Image destriping
From GRASS-Wiki
Image destriping with Fast Fourier Transform (FFT)
In some image maps, artifacts (stripes) are visible. These can be reduced with FFT filtering (i.fft).
First we take a look at the original tile (screenshot upper right map):
# set computational region to GDEM map:
g.region rast=imagemap -p
d.mon x0
d.rast imagemap
Then we perform Fast Fourier Transform (FFT; screenshot upper left map):
i.fft in=imagemap real=imagemap_real imag=imagemap_imag
d.mon x1
d.rast imagemap_imag
d.rast imagemap_real
Create a MASK in order to remove noise (screenshot upper left map):
# digitize filter mask to reduce noise
r.digit filter #not working in Grass v7
d.rast filter
r.mask -i filter
Inverse FFT to get filtered GDEM back (screenshot lower left map):
i.ifft real=imagemap_real imag=imagemap_imag output=imagemap_filtered
r.mask -r
d.mon x2
d.rast imagemap_filtered
r.colors imagemap_filtered color=elevation
Calculate the differences (screenshot lower right diagram):
# validate with differences map:
r.mapcalc "diff = imagemap - imagemap_filtered"
r.colors diff color=differences
d.mon x3
d.rast.leg diff
# done
Workflow of image destriping with FFT
Note: If the MASK is made larger (more to the center), more aggressive destriping occurs.
See also
