Updating GRASS Documentation
From GRASS-Wiki
Jump to: navigation, search
How-to for Updating GRASS Manual Pages
Overview
Module manual page:
Place the documentation in HTML format into '<module>.html', where <module> is the name of the module. E.g. if the module is named r.example, the documentation file should be named r.example.html.
The easiest way to do this is to study an existing HTML page (to get the page style, e.g. vector/v.to.db/v.to.db.html). With a few exceptions header and footer are NOT allowed. You can add figures (PNG format), the figure name prefix should be the module name. See raster/r.terraflow/r.terraflow.html for an example.
Note that the parameter information is auto-generated upon compilation. This is done by running module in a virtual session after compilation (see the output of 'make'). To subsequently verify the final HTML page, check the resulting HTML pages which will be stored with the name of the module.
The online WWW man pages will be updated every Saturday by SVN.
Instructions
This page will provide general step-by-step instructions for updating and improving GRASS manual pages. Feel free to update and improve this page as well! See also SUBMITTING_DOCS in the source code.
As an example, the vector program v.in.ascii will be used to illustrate the steps required to update its manual page. These steps can then be generalized for your case.
Getting the latest source
  • To begin, you must obtain the latest GRASS source code from the Subversion repositories. Detailed instructions on how to do so can be found here.
  • Once you have downloaded the SVN source code, open a terminal and change directory to where the source for a specific GRASS module is located - in this example, something like:
cd /your_svn_directory/grass6/vector/v.in.ascii
  • Open a text editor and make your edits to <module>.html. Do not use a "WYSYWIG" HTML editor on those files, but either a normal text editor or something which is designed for editing HTML source (e.g. [X]Emacs' html-mode or psgml-mode). Save your edits by overwriting the original <module>.html.
Help page sections
Please use the following section list as a guideline. The intent is to promote a unified user experience, not to limit the flow of information. If exceptions are needed, please use them sparingly. Minor sections (<H3>, etc) may be free-form, as required.
Auto-generated
Modules using the parser interface will have these sections automatically generated from 'g.module --html-description'
<h2>NAME</h2>
<h2>KEYWORDS</h2>
<h2>SYNOPSIS</h2>
Found in <module>.html
A number of major sections should be present in each help page.
* = Required
! = Suggested
. = Optional
In recommended order
* <h2>DESCRIPTION</h2>
! <h2>NOTE</h2>, <H2>NOTES</h2>
! <h2>EXAMPLE</h2>, <H2>EXAMPLES</h2>
. <h2>TODO</h2>
. <h2>BUGS</h2>
. <h2>REFERENCE</h2>, <H2>REFERENCES</h2>
* <h2>SEE ALSO</h2>
* <h2>AUTHOR</h2>, <h2>AUTHORS</h2>
Images
  • Images can also be inserted in the html help page. See v.voronoi for an example. Note that images won't show up in the Grass man pages (which are generated from the HTML), so they shouldn't be considered a substitute for an adequate textual description. Be sure to also send the image (preferably png format) along with your documentation patch.
PNG files are best for figures with solid chunks of a single color. They can get rather large for imagery. In those cases JPEGs are a better choice. In general JPEG is a lossy format so the image quality will not be as good.
To help keep the source distribution size small, try and keep the images small and the files under 50kb or so. Save PNGs at a compression setting of "9" with a minimal color pallet, you can also use tools like pngcrush or optipng to compress them further, e.g.:
Examples
For non trivial modules please provide an example of the command line usage. It is good to have this double as a mini-tutorial, so please use one of the sample datasets (Spearfish or the new North Carolina one) or common dataset such as NASA's WMS or SRTM data files.
Examples should be coded like this:
 <div class="code"><pre>
 v.to.db map=soils type=area option=area col=area_size unit=h
 </pre></div>
HTML codes
The g.html2man tool is used to generate man pages from the HTML help files.
  • The following html codes are understood to some extent by g.html2man (brackets removed): A, B, BLINK, BODY, BR, CODE, DD, DL, DT, EM, H2, H3, H4, HEAD, HEADER, HR, I, IMG, LI, OL, P, PRE, SUP, TABLE, TD, TH, TITLE, TR, UL.
  • Others may be added to g.html2man as required.
Creating and submitting a patch
Translations
See the main page GRASS manual translation.
Currently there is no framework yet for translating the full help ("man") pages (implementation wanted!).
There is good support for GRASS module, library, and GUI message translations though:
  • Translation support pages:
- GRASS messages translation
- GRASS Translation Glossary
- Project translation statistics
Idea: use an online translator such as AltaVista's Babelfish service or Google Translate.
The top part of the page (generated by `g.module --html-description`) is translated by the $LANG variable and <grass/glocale.h>, so we should not be attempting to automatically translate the option and modules names. The idea for a two part translation is to make a modified version of tools/mkhtml.sh which (if ./config'd --with-nls) loops through major languages and creates html pages like $GISBASE/docs/html/de/, $GISBASE/docs/html/es/,... but instead of just pasting the english <module>.html files to the bottom have it save those as g.module_descr_en.html in a common dir.
The translated help pages (generated with mkhtml_i18n.sh) would contain a lower frame which calls an online translation of the g.module_descr_en.html page from e.g. ibiblio.org/grass63/html_docs/en_descr/g.module_descr_en.html with the appropriate "lp=en_de" setting in the bablefish URL.
Examples of live whole-page translations for GRASS 6.4 help pages:
Ideas for a translation framework
The above idea really sucks IMHO. Better not to have translated documentation at all than babelfish. --Steko 13:12, 18 February 2008 (CET)
A true translation framework for translation of both interface and documentation would be structured like this:
A brief guide to valid HTML
While web browsers will happily accept invalid HTML, the tools used to convert HTML documentation to Unix manual pages won't. For that reason, please try to ensure that the documentation is valid HTML, not just whatever your browser accepts.
If you have OpenSP/OpenJade, you can validate an HTML file with e.g.:
nsgmls -s -c /usr/share/sgml/openjade-1.3.2/pubtext/HTML4.soc <filename>.html
[The program may be called nsgmls or onsgmls, and the exact location where the catalogues are installed will vary.]
This needs to be done on the completed HTML file in dist.<arch>/docs/html; the <module>.html files in the module directories won't normally validate, as they lack the header which is added by running the module with the --html-description.
The most common error is using block elements (e.g. <div>, <pre>, <p>) in contexts where only inline elements are allowed (e.g. <dt>).
The definitive reference of which elements are allowed where is the HTML 4.0 Transitional DTD
E.g. the definition:
<!ELEMENT DT - O (%inline;)* -- definition term -->
indicates that only inline elements are allowed inside DT, while e.g.:
<!ELEMENT DD - O (%flow;)* -- definition description -->
indicates that both block and inline elements are allowed inside DD.
If you don't want to read the DTD, here's a rough summary:
Entity classes:
	%StyleSheet	= <CSS stylesheet>
	%Script		= <JavaScript code>
	%html.content	= HEAD, BODY
	%head.content	= TITLE, ISINDEX, BASE
	%heading	= H1, H2, H3, H4, H5, H6
	%fontstyle	= TT, I, B, U, S, STRIKE, BIG, SMALL
	%phrase		= EM, STRONG, DFN, CODE, SAMP, KBD, VAR, CITE, ABBR,
			  ACRONYM
	%special	= A, IMG, APPLET, OBJECT, FONT, BASEFONT, BR, SCRIPT,
			  MAP, Q, SUB, SUP, SPAN, BDO, IFRAME
	%formctrl	= INPUT, SELECT, TEXTAREA, LABEL, BUTTON
	%list		= UL, OL,  DIR, MENU
	%head.misc	= SCRIPT, STYLE, META, LINK, OBJECT
	%pre.exclusion	= IMG, OBJECT, APPLET, BIG, SMALL, SUB, SUP,
			  FONT, BASEFONT
	%preformatted	= PRE
	%block		= P, DL, DIV, CENTER, NOSCRIPT, NOFRAMES,
			  BLOCKQUOTE, FORM, ISINDEX, HR, TABLE, FIELDSET,
			  ADDRESS, %heading, %list, %preformatted
	%inline		= #PCDATA, %fontstyle, %phrase, %special, %formctrl
	%flow		= %block, %inline
The immediate children permitted for each element are:
	A:		%inline
	ABBR:		%inline
	ACRONYM:	%inline
	ADDRESS:	%inline, P
	APPLET:		%flow, PARAM
	B:		%inline
	BDO:		%inline
	BIG:		%inline
	BLOCKQUOTE:	%flow
	BODY:		%flow, INS, DEL
	BUTTON:		%flow
	CAPTION:	%inline
	CENTER:		%flow
	CITE:		%inline
	CODE:		%inline
	COLGROUP:	COL
	DD:		%flow
	DEL:		%flow
	DFN:		%inline
	DIR:		LI
	DIV:		%flow
	DL:		DT, DD
	DT:		%inline
	EM:		%inline
	FIELDSET:	%flow, LEGEND
	FONT:		%inline
	FORM:		%flow
	FRAMESET:	FRAMESET, FRAME, NOFRAMES
	H1:		%inline
	H2:		%inline
	H3:		%inline
	H4:		%inline
	H5:		%inline
	H6:		%inline
	HEAD:		%head.content, %head.misc
	HTML:		%html.content
	I:		%inline
	IFRAME:		%flow
	INS:		%flow
	KBD:		%inline
	LABEL:		%inline
	LEGEND:		%inline
	LI:		%flow
	MAP:		%block, AREA
	MENU:		LI
	NOFRAMES:	%flow
	NOSCRIPT:	%flow
	OBJECT:		%flow, PARAM
	OL:		LI
	OPTGROUP:	OPTION
	OPTION:		#PCDATA
	P:		%inline
	PRE:		%inline
	Q:		%inline
	S:		%inline
	SAMP:		%inline
	SCRIPT:		%Script
	SELECT:		OPTGROUP, OPTION
	SMALL:		%inline
	SPAN:		%inline
	STRIKE:		%inline
	STRONG:		%inline
	STYLE:		%StyleSheet
	SUB:		%inline
	SUP:		%inline
	TABLE:		CAPTION, COL, COLGROUP, THEAD, TFOOT, TBODY
	TBODY:		TR
	TD:		%flow
	TEXTAREA:	#PCDATA
	TFOOT:		TR
	TH:		%flow
	THEAD:		TR
	TITLE:		#PCDATA
	TR:		TH, TD
	TT:		%inline
	U:		%inline
	UL:		LI
	VAR:		%inline
Some elements don't allow certain elements as descendents:
	A:		A
	BUTTON:		%formctrl, A, FORM, ISINDEX, FIELDSET, IFRAME
	DIR:		%block
	FORM:		FORM
	LABEL:		LABEL
	MENU:		%block
	PRE:		%pre.exclusion
	TITLE:		%head.misc
Notes:
  • The children of DIR/MENU are LI, which is a block element, but those LI can't contain block elements. UL/OL don't have this restriction.
  • DT cannot contain block elements, but DD can. This means that you can't use <div class="code"><pre> in a DT; use <span class="code"><tt> instead. DIV and PRE are block elements; SPAN and TT are inline.
  • TABLE cannot have TR as a child. But TBODY can have TR, and TBODY allows both the start and end tags to be omitted, so <table><tr>....</tr></table> is really just a shorthand for <table><tbody><tr>.... </tr></tbody></table>.
  • P cannot contain blocks. So <p>...<div> is actually shorthand for <p>...</p><div>. But <p>...<div>...</div>...</p> is an error, as the </p> doesn't match any open element (the <div> implicitly closed the original <p>, and P doesn't allow the start tag to be omitted).
  • HTML, HEAD, BODY, and TBODY allow the start tag to be omitted. With the exception of TBODY, this feature shouldn't be used (it's a nuisance to implement if the number of valid child tags is large).
See also
