Compile and Install
Disclaimer: This page explains how to turn the GRASS source code into an installable binary package ("compilation") for different operating systems. If you just want to get ready-to-use binaries, go here, otherwise read on...
How to do compilation and installation of GRASS?
Here we explain the procedure to compile GRASS from GitHub, but it also applies to official GRASS 8 releases.
Prerequisites
Extra libraries
GRASS needs at least two extra libraries: PROJ and GDAL/OGR. It is recommended to download them as ready-to-use packages for your software platform (Linux distribution, Windows, Mac...).
Download GRASS source code
First, download the GRASS source code.
Generic Compilation and installation procedure
cd /usr/local/src/ su -c 'mkdir grass8' su -c 'chown yourlogin:yourgroup grass8'
mkdir $HOME/src cd $HOME/src/ git clone https://github.com/OSGeo/grass.git grass_main
./configure --help | less
It may (!) look like this:
GRASS is now configured for: x86_64-pc-linux-gnu Source directory: /home/user/software/grass_main Build directory: /home/user/software/grass_main Installation directory: ${prefix}/grass84 Startup script in directory:${exec_prefix}/bin C compiler: gcc -O2 -march=native -std=gnu99 -fexceptions -fstack-protector -m64 -fdiagnostics-color C++ compiler: c++ -g -Wall Building shared libraries: yes OpenGL platform: X11 MacOSX application: no MacOSX architectures: MacOSX SDK: BLAS support: yes BZIP2 support: no C++ support: yes Cairo support: yes DWG support: no FFTW support: yes FreeType support: yes GDAL support: yes GEOS support: yes [...]
make -j2
---------------------------------------------------------------------- Following modules are missing the 'description.html' file in src code: ---------------------------------------------------------------------- GRASS compilation log ------------------------- Started compilation: Mon 19 Aug 2024 10:47:57 PM CEST -- Errors in: No errors detected. -- Finished compilation: Mon 19 Aug 2024 10:55:12 PM CEST (In case of errors please change into the directory with error and run 'make')
su -c 'make install'
- enjoy GRASS:
grass
What else?
If you want to use QGIS, then also compile the GRASS-GDAL/OGR plugin. This is also useful to access your GRASS-data from other application using GDAL/OGR like R_statistics/ R.
Linux
Examples:
- Archlinux: https://aur.archlinux.org/packages/grass
Alpine Linux
# install compiler tools and libraries
apk add build-base bzip2-dev cairo-dev fftw-dev freetype-dev g++ gcc gdal-dev geos-dev git \
gnutls-dev libc6-compat libjpeg-turbo-dev libpng-dev make openjpeg-dev openblas-dev \
postgresql-dev proj-dev python3-dev py3-numpy-dev sqlite-dev tar tiff-dev unzip vim \
wget zip zstd-dev
# install needed tools and libraries when using GRASS
apk add attr bash bison bzip2 cairo curl fftw flex freetype gdal gdal-tools gettext geos gnutls \
jsoncpp libbz2 libexecinfo libjpeg-turbo libpng libunwind musl musl-utils ncurses openjpeg \
openblas py3-numpy py3-pillow py3-six postgresql proj-datumgrid proj-util sqlite sqlite-libs \
subversion tiff zstd zstd-libs
# get source code
cd ~
wget -c https://grass.osgeo.org/grass88/source/snapshot/grass-8.4.git_src_snapshot_latest.tar.gz
# unpack
tar xvfz grass-8.4.git_src_snapshot_latest.tar.gz
rm -f grass-8.4.git_src_snapshot_latest.tar.gz
# change into source code (update path name as needed)
cd grass-8.4.git_src_snapshot_2021_05_01/
# minimal configuration
./configure \
--with-cxx \
--with-geos \
--with-sqlite \
--without-nls \
--without-wxwidgets \
--without-fftw \
--without-cairo \
--without-freetype \
--without-opengl \
--without-odbc
# compilation
nice make -j2
Archlinux
You can install GRASS for Archlinux distribution based like Archlinux, Manjaro, EndeavourOS ...
- Easiest method : use a prebuilt package using arch4edu repository
"Arch4edu is a community repository for Arch Linux and Arch Linux ARM that strives to provide the latest versions of most software used by college students."
1. Add Arch4edu repository. Follow instructions from official documentation:
https://github.com/arch4edu/arch4edu/wiki/Add-arch4edu-to-your-Archlinux
2. Refresh packages list with
pacman -Syyu
3. Install GRASS package
pacman -S grass
- Advanced method : use AUR (Arch User Repository) package
Up-to-date links to Archlinux GRASS PKGBUILDs are on Arch User Repository. PKGBUILD downloads and builds automatically sources from https://grass.osgeo.org/download/software/linux/.
You can use an AUR helper like pamac, yay, among others ... More info through this link https://wiki.archlinux.org/title/AUR_helpers
Exemple with yay:
yay -S grass
- Expert method : compile from source code
If you want to compile it yourself, you could follow steps below :
(As an alternative it is recommended to download PKGBUILD from AUR and then customize to your needs)
Install dependencies :
pacman -S bzip2 cairo fftw fontconfig freetype2 gcc-libs gdal geos glibc glu libpng libtiff libx11 libgl netcdf pdal proj python-gdal python-numpy python-pillow python-wxpython readline zlib zstd
Download and extract sources : https://grass.osgeo.org/download/software/sources/
We can now start building GRASS
export PATH=~/usr/bin:$PATH && \ ./configure \ --with-freetype-includes=/usr/include/freetype2 \ --with-wxwidgets \ --with-readline \ --with-pthread \ --with-netcdf \ --with-nls \ --with-geos \ --with-postgres \ --with-pdal=/usr/include/pdal \ --with-bzlib \ --with-zstd
make make install
It's done, you can enjoy GRASS in Arch, just type "grass" in the terminal to launch it or look for grass in your menu.
Generic procedure for Debian-based distributions (Ubuntu, ...)
WORK IN PROGRESS
1. Install official GRASS package
sudo apt install grass grass-dev
2. Enable source code download
3. Install GRASS dependencies
sudo apt build-dep grass
4. Download GRASS source code
git clone https://github.com/osgeo/grass
5. Compile GRASS from source code
cd grass
Configure:
grass --config build | sh
Optionally install missing dependencies (can happen when official GRASS package is not compatible with GRASS main), eg.
sudo apt install libzstd-dev
Compile:
make -j2
6. Run locally or install
./bin.x86_64-pc-linux-gnu/grass --version
or
sudo make install grass --version
Debian
https://salsa.debian.org/debian-gis-team/grass
GRASS 8 on Debian 11 (bullseye)
Install needed packages for GRASS 8.4:
apt-get update && \ apt-get install bison debhelper-compat dh-python doxygen fakeroot flex graphviz \ libblas-dev libbz2-dev libcairo2-dev libfftw3-dev libfreetype6-dev \ libgdal-dev libgeos-dev libgl1-mesa-dev libglu1-mesa-dev libjpeg-dev liblapack-dev libmotif-dev \ default-libmysqlclient-dev libncurses5-dev libnetcdf-dev libpng-dev libpq-dev \ libproj-dev libreadline-dev libsqlite3-dev libtiff-dev libxmu-dev libzstd-dev \ netcdf-bin pkg-config proj-bin python3 python3-dev python3-numpy python3-pil python3-ply \ python3-six python3-wxgtk4.0 wget unixodbc-dev zlib1g-dev
Download and unpack GRASS 8.4 source code (or fetch from GitHub: https://github.com/OSGeo/grass):
wget https://grass.osgeo.org/grass84/source/grass-8.4-latest.tar.gz tar xvfz grass-8.4-latest.tar.gz cd grass-8.4.*
Configuration:
CFLAGS="-Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused" \ CXXFLAGS="-Wall" \ ./configure \ --prefix=/usr/local \ --with-gdal --with-proj --with-proj-share=/usr/share \ --with-glw --with-nls --with-readline \ --with-cxx --enable-largefile \ --with-freetype --with-freetype-includes=/usr/include/freetype2 \ --with-sqlite --with-cairo --with-python=/usr/bin/python-config \ --with-wxwidgets --with-geos \ --with-netcdf=/usr/bin/nc-config --with-odbc=yes \ --with-openmp=yes --with-pthread=no
Compile:
make -j2
Install:
make install
Run:
grass --version
Ubuntu
There is a dedicated page on how to Compile the GRASS source code & install it in Ubuntu.
Linux Mint
# Linux Mint 21+
# be sure to have an updated system
sudo apt-get update && sudo apt-get upgrade -y
# recommended to give Python3 precedence over Python2 (which is end-of-life since 2024)
sudo update-alternatives --install /usr/bin/python python /usr/bin/python3 1
# install compiler tools and further dependencies (tested with Linux Mint 21)
# this is a single command, please copy-paste it entirely into the terminal:
sudo apt-get install \
build-essential \
flex make bison gcc libgcc1 g++ cmake ccache \
libproj-dev proj-data proj-bin \
libgeos-dev \
libgdal-dev python3-gdal gdal-bin \
python3 python3-dev \
python3-opengl \
python3-wxgtk4.0 \
python3-dateutil libgsl-dev python3-numpy \
wx3.2-headers libwxgtk3.2-dev libwxbase3.2-1 libfftw3-dev libgtk-3-dev\
libncurses5-dev zlib1g-dev gettext \
libbz2-dev libzstd-dev libfreetype6-dev \
libtiff5-dev libpnglite-dev libcairo libcairo-dev \
sqlite3 libsqlite3-dev libpq-dev \
libfftw3-3 libfftw3-dev \
libboost-thread-dev libboost-program-options-dev \
subversion \
checkinstall \
libglu1-mesa-dev libxmu-dev \
ghostscript wget -y
GUI - update wxpython:
pip3 install -U -f https://extras.wxpython.org/wxPython4/extras/linux/gtk3/ubuntu-22.04 wxPython
Next steps:
- create a subdirectory in your HOME tree for storing the GRASS source code (and later compilation)
- get source code, one of the two options:
- a) download GRASS source code weekly snapshot (e.g. take the "8.x.git snapshot"), or
- unpack source code
- b) current source code from GitHub:
- change into the source code directory
# in the source code directory, "configure" the source code to prepare for compilation:
./configure \
--with-cxx \
--with-geos \
--with-sqlite \
--with-nls \
--with-zstd \
--with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
--with-fftw \
--with-opengl-libs=/usr/include/GL \
--without-postgres \
--without-pdal \
--without-netcdf \
--without-mysql \
--without-odbc \
--without-openmp
# compile GRASS
make -j2
# install compiled GRASS on system
sudo make install
# use GRASS! Start on command line
grass
Enterprise Linux
See: https://wiki.osgeo.org/wiki/Enterprise_Linux_GIS
Scientific Linux
See Centos
CentOS
You first need to add the EPEL repository for PROJ and GDAL, see here
Preparation Centos 8:
dnf install epel-release
dnf install flex bison make zlib-devel gcc-c++ gettext \ fftw-devel libtiff-devel sqlite-devel \ proj proj-devel proj-datumgrid libxml2 \ geos geos-devel git \ netcdf netcdf-devel atlas-devel \ blas-devel lapack-devel libpq-devel \ python3-devel python3-numpy \ python3-dateutil python3-imaging python3-matplotlib \ gdal gdal-libs gdal-python-tools python3-gdal gdal-devel \ wxGTK3-devel mesa-libGL-devel mesa-libGLU-devel \ libXmu-devel libX11-devel
GRASS 8 compilation and installation
Download source code (e.g., --> "Download latest 8.4 code)" and configure GRASS 8 (suggestion: save this as script):
./configure \ --with-cxx \ --with-proj --with-proj-share=/usr/share/proj \ --with-gdal=/usr/bin/gdal-config \ --with-sqlite \ --with-python \ --with-cairo --with-cairo-ldflags=-lfontconfig \ --with-freetype --with-freetype-includes=/usr/include/freetype2 \ --with-wxwidgets=/usr/bin/wx-config \ --with-openmp \ --with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \ --with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \ --with-fftw \ --with-geos \ --with-netcdf \ --without-ffmpeg \ --without-mysql \ --without-postgres \ --without-odbc \ --without-fftw
Compile:
make
make -j4
make install
bin.$ARCH/grass -gui
mkdir $HOME/bin cd $HOME/bin # example: ln -s $HOME/software/grass84_release/bin.x86_64-pc-linux-gnu/grass .
Now use it subsequently with
grass -gui
Installation grass on a HPC system with Centos 7 and no root privileges:
This assumes that python3, fftw, proj, gdal and geos are available on the HPC system, either as modules or as installed software.
./configure \ -prefix=$HOME/grass \ --enable-64bit --with-fftw-includes=/path/to/fftw/include/ \ --with-fftw-libs=/path/to/fftw/lib/ \ --with-freetype-includes=$HOME/grass/freetypes/freetype-2.9.1/include/ \ --with-netcdf --with-geos --with-blas --with-lapack --with-postgres \ --with-zstd-includes=$HOME/grass/zstd/zstd-1.4.4/lib/ \ --with-zstd-libs=$HOME/grass/zstd/zstd-1.4.4/lib/ \ --with-gdal=/path/to/gdal-config # This could be the path to a gdal version compiled from source
Finally as usual:
make; make install grass
Gentoo
See also https://packages.gentoo.org/package/sci-geosciences/grass
Funtoo
Fedora
GRASS 8 on Fedora
Preparation for the compilation of GRASS 8+ source code (F36+):
dnf install gcc gcc-c++ bison flex ncurses-devel gettext proj-devel \ gdal gdal-devel sqlite-devel xml2 mesa-libGL-devel cairo-devel \ fftw-devel mesa-libGLU-devel libXmu-devel libX11-devel geos geos-devel \ libtiff-devel python3-devel numpy wxGTK-devel gawk git \ python3-dateutil python3-imaging python3-matplotlib-wx doxygen python3-sphinx \ libzstd-devel libzstd python3-six python3-numpy python3-wxpython4 \ proj-data PDAL-devel PDAL-libs
# optionally also: netcdf-devel postgresql-devel # atlas-devel lapack-devel lapack-devel # laszip laszip-devel # proj-data-at proj-data-au proj-data-be ...
Download and unpack the source code:
- GRASS 8: weekly snapshot - GitHub repository
./configure \ --with-cxx \ --with-gdal=/usr/bin/gdal-config \ --with-proj --with-proj-share=/usr/share/proj \ --with-geos \ --with-pdal \ --with-sqlite \ --with-nls \ --with-wxwidgets=/usr/bin/wx-config \ --with-fftw \ --with-cairo --with-cairo-ldflags=-lfontconfig \ --with-freetype --with-freetype-includes=/usr/include/freetype2 \ --enable-largefile \ --without-odbc
--with-zstd \
Then use GRASS 8 and enjoy!
grass --version
openSUSE
To build GRASS on openSUSE:
sudo zypper addrepo https://download.opensuse.org/repositories/Application:Geo/openSUSE_Leap_42.3/Application:Geo.repo
sudo zypper refresh
RPM packages to be installed:
Source code configuration:
./configure \
--with-cxx \
--with-lapack=yes \
--with-motif \
--with-fftw \
--with-readline \
--with-netcdf \
--with-geos \
--with-nls \
--with-sqlite \
--with-freetype \
--with-wxwidgets \
--with-odbc \
--with-python
RPM SPEC files
macOS
Compiling GRASS for macOS is not fundamentally different from for other *nix systems. It is on the contrary quite similar, but what differ is the lack of a default package management system for software GRASS depends on. This leaves the mac user to either: (1) compile the dependencies one-by-one; (2) compiling with one of the third-party package management systems avaliable; or (4) a combination thereof.
To date, maybe the easiest way to compile for Mac is by using GRASS app build script which is based on the instructions below for building using Anaconda. It will install dependencies, package and install an app bundle with just a command in Terminal.
For more up-to-date instructions please read:
- Compiling on macOS using Conda (Intel / Apple silicon based machine M1)
- Compiling on macOS using Anaconda
- Compiling on macOS using Homebrew
- Compiling on macOS using MacPorts
Legacy instructions
The following compilation and installation instructions are rather outdated as a whole. They do, however, contain parts and snippets that still may be very instructive and useful.
Troubleshooting:
- solving errors at starting GRASS: MacOSX GRASS errors
FreeBSD / NetBSD
GRASS 8 should compile on FreeBSD and NetBSD.
It is highly recommended to install GDAL/OGR and PROJ first. These libraries and tools are available as ports for FreeBSD and packages for NetBSD.
ICONVLIB = -liconv
AIX
GRASS 8: Using the IBM xlc compiler:
- GNU tar
- GNU make (>= 3.81)
- SQLite
- GRASS 8
## AIX 5.x export LIBPATH=/opt/freeware/lib64:/opt/freeware/lib # make 'ar' happy export OBJECT_MODE=64 PREFIX=$HOME/private/bin ./configure \ --prefix=$PREFIX \ --disable-shared \ --with-cxx \ --with-proj-includes=$PREFIX/include/ \ --with-proj-libs=$PREFIX/lib/ \ --with-proj-share=$PREFIX/share/proj/ \ --with-sqlite \ --with-sqlite-includes=$PREFIX/include/ \ --with-sqlite-libs=$PREFIX/lib/ \ --with-tiff=no \ --with-png=no \ --with-fftw=no \ --with-cairo=no \ --with-freetype=no
GRASS 8: Using the GNU gcc compiler:
- if needed, GNU tar
- SQLite
- GRASS 8
## AIX 7.x export CC="gcc" export CXX="g++" PREFIX=$HOME/bin LDFLAGS="-Wl,-bsvr4,-R,/opt/freeware/lib -L/opt/freeware/lib" CPPFLAGS="-I/opt/freeware/include" ./configure \ --prefix=$PREFIX \ --enable-shared \ --with-includes=/opt/freeware/include --with-libs=/opt/freeware/lib \ --with-cxx \ --with-proj-includes=$PREFIX/include/ \ --with-proj-libs=$PREFIX/lib/ \ --with-proj-share=$PREFIX/share/proj/ \ --with-gdal=$PREFIX/bin/gdal-config \ --with-sqlite \ --with-sqlite-libs=$PREFIX/lib --with-sqlite-includes=$PREFIX/include \ --with-png=no \ --with-tiff=no \ --with-fftw=no \ --with-cairo=no \ --with-opengl=no \ --with-freetype=no
MS-Windows
MS-Windows/native
GRASS on Windows using a standalone installer. It is still MinGW based (we are going to move this to CMake in 2024+).
Instructions to compile from source code:
MS-Windows/OSGeo4W
OSGeo4W is an installer for a broad set of open source geospatial software packages including GRASS as well as many other packages (QGIS, GDAL/OGR, and more).
- See OSGeo4W
MS-Windows/Cygwin
- See the Cygwin wiki pages
Common problems and solutions
- error: lib/python/ctypes
- This error appears during the compilation:
free(): invalid pointer Aborted (core dumped)
- It happens when you have multiple
libproj
versions on your system (check it with commandldd PATH_TO_GRASS_INSTALL/lib/libgrass_gproj.so | grep proj
- when this is not your problem, you should obtain exactly one result) - Solution: Try to reinstall
libproj-dev
andproj-data
Static compilation
This will however break the wxGUI and GRASS 8 completely because "ctypes" wants to link against shared libs, or there is something in the static libs that "ctypes" does not like.
Optimization
CFLAGS=-O ./configure
or,
setenv CFLAGS -O ./configure
gcc -dumpspecs
See also: https://gcc.gnu.org/
make -j 4
GRASS-GDAL plugin
Addons
Please note that the installation of GRASS addons can be easily done with the g.extension manager. The compile instructions below are aiming at own development.
Compiled modules
Requirements:
Either:
- a binary GRASS package, or
make MODULE_TOPDIR=/path/to/grass84/
Note that the /path/to/grass84 has to be absolute, not relative.
alias gmake64='make MODULE_TOPDIR=/path/to/grass84/'
make MODULE_TOPDIR=/path/to/grass84/ install
make MODULE_TOPDIR=/usr/lib/grass84/ INST_DIR=/usr/lib/grass84/
Scripts
GRASS (nc_spm):~ > v.krige.py
