GRASS and C++
From GRASS-Wiki
Jump to: navigation, search
(page to be expanded)
Calling GRASS library functionality in C++
For working examples, see:
I/O:
Raster data processing
Image processing
Visualization:
Notes
C++ code that use C shared libraries needs to specify this fact to the compiler. This can be defined with the extern "C" keyword, in this way:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
The C++ compiler will understand that the functions defined in gis.h are coded in C. If it is not specified the linking step will throw an error stating that the symbols for the C functions were not found in the shared library. Without the 'extern "C" ...' qualification, C++ assumes that functions have C++ linkage, meaning that the parameter types are embedded in the symbol name (C++ allows function overloading, where multiple functions can have the same name provided that they have different parameter types).
See also
