Talk:GRASS Community Sprint Como 2015
From GRASS-Wiki
Reports
Impressions from the GRASS GIS Community Sprint 2015: Como, Italy)
More photos at Twitter, FB, G+ ...
Overall
Individual reports
Martin Landa
v.external interactive input/layer
  • fix GRASS_VECTOR_TEMPORARY (r65677)
  • fix v.buffer -s/-c flags (r65710)
  • trac #2711
  • v.in.proj renamed to v.import and copied to trunk, integrated into wxGUI (see screenshot below)
Import and reproject vector data on the fly
Import and reproject vector data on the fly (check result)
Planned but not finished:
  • integrate r.in.proj and v.in.proj to trunk
  • work on PostGIS Topology support, see trac #2460, trac #2497
  • GRASS 7 support in pywps
  • trac #2386
  • implement v.clip
  • implement v.convert.g6
  • g.gui.datacatalog
Anna Petrasova
  • fixed digitizing attributes on MacOSX with wxPython 3 - r65606
  • fix trac #2386 in r65614 and fix manual page example (r65615)
  • test for r.horizon added (r65621), reorganized options in r65635
  • fix creating command in PyGRASS r65630 (to be backported)
  • fix listing temporal datasets in GUI in r65641
  • animation tool: put time label color and number of processes to settings, resizing window behavior improved
  • default dialog style changed to vertical on Linux
  • r.import interface change + test in progress
  • + Massimo Di Stefano: first stage of integration of Cesium virtual globe in Map Display
First steps in integration Cesium virtual globe in GRASS GIS 7
Ludmila Furtkevicova
  • r.flow manual: example added (r65680, r65681)
  • various manual wording tweaks
  • r.slope.aspect manual: example added (r65722, r65724)
Markus Neteler
Vaclav Petras
  • migrating tests to NC basic location (r65613)
  • supporting Ivan Mincik in Git synchronization for Travis CI
  • supporting Markus Neteler in Trac download links (needed for g.extension)
  • updating Python documentation (r65612)
  • test for g.extension (r65673)
  • refactoring and documentation of g.extension (r65676, r65688, r65711, r65762)
  • giving GRASS GIS contributing introduction to Ludmila Furtkevicova
  • supporting Annalisa Minelli in fixing r.agent/r.agent.aco compilation and source code layout
  • support for other sources of source code for g.extension (r65730, r65737, r65740, r65757, r65769)
    • downloading Trac ZIP files is used by default instead of Subversion checkout (r65769)
    • newly supported options:
      • ZIP or TAR family archive file locally or on the web:
        • g.extension r.example svnurl=https://trac.osgeo.org/.../r.example?format=zip
      • local directory on disk:
        • g.extension r.example svnurl=/local/directory/r.example/
      • simple URL to GitHub, GitLab, Bitbucket repositories (downloads a ZIP file):
        • g.extension r.example svnurl=github.com/johnsmith/r.example
      • simple URL to OSGeo Trac (downloads a ZIP file, requires download enabled in Trac):
        • g.extension r.example svnurl=trac.osgeo.org/.../r.example
    • only official repository supported on MS Windows (compilation is not possible)
    • local XML files cannot be properly updated as they are provided only in official repository
    • CRLF line endings are replaced by LF before compilation (advantageous for ZIPs from Trac and from ZIP providers using MS Windows)
Annalisa Minelli
Testing possible interactions between Gama-platform and GRASS trunk focusing on pre and post processing of data for the multi agent platform. Specifically:
Margherita Di Leo
Mainly working on documentation and cooking for the crew (together with Luca Delucchi) ;-)
Veronica Andreo
Luca Delucchi
Ivan Minčík
Overall Code Sprint page
OSGeo code sprint (one day): http://wiki.osgeo.org/wiki/FOSS4G-Europe_2015_Code_Sprint
Press release
[todo]
