GRASS and Shell
From GRASS-Wiki
This page contains information about GRASS GIS' own shell setup and use.
For information about scripting for GRASS, please refer to the page Shell scripting.
Automated batch jobs: Setting the GRASS environmental variables
Main article: Working with GRASS without starting it explicitly
This section applies to jobs which shall set the entire GRASS environment. You have to set a couple of variables to enable GRASS command to run from outside GRASS:
   # Example in bash shell syntax:
   # path to GRASS binaries and libraries:
   export GISBASE=/usr/lib64/grass78
   export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
   export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GISBASE/lib
   # set PYTHONPATH to include the GRASS Python lib
   if [ ! "$PYTHONPATH" ] ; then
      PYTHONPATH="$GISBASE/etc/python"
   else
      PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
   fi
   export PYTHONPATH
   # use process ID (PID) as lock file number:
   export GIS_LOCK=$$
   # settings for graphical output to PNG file (optional)
   export GRASS_PNGFILE=/tmp/grass6output.png
   export GRASS_TRUECOLOR=TRUE
   export GRASS_WIDTH=900
   export GRASS_HEIGHT=1200
   export GRASS_PNG_COMPRESSION=1
   export GRASS_MESSAGE_FORMAT=plain
Define a GRASS session with the last used GISDBASE, LOCATION_NAME, and MAPSET
   # path to GRASS settings file
   export GISRC=$HOME/.grassrc7
Define a GRASS session with a different GISDBASE, LOCATION_NAME, and/or MAPSET
   export GISRC=/tmp/grass7-${USER}-$GIS_LOCK/gisrc
   # remove any leftover files/folder
   rm -fr /tmp/grass7-${USER}-$GIS_LOCK
   mkdir /tmp/grass7-${USER}-$GIS_LOCK
   export TMPDIR="/tmp/grass7-${USER}-$GIS_LOCK"
   # set GISDBASE, LOCATION_NAME, and/or MAPSET
   echo "GISDBASE: /path/to/some/grassdata" >>$GISRC
   echo "LOCATION_NAME: some_location" >>$GISRC
   echo "MAPSET: some_mapset" >>$GISRC
   # start in text mode
   echo "GRASS_GUI: text" >>$GISRC
The following three settings are only recommended if you will be calling the script from another program - e.g. a PHP web page using system() or exec()
   export HOME=/var/www
   export USER=www-data
   export GROUP=www-data
Now you can test:
   # this should print the GRASS version used:
   g.version
   # check GISDBASE, LOCATION_NAME, and MAPSET
   g.gisenv
   # other calculations go here ...
If this works, you can launch other GRASS commands. The approach works within Shell scripts and also in the command line terminal.
When done, you should cleanup internal tmp files like this:
   # run GRASS' cleanup routine
   $GISBASE/etc/clean_temp
   # remove session tmp directory:
   rm -rf /tmp/grass7-${USER}-$GIS_LOCK
Changing the prompt:
   PS1_BACKUP="$PS1"
   export PS1="GRASS 6> "
Once you are done, you can set it back (see also next hint about unsetting variables):
   export PS1="$PS1_BACKUP"
Unsetting variables after usage:
   Using the "unset VARNAME" command you get rid of it:
   unset GISBASE
   unset GISRC
Example
Parallel GRASS jobs
See Parallel GRASS jobs for Grid Engine, PBS etc.
GRASS Batch jobs
Since GRASS GIS 6.4, there is an alternative method to easily run jobs in GRASS from a collection of commands in a shell script file. Just define the environmental variable GRASS_BATCH_JOB with the shell script file containing GRASS (or whatever) commands, preferably with full path. Then launch GRASS and it will be executed. It is best to launch GRASS in -text mode and to provide gisdbase/location/mapset as parameters. The job script needs executable file permissions (chmod on Unix). In order to get readable percentage output during the processing (0..2..4... 100%), we set the environment variable GRASS_MESSAGE_FORMAT to "plain":
Example:
#### 1) PREPARATION
# First we generate a script which contains the command(s) to be executed:
# for convenience, we save the file in our HOME directory
## You may use also a text editor for this, here we use the "echo" shell command
echo "export GRASS_MESSAGE_FORMAT=plain
# set computational region, here: UTM32N coordinates
g.region n=4900000 s=4800000 w=700000 e=800000 res=100
v.random mymap3000 n=3000
v.out.ogr input=mymap3000 output=mymap3000.shp" > $HOME/my_grassjob.sh
# verify the content of the file
cat $HOME/my_grassjob.sh
# make it user executable (this is important, use 'chmod' or via file manager)
chmod u+x $HOME/my_grassjob.sh
# create a directory (may be elsewhere) to hold the location used for processing
mkdir -p $HOME/grassdata
# create new temporary location for the job, exit after creation of this location
grass78 -c epsg:32632 $HOME/grassdata/mytemploc_utm32n -e
#### 2) USING THE BATCH JOB
# define job file as environmental variable
export GRASS_BATCH_JOB="$HOME/my_grassjob.sh"
# now we can use this new location and run the job defined via GRASS_BATCH_JOB
grass78 $HOME/grassdata/mytemploc_utm32n/PERMANENT
#### 3) CLEANUP
# switch back to interactive mode, for the next GRASS GIS session
unset GRASS_BATCH_JOB
# delete temporary location (consider to export results first in your batch job)
rm -rf $HOME/grassdata/mytemploc_utm32n
# Now you can use the resulting SHAPE file "mymap3000.shp" elsewhere.
The grass78 command starts GRASS in the given mapset, executes the contents of the job file and leaves GRASS. Since the normal startup/closure is used, all internal tmp files are properly removed.
Note: The $HOME variable (or the ~ shortcut) cannot be used in the batch job itself since the variables are not available here.
Example
Unattended execution
  • GNU_Screen is another extremely valuable tool if you need to detatch and leave long-running processes unattended. It is well worth your time to learn how to use it if you run scripts on remote systems. There are many good tutorials on the web.
Usage:
Run "screen" in the terminal. You will reach again the command line but now in screen mode. Now start GRASS.
- To disconnect from the session press Control-A, Control-D.
- To list your screens type "screen -ls" (to find it back)
- To reconnect with a disconnected screen run "screen -r [identifier]" (the "identifier" you need only if you have several screens running)
Enjoy.
  • Along with the "nohup" (no hang-up) command you can login to your machine, launch the job and leave the machine again.
The process will continue after you logged off when you start it with nohup:
       nohup grass64 ~/grassdata/spearfish60/neteler/ &
Receive a notification when finished
Maybe put email notification at the end of 'my_grassjob.sh' using the "mail" or the "mutt" program, for example like this:
       echo "Finished at `date`" > /tmp/done.txt && \
       EDITOR=touch mutt -s "Job done" \
       me@mydomain.org < /tmp/done.txt && rm -f /tmp/done.txt
or like this:
       mail -s "GRASS job $0 finished" me@mydomain.org <<EOF
         GRASS GIS has finished the batch job $0
       EOF
or simply like this:
       echo "GRASS GIS has finished the batch job $0" | mail -s "GRASS job finished" me@mydomain.org
Stupid pet tricks (don't use them!)
Note: This is highly discouraged. Keep fingers off from manually modifying the content of a GRASS GIS mapset (at least don't complain if you break things).
;Quick cd to the MAPSET directory To make a quick little function called 'g.cd' to change into the mapset dir, add this to ~/.grass.bashrc:
g.cd()
  MAPSET=`g.gisenv get=MAPSET`
  LOCATION_NAME=`g.gisenv get=LOCATION_NAME`
  GISDBASE=`g.gisenv get=GISDBASE`
  LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
  cd "$LOCATION/$1"
With that you can also do like: "g.cd colr/" to get to the color tables directory, or "g.cd .." to get to the LOCATION directory.
Another method would be
  alias g.home='cd `dirname "$HISTFILE"`'
Simpler command completion from command history
Add this to a file called ~/.inputrc in your home dir:
set prefer-visible-bell
# -------- Bind page up/down wih history search ---------
"\e[5~": history-search-backward
"\e[6~": history-search-forward
Then you can type a bit of a command and use PgUp and PgDn to cycle through the command history which matches in a way less clumsy that Ctrl-r. Also it tells to make the shell flash on alarm instead of sending a beep to the speaker (making tab-completion compatible with your office mates).
See also
Generic Shell script tutorials:
GRASS Shell script tutorials:
Misc:
