Tools for Python programming
From GRASS-Wiki
To help with finding broken code, unused variables and other problems, there are several tools available. Described tools are free and open source and usually widely available in GNU/Linux distribution repositories or through pip. They can be connected to some code editor or run separately from command line. Some editors integrate some of these tools. Generally, all tools need to be run from a GRASS session.
pep8 for checking of style
Checks the basic correctness and style of Python code according to PEP 8 -- Style Guide for Python Code.
pep8 lmgr/toolbars.py
Please see https://trac.osgeo.org/grass/wiki/Submitting/Python for GRASS GIS specific details.
Pylint static checker
Main article: Pylint rc file for GRASS
Pylint is a tool for static source code analysis. It provides wide range of analysis and is highly customizable. It is integrated to some Python editors.
cProfile profiling tool
cProfile is a Python profiling tool. It can be used directly in your Python source code or from the command line. The output can be processed by the gprof2dot tool which generates call graph in dot (depends on Graphviz is necessary to render the graph).
For Ubuntu, Graphviz and cProfile are available in repository (graphviz and python-profiler packages). gprof2dot tool needs to be installed through pip (sudo pip install gprof2dot).
# does the actual profiling
python -m cProfile -o output.pstats  my_python_script.py --various-my-script-parameters foo bar
# creates a callgraph with profiling info (filtered)
#!/bin/bash
# Usage:
# ./python-profile.sh your_python_script.py and its parameters
# need to run in the directory which contains profiled script
OUTFILE=$(basename $1 .py)_profile
python -m cProfile -o $OUTFILE.pstats $* \
&& gprof2dot -f pstats $OUTFILE.pstats > $OUTFILE.dot \
&& dot -Tpng -o $OUTFILE.png $OUTFILE.dot \
&& dot -Tpdf -o $OUTFILE.pdf $OUTFILE.dot
Pyreverse static checker
Needs to run in distribution directory.
Note that it shows only import and usage dependencies. Because of the Python dynamic typing it is not possible to find dependency on particular object interface when the object is not created but only passed to a function or object constructor.
cd dist.../etc/gui/wxpython
pyreverse -o pdf -p wxgui --only-classnames core/ gui_core/ lmgr/ mapdisp/
PyCharm IDE
PyCharm is a editor, or better to say IDE, for Python with large number of tools integrated into it.
  • GRASS GIS 7: e.g., GRASS 7.8.8 comes on MS Windows with a new BAT initialization 'python-grass78.bat' file which can be used for setting up the PyCharm environment.
  • GRASS GIS 8: e.g., GRASS 8.3.0 comes on MS Windows with a new BAT initialization 'python-grass83.bat' file which can be used for setting up the PyCharm environment.
Create a new PyCharm project (File -> New Project).
Go to 'Existing interpreter' section and click on '...'
Click on '...' in 'System Interpreter' section and choose 'C:\OSGeo4W64\bin\python-grass78.bat' file
Click on 'Create' in order to create a new PyCharm project
Add a new Python file into the created project by File -> New. See a sample Python script below. This script creates a new temporary GRASS location and prints the settings. Then, the temporary location is deleted.
import os
import tempfile
import shutil
import grass.script as gs
import grass.script.setup as gsetup
# create temporary location
dbase=tempfile.gettempdir()
location='demo'
gsetup.init(os.environ['GISBASE'], dbase, location, 'PERMANENT')
gs.create_location(dbase, location)
print(gs.gisenv())
# remove location
shutil.rmtree(os.path.join(dbase, location))
Go to Run -> Run and choose a script to run
Example of GRASS script run from PyCharm environment
Spyder editor
Spyder is a editor, or better to say IDE, for Python with large number of tools integrated into it. To get better results, you should run Spyder within a GRASS GIS session. It has an integrated pylint tool to verify the source code instantly for undefined or unused variables, wrong indentation and more.
  • Linux: many distributions provide "spyder" as a package for easy installation.
  • Windows: you may also install Spyder as part of WinPython
Important: Change the editor settings from 'tab' to '4 spaces' (according to the style guide at https://trac.osgeo.org/grass/wiki/Submitting/Python):
  • Menu Tools > Preferences > Editor > Advanced Settings: Indentation characters: 4 spaces
An ideal way how to run Spyder within a GRASS session ('.' can by replaced by any directory):
spyder -w . 2>/dev/null &
Eric Python IDE
"Eric is a full featured Python and Ruby editor and IDE, written in python":
Simple Python Editor in GRASS GIS
Simple Python editor with the interactive Python shell (console) in the background
Since GRASS GIS 7.2, there is an embedded editor for Python in GRASS GIS with basic set of editing features. It is aimed towards beginners and contains examples and templates. User scripts and newly developed GRASS GIS modules can be executed in the (command) Console tab directly from the editor.
