Terrain analysis
From GRASS-Wiki
Terrain analysis in GRASS GIS
GRASS GIS offers an enormous range of methods and tools for terrain analysis.
(see also: Geomorphometry and Hydrological Sciences)
Accumulation
  • r.accumulate addon module: Calculates weighted flow accumulation, subwatersheds, stream networks, and longest flow paths using a flow direction map.
Analytical Hillshading
  • r.shaded.pca addon module: Creates relief shades from various directions and combines them into RGB composition
Aspect
See: r.slope.aspect: Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map
Basins
  • r.basin addon module: morphometric characterization of river basins
  • r.basin.fill: Generates watershed subbasins raster map
  • r.valley.bottom addon module: Calculation of Multi-resolution Valley Bottom Flatness (MrVBF) index
  • r.watershed: Determines watersheds
Catchment Area
  • r.catchment addon module: Creates a raster buffer of specified area around vector points using cost distances using r.walk
Channel Network Base Level
See list in Hydrological Sciences
Channel Network Distance
Closed Depressions
  • r.fill.dir: Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map
Contours
  • r.contour: Produces a vector map of specified contours from a raster map
Convergence Index
Curvatures
  • r.slope.aspect: Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map
Flooding
  • r.lake: Fills lake at given point to given level
Flow and lines
  • r.flow: Computes flow-lines, flow-path lengths, and flow-accumulation (contributing areas)
  • r.terraflow: Performs flow computation for massive grids
Fractal surfaces
  • r.surf.fractal: Creates a fractal surface of a given fractal dimension
Habitats and terrain
  • v.habitat.dem addon module: Calculates DEM derived characteristics of habitats
Landscape evolution
Local relief model
  • r.local.relief addon module: Creates a local relief model from elevation map
LS-Factor
  • r.watershed: Calculates hydrological parameters and RUSLE factors
Northerness, easterness
  • r.northerness.easterness addon module: Calculation of northerness, easterness and the interaction between northerness and slope
Random surfaces
  • r.random.surface: Generates random surface(s) with spatial dependence
  • r.surf.contour: Generates surface raster map from rasterized contours
  • r.surf.gauss: Generates a raster map using gaussian random number generator
  • r.surf.idw: Provides surface interpolation from raster point data by Inverse Distance Squared Weighting
  • r.surf.random: Produces a raster surface map of uniform random deviates with defined range
Shaded relief map
  • r.relief: Creates shaded relief map from an elevation map (DEM)
Slope
  • r.slope.direction addon module: Calculates slope following a direction raster
Stream channels
Surface roughness
  • r.roughness.vector addon module: Calculates surface roughness in a moving-window, as the orientation of vectors normal to surface planes.
Terrain classification
  • r.terrain.texture addon module: Unsupervised nested-means algorithm for terrain classification
Terrain forms (geomorphons)
  • r.geomorphon: Calculates geomorphons (terrain forms) and associated geometry using machine vision approach
Topographic Position Index
  • r.tpi addon module: Calculates the multiscale topographic position index
Topographic Ruggedness Index
  • r.tri addon module: Computes the Terrain Ruggedness Index
Topographic Wetness Index
See: r.topidx: Creates a topographic index (wetness index) raster map from an elevation raster map
Vector Ruggedness Measure
Watersheds
Valley Depth
Viewshed
  • r.viewshed: Computes the viewshed of a point on an elevation raster map
  • r.viewshed.cva addon module: Undertakes a "cumulative viewshed analysis" using a vector points map as input "viewing" locations, using r.viewshed to calculate the individual viewsheds
  • r.viewshed.exposure addon module: Visual exposure to defined exposure source
See also
