WxGUI Map Swipe
From GRASS-Wiki
Introduction
The Map Swipe is a wxGUI application which allows GRASS users to interactively compare two raster maps of the same area by revealing different parts of the raster maps. It is useful e.g. for comparing raster maps from different time periods. See also the manual.
The Map Swipe is available in GRASS 7 from the menu
- File → Map Swipe
Implemented features:
- orientation of the swipe line can be changed (horizontal or vertical)
- zooming, panning
- maps are loaded automatically when opening Map Swipe with two selected raster maps in Layer Manager
- save display to graphic file
- new 'mirror' mode added - two synchronized maps side by side
- added text label with the name of currently displayed map
- in mirror mode: added cross to mirror the movement of mouse cursor
- new: multiple raster and vector maps with transparency
- new in 'mirror' mode: change the appearance of mirrored cursor (available in Map Swipe settings)
Possible enhancements:
add simplified layer manager for each window so that you can add any maps (raster/vector)r58197 -
add transparency levels (while in swipe mode) so one can actually see below the map that is (virtually) on top -- this will be useful if a "simplified layer manager" will be added! -
Paulo van Breugel: rather then splitting the area between the two maps, the same area is shown for both maps. The display of two (or more) maps are synchronized so moving or zooming one map will move / zoom the other map too. This makes it easier to see changes between two maps in detail (similar to MirrorMap plug-in for QGIS). See also ticket 1669. -
Add option to export the display to graphics file (PNG) - add a query tool that when you click on a spot in one of the maps gives you the info for both
- add a button that launches Michael's new histogram tool to directly show the histograms of the two maps
- add your idea here
Simple testing with sample data
You can use the North Carolina sample dataset (download) for this test:
# set computation region
g.region rast=lsat7_2002_10 -p
# create RGB composites, first color-balance:
i.landsat.rgb b=lsat5_1987_10@landsat g=lsat5_1987_20@landsat r=lsat5_1987_30@landsat
r.composite b=lsat5_1987_10@landsat g=lsat5_1987_20@landsat r=lsat5_1987_30@landsat out=lsat5_1987.rgb
i.landsat.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
r.composite b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30 out=lsat7_2002.rgb
# .. now load the two RGB composites into the "Map Swipe" tool.
Disaster analysis
The Map swipe tool is particularly interesting for pre and post disaster analysis of satellite or other images.
Screenshot of map comparison:
Pre and post disaster images of the tsunami in Japan in 2011. The upper MODIS image taken on February 26, 2011, shows the coastline under normal conditions while the lower MODIS image on March 13, 2011, shows a clear view of tsunami flooding along the coastline. Water, black and dark blue in these false-color images, still covers the ground as much as five kilometers (three miles) from the coast. Source: http://earthobservatory.nasa.gov/NaturalHazards/view.php?id=49634
