw
Available
common
v.surf.rst
Available
common
v.to.3d
Missing - Lo
v.to.db
Available
6.3/6.4
v.to.points
Available
common
v.to.rast
Available
common x2, attr, constant
v.to.rast3
Missing - Lo
v.transform
Available
common
v.type
Available
common x4, b2l, l2b, c2p, p2c
v.univar
Available
common
v.univar.sh
Not Relevant
old, not needed
v.vol.rst
Missing - Lo
v.voronoi
Available
common x2, line, area; https://trac.osgeo.org/grass/ticket/957
v.what
Not Relevant
QGIS GUI supplies query at location function
v.what.rast
Available
common
v.what.vect
Available
common
GUI and command modules
GUI modules
gis.m
Not Relevant
Not relevant
nviz
Available
common
shell
Available
common
xganim
Missing - Lo
Display modules
d.*
None of the display modules will be relevant. Display functionality is handled in the QGIS GUI.
