Talk:GRASS Community Meeting Prague 2023
From GRASS-Wiki
Quick links: Meeting page | Reports | Sponsors | Press release
Tasks for participants
  • Create section for you in the Reports section.
  • List all the things you are working on in the section. Update the list each day. Include things you work on with other people.
  • Link the GRASS Community Meeting Prague 2023 project on GitHub to each PR or issue you are working on or plan to be working on.
  • If you are or will be working on an issue or on a PR which is not originally submitted by you, assign yourself to the issue or PR. (You can unassign yourself later if you change your mind.)
Planning and organizing
  • Initial planning: Veronica Andreo, Martin Landa, Vaclav Petras, Helmut Kudrnovsky, Anna Petrasova, Huidae Cho, Markus Neteler, Helena Mitasova, Micha Silver, Linda Kladivova
  • Funding acquisition: Veronica Andreo, Markus Neteler, Vaclav Petras, Anna Petrasova, Huidae Cho, Luca Delucchi, Venkatesh Raghavan
  • Budget: Vaclav Petras, Markus Neteler, Veronica Andreo
  • Venue and local organizing: Martin Landa, helpers: Ondrej Pesek, Vaclav Petras
  • T-shirts, hoodies, stickers: Vaclav Petras, Anna Petrasova
  • Promotion, invitations, and social media: Caitlin Haedrich, Veronica Andreo, Vaclav Petras
  • Wiki page: Martin Landa, Markus Neteler, Vaclav Petras, Veronica Andreo
  • Virtual meeting organizing: Veronica Andreo
  • Photography: Caitlin Haedrich, Maris Nartiss
Reports
Caitlin Haedrich
Vaclav Petras
See also June activity log on GitHub.
Anna Petrasova
Maris Nartiss
  • i.svm.* cleanup and preparation for a review
  • A conceptual proposal for a new start up screen
  • Initial version of imagery signature management module i.signatures
  • Remove obsolete parts of locale README file
  • Extract translatable messages also from C++ files
  • Improve parser library documentation
Micha Silver
Working on a new GRASS addon: r.optram the repo on github
02/06: Initialize main file r.optram.py
includes these functions:
  1. getImgList() - get list of IMG_FILEs in a Sentinel 2 SAFE Directory
  2. cropToAOI() - Crop the images to the Area of Interest
  3. prepareSTR() - Convert SWIR to the SWIR Transformed Reflectance
  4. prepareVI() - Prepare the (user chosen) vegetation index
03/06:
  1. Split to three modules: r.optram.preprocess, r.optram, r.optram.soilmoisture
  2. new function: prepareTrapezoid() - to get wet-dry regression lines and slope, intercept values
04/06
  1. prepareTrapezoid() function completed.
  2. (Joined video conf with Roger Bivand on R-GRASS integration.)
05/06 Initialize third file/function: r.optram.soilmoisture.py
  1. createSoilMoisture() - creates new GRASS raster for a single date
  2. Add documentation to modules
  3. (joined video conf with Nyall Dawson)
TODO list:
  • Read Sentinel cloud mask and mask out cloud pixels in r.optram.preprocess
  • large study areas or very long time series will create a big numpy table of variables (vegetation index and STR). A possible solution:
  1. Determine some "reasonable" maximum size for the numpy table, depending on computer resources.
  2. Extract a subset of pixels from each raster in the time series, such that the total table pixel values will not exceed that maximum
  3. The size of the subset will be set by ("reasonable" max / number of rasters in time series)
  4. Allow user to determine "reasonable" max.
  • Currently this addon consists of three sub-modules. Consider to consolidate to one.
  • Improve HTML documentation
Luís de Sousa
Work on GRASS add-on r.mblend
  • Module is still maintained and fully functional in GRASS 8.2 (now included in the GRASS global add-ons repository)
  • However was not longer producing correct results due to new behaviour in v.what.rast
  • Solution identified, using inner buffer to interpolation area (PR #910)
  • A small unit test suite was developed (PR #911)
Documentation
  • Expanded instructions on Pre-commit (PR #3006)
  • Mini guidelines on unit tests for add-ons (PR #916)
Aaron Saw Min Sern
  • Fix bug to complete r.univar parallelization. PR
  • Investigate CMake progress in Windows. There still needs to be source code fixes to be port over to MSVC:
    • Variable Length Arrays (VLA) is not supported in MSVC (is optional in C99).
    • DLL export directives are required across dynamic library boundaries.
  • Coordinate CMake PR, fix some bugs and make some progress (got a full build on UNIX environment). [1]
  • r.mapcalc removed previous threading artifacts that are ineffective.
  • r.mapcalc refactored global variables in preparation for threading work. (PR to come)
Martin Landa
  • Check min required wx version when starting wxgui PR #2990
  • Graphical modeler: avoid overlapping module parameters PR #2991
  • Show ModelRelation in white on dark mode PR #2997
  • Add OSGeo4W workflow to compile Addons PR #912
  • Integrate Grapical Modeler into single window layout PR #3003
  • Graphical Modeler: fix command parsing in "add tool" dialog PR #3022
  • Describe required updates for new version for winGRASS #2406
Markus Neteler
  • backport of "HTML header charset changed from ISO-8859-1 to UTF-8" PR #2547 to GRASS GIS 8.2.1 (fixing r.forcircular manual encoding bug)
  • improve "Update alpine Docker tag to v3.18 PR #2953
  • backport of Alpine Dockerfile improvements
  • discussion about "location/mapset" vs "project/..." terminology
  • initial QGIS-GRASS update discussion: update of provider to GRASS GIS 8
  • Google Photo album feeds
  • Use of pre-commit (recommended to all devs!)
  • Participate in a two-hour meeting with Nyall Dawson (QGIS) and the GRASS Community about interfacing GRASS from QGIS
  • GRASS GIS docker images: moved from "mundialis organization" to https://hub.docker.com/r/osgeo/grass-gis (together with Carmen)
    • Once the CI completes the images will show up there. Update of grass-web page is in the works.
  • Update of release procedure documents (together with Vaclav)
  • GRASS GIS manual pages: re-styling and conversion of all pages to markdown:
First attempt to convert the manual to Markdown/mkdocs
  • Discuss about a 4th edition of "Open Source GIS: A GRASS GIS Approach"
  • GRASS GIS addons overview generator for entire GitHub (and more?) based on tag "grass-gis-addons"
  • User message translation: Easy machine translation of messages in OSGeo-Weblate with DeepL API
    • my tests with DeepL show that the quality is very good; average translation time of a user message shrinks to 15 seconds
    • note: one needs to login to Weblate to see the "Automatic suggestion" button (using the OSGeo-ID)
Helmut Kudrnovsky
  • Participated in a two-hour meeting with Roger, Floris, Vaclav, Anna, Micha, ..... about rgrass development
Ondřej Pešek
Floris Vanderhaeghe
Vero Andreo
  • Participated in the discussion about renaming locations to projects
  • Call with Paulo on diverse topics, r.niche.similarity PR revision and merge
  • Participated in a two-hour meeting with Roger, Floris, Vaclav, Anna, Helmut, Micha, ..... about rgrass development
  • Worked on GRASS Website:
    • Apply fixes and merge the DOI and first draft of sponsoring tiers PRs
    • Beautify tables and content of sponsoring page #368
    • New menu and submenus (some reordered), please comment #369
    • Created a news item about rgrass7 retirement with text snippet contributed by Roger Bivand #370
  • Other minor revisions
Ideas for the meeting agenda:
  • All - think about GRASS GIS mission and vision: Where do we want to be as a project in 5 years time? What do we want to have? What do we want to be?
  • Participate in discussions about GRASS interfaces with QGIS and R (rgrass)
  • Discuss sponsoring
  • Student grant for (python) documentation?
  • Discuss about wiki clean-up/update (Anna was working on a list of pages)
  • Website enhancements: complete open PR's, meet Daniel Torres, new support item in main menu
  • Discuss State of GRASS presentation for FOSS4G 2023
  • i.landsat if time permits
Carmen Tawalika
  • Move official GRASS GIS Dockerimage from mundialis/grass-py3-pdal to osgeo/grass-gis
    • PR for CI in #3001
    • Update website in #371
    • Update reference in actinia-docker repository in #41
  • Update alpine version in Dockerimage to v3.18
    • Local testing for #2953
    • Update of various images for actinia #38, #39 and #442
  • Enhance actinia version info in #443, #444 and #40
  • Fix tests for actinia-parallel-plugin
Loïc Bartoletti
  • Rebased Markus PR and continuing migration to CMake
  • Fix a Crash on QGIS loading a raster generated with r.null
  • Fix a memory leak in lib/bitmap
  • Remove compatibility to GDAL < 2.2 #2995
  • Tests and reviews for #1034, #1889, #2930
  • Working on Cppcheck and SonarCloud WIP for GRASS build
  • Update URL to GRASS manual pages in QGIS #53372 and #53376
Discussion on interfacing GRASS from QGIS
Complete minutes are in the GitHub Discussion Meeting minutes on interfacing GRASS from QGIS #3047.
Discussion on using GRASS from R
  • Special guest: Roger Bivand (rgrass, ...)
  • Attended by 7+ participants
Complete minutes are in the GitHub Discussion Meeting minutes on interfacing GRASS from R #78.
What to do differently the next time
  • Use food delivery also for couple of evenings to allow for longer coding. (asked for by several participants)
  • Pay for more parallel CI jobs. (the queue was very long and too long for the release procedure)
