GRASS Digitizing tool
From GRASS-Wiki
Jump to: navigation, search
GUI vector digitizer
New digitizer
Quick overview:
  • Editing of vector objects:
    • Add, Break, Copy, Connect, Convert Type, Delete, Flip direction, Merge, Move, Select lines by query, Snap, Split
  • Cats:
    • Copy, Delete, Z-Bulk Labeling
  • Vertex:
    • Insert, Delete, Move
Old digitizer
  • TCL/TK-based old fashioned v.digit module
  • no longer maintained
Command Line (CLI) vector digitizer
See manual page of v.edit.
Raster digitizer
The r.in.poly ASCII format is almost the same as the standard vector ASCII format. So the new digitizer should be able to output for both, and then we have a replacement for r.digit too!
