User talk:Neubadanho
hi, I have just download the new native wingrass and it seems like it does not work properly. Is it correct?
> Please refer bug reports regarding native winGRASS to the developers mailing list. thanks. --Hamish
i have forget to say that i am new in grass and many thing need to be explain to me. This the error message:
For Nviz: couldn't execute "nviz": no such file or directory couldn't execute "nviz": no such file or directory
while executing
"exec -- nviz &"
("eval" body line 1)
invoked from within
"eval [list exec -- $cmd] $args &"
(procedure "spawn" line 3) invoked from within
"spawn $cmd"
(procedure "Gm::nviz" line 13) invoked from within
"Gm::nviz"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18) invoked from within
"Button::_release .mainframe.topf.tb1.bbox4.b0"
(command bound to event)
for legend can't read "env(GRASS_FONT)": no such variable can't read "env(GRASS_FONT)": no such variable
while executing
"set currfont $env(GRASS_FONT)"
(procedure "GmLegend::display" line 69) invoked from within
"GmLegend::display $node $mod"
("legend" arm line 2)
invoked from within
"switch $type {
group {
GmGroup::display $node $mod
} raster { GmRaster::display $node $mod } labels { GmLabels::disp..."
(procedure "GmTree::display_node" line 7) invoked from within
"GmTree::display_node $n $mod"
(procedure "GmGroup::display" line 24) invoked from within
"GmGroup::display "root" $mod"
(procedure "MapCanvas::runprograms" line 64) invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
(procedure "MapCanvas::drawmap" line 38) invoked from within
"MapCanvas::drawmap $mon"
(procedure "MapCanvas::display_server" line 9) invoked from within
("after" script)
For r.shaded begin_dialog {r.shaded.relief} {
label {}
desc {Creates shaded relief map from an elevation map (DEM).}
key {raster, elevation}
} add_option 1 {
name {map}
type {string}
multi 0
desc {Input elevation map}
required 1
options {}
descs {}
answer {}
prompt {old,cell,raster}
label {}
guisection {}
} add_option 2 {
name {shadedmap}
type {string}
multi 0
desc {Output shaded relief map name}
required 0
options {}
descs {}
answer {}
prompt {new,cell,raster}
label {}
guisection {}
} add_option 3 {
name {altitude}
type {integer}
multi 0
desc {Altitude of the sun in degrees above the horizon}
required 0
options {0-90}
descs {}
answer {30}
prompt {}
label {}
guisection {}
} add_option 4 {
name {azimuth}
type {integer}
multi 0
desc {Azimuth of the sun in degrees to the east of north}
required 0
options {0-360}
descs {}
answer {270}
prompt {}
label {}
guisection {}
} add_option 5 {
name {zmult}
type {float}
multi 0
desc {Factor for exaggerating relief}
required 0
options {}
descs {}
answer {1}
prompt {}
label {}
guisection {}
} add_option 6 {
name {scale}
type {float}
multi 0
desc {Scale factor for converting horizontal units to elevation units}
required 0
options {}
descs {}
answer {1}
prompt {}
label {}
guisection {}
} add_option 7 {
name {units}
type {string}
multi 0
desc {Set scaling factor (applies to lat./long. locations only)}
required 0
options {meters,feet}
descs {}
answer {}
prompt {}
label {}
guisection {}
} add_xflag 8 {
name {overwrite}
desc {Allow output files to overwrite existing files}
answer 0
label {Allow overwrite}
guisection {}
} end_dialog 8 c:/grass/grass-6.3.cvs/scripts/r.shaded.relief: basename: command not found begin_dialog {r.shaded.relief} {
label {}
} add_option 1 {
name {map}
type {string}
multi 0
required 1
options {}
descs {}
answer {}
label {}
guisection {}
} add_option 2 {
name {shadedmap}
type {string}
multi 0
required 0
options {}
descs {}
answer {}
label {}
guisection {}
} add_option 3 {
name {altitude}
type {integer}
multi 0
required 0
options {0-90}
descs {}
answer {30}
prompt {}
label {}
guisection {}
} add_option 4 {
name {azimuth}
type {integer}
multi 0
required 0
options {0-360}
descs {}
answer {270}
prompt {}
label {}
guisection {}
} add_option 5 {
name {zmult}
type {float}
multi 0
required 0
options {}
descs {}
answer {1}
prompt {}
label {}
guisection {}
} add_option 6 {
name {scale}
type {float}
multi 0
required 0
options {}
descs {}
answer {1}
prompt {}
label {}
guisection {}
} add_option 7 {
name {units}
type {string}
multi 0
required 0
descs {}
answer {}
prompt {}
label {}
guisection {}
} add_xflag 8 {
name {overwrite}
answer 0
guisection {}
while executing
"exec -- $program --tcltk"
(procedure "run_ui" line 6) invoked from within
"run_ui $cmd"
(procedure "execute" line 3) invoked from within
"execute r.shaded.relief "
(menu invoke)
