Compile and Install
How to do compilation and installation of GRASS 6?
Here we explain the procedure to compile GRASS from SVN, but it also applies to official GRASS 6 releases.
Prerequisites
Extra libraries
GRASS needs at least two extra libraries: PROJ and GDAL/OGR
Note: if you want to have DBMS support in GDAL (subsequently in GRASS) you have to perform the "Optional" steps below as well.
- PROJ4 for management of projections (with proj-datumgrid-1.3.zip support)
- Optional: GEOS
- Optional: PostgreSQL, mySQL, unixODBC, SQLite (SQLite is needed for QGIS)
- GDAL/OGR for reading and writing various GIS data formats (interoperability)
You have to install these two libraries first (see below how to get them precompiled for your system).
It is easiest to obtain a prepackaged version of these libraries (e.g., .rpm; .deb) for your particular operating system and run the corresponding package installation (e.g., rpm -Uhv packagename.rpm; apt-get) in a terminal window. Take care to also install the development packages of these libraries (...-devel packages). If there is no prepackage version, then you will have to download the source code (see links above, source code packages usually ends in .tar.gz or .zip) and compile it (you must have a C compiler installed as part of your operating system). The Web sites show the steps to compile the libraries.
To compile, you will also need the respective "-devel" packages.
Download GRASS GIS source code
Then download the GRASS GIS source code of course.
Generic Compilation and installation procedure
cd /usr/local/src/
su -c 'mkdir grass6'
su -c 'chown yourlogin:yourgroup grass6'
cd /usr/local/src/
svn checkout ...
- do a code checkout from the SVN source code repository
- checkout the latest GRASS 6.x from SVN (see: [1])
- in the grass6 directory, you will find the precious INSTALL file, open it with your favourite pager/editor and read it carefully!
./configure --help | less
It may (!) look like this:
./configure \
--with-cxx \
--with-sqlite \
--with-postgres-libs=/usr/include/pgsql/libpq \
--with-postgres-includes=/usr/include/pgsql \
--with-freetype \
--with-motif \
--with-proj-share=/usr/share/proj
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /usr/src/grass6
Build directory: /usr/src/grass6
Installation directory: /usr/local/grass-6.3.svn
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
FORTRAN compiler:
Building shared libraries: yes
64bit support: no
NVIZ: yes
BLAS support: no
C++ support: yes
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GLw support: no
LAPACK support: no
Large File Support (LFS): no
Motif support: no
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL(R) support: yes
PNG support: yes
PostgreSQL support: yes
Readline support: no
SQLite support: no
Tcl/Tk support: yes
TIFF support: yes
X11 support: yes
make
---------------------------------------------------------------------- Following modules are missing the 'description.html' file in src code: ---------------------------------------------------------------------- GRASS GIS compilation log ------------------------- Started compilation: Ne kvě 28 13:18:43 CEST 2006 -- Errors in: -- Finished compilation: Ne kvě 28 13:43:40 CEST 2006 (In case of errors please change into the directory with error and run 'make')
- If there is any error, change directory to directory with error and run "make" again. Report occuring bug to grass mailing list
su -c 'make install'
- enjoy GRASS:
grass64
What else?
Linux
Debian
Read the instructions here:
# first install PROJ, GDAL, etc. cd grass64/ # follow instructions in debian/README.debian fakeroot buildpackage
- Official DebianGIS packaging control files, also accessible via svn:
svn co svn://svn.debian.org/svn/pkg-grass/packages/grass/trunk/
or
svn co svn://svn.debian.org/svn/pkg-grass/packages/grass/branches/<GRASS Version>
GRASS 6.1 on Debian Sarge
GRASS 6.4 on Debian Lenny
Install needed packages:
apt-get install flex bison libreadline-dev libncurses5-dev lesstif2-dev debhelper dpatch libtiff4-dev \
tcl-dev tk-dev libfftw3-dev libxmu-dev libfreetype6-dev autoconf2.13 autotools-dev doxygen \
libmysqlclient15-dev graphviz libsqlite3-dev python-wxgtk2.8 libcairo2-dev libwxgtk2.8-dev \
python-dev libgdal1-dev libgdal1-1.5.0 libproj-dev libproj0 proj-data mysql
Configure:
./configure \ --with-cxx \ --with-sqlite \ --with-postgres --with-postgres-includes=/usr/include/postgresql \ --with-mysql --with-mysql-includes=/usr/include/mysql --with-mysql-libs=/usr/lib/mysql \ --with-odbc \ --with-cairo \ --with-proj-share=/usr/share/proj \ --with-tcltk-includes=/usr/include/tcl8.4/ \ --with-freetype --with-freetype-includes=/usr/include/freetype2 \ --with-motif --with-fftw --with-nls --with-python
Compile:
make
Install:
sudo make install
GRASS 7 on Debian Squeeze
apt-get install flex bison debhelper dpatch autoconf2.13 autotools-dev python-dev \
g++ gcc gettext graphviz libcairo2-dev libfftw3-dev libfreetype6-dev \
libgdal1-1.6.0 libgdal1-dev libglu1-mesa-dev libglw1-mesa-dev \
libncurses5-dev libproj-dev libreadline-dev libsqlite3-dev libtiff4-dev \
libwxgtk2.8-dev libxmu-dev libxmu-headers libxt-dev mesa-common-dev \
proj-bin python-numpy python-wxgtk2.8 subversion wx-common zlib1g-dev
Download source code:
Configure:
CFLAGS="-g -Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused" \ CXXFLAGS="-g -Wall" \ ./configure --prefix=/usr/local \ --with-gdal --with-proj --with-proj-share=/usr/share \ --with-glw --with-nls --with-readline \ --without-tcltk \ --with-cxx \ --enable-largefile \ --with-freetype --with-freetype-includes=/usr/include/freetype2 \ --with-sqlite \ --with-cairo --with-python=/usr/bin/python2.6-config --with-wxwidgets \ --with-geos --with-pthread
Compile:
make
Install:
sudo make install
Ubuntu
The above Debian notes will probably work with Ubuntu as well.
A more specific page towards Ubuntu is being written on.
Ubuntu 6.06, 7.10
- makegrass.sh is script designed to automate most of the download, configuration and compilation of GRASS 6.x-CVS
- it is advised use checkinstall (sudo apt-get install checkinstall) instead of make install to keep track of installed software
- Think twice before using this script. Some users experienced problems such as disabled XGL etc.
- Here is another of these scripts, it's homemade so probably you'll find the above more useful for production sites.
Ubuntu 7.10 64-bit
- Compiling latest GRASS source code on a 64-bit machine (with an ATI graphic card) under Ubuntu 7.10 64-bit with support for: 64-bit, SQLite, OpenGL, PYTHON, FFMPEG
(Based on "Ubuntu 6.06 LTS - GRASS 6.1 Compilation Script" by David Finlayson) Assuming it is the first time attempting to compile GRASS' source code & installing SVN, PROJ, GDAL/OGR
Preparation
sudo apt-get update && sudo apt-get upgrade
- install dependencies for compiling (in general) and dependencies for GRASS: PROJ, GDAL/OGR
sudo apt-get install grass build-essential flex bison libncurses5-dev zlib1g-dev \ libgdal1-dev libtiff4-dev libgcc1 libpng12-dev tcl8.4-dev tk8.4-dev fftw3-dev \ libfreetype6-dev libavcodec-dev libxmu-dev gdal-bin libreadline5 libreadline5-dev \ make python-dev python-wxversion
- install SQLite
sudo apt-get install sqlite3 libsqlite3-dev
- install SVN
sudo apt-get install subversion
- create a directory as a simple user where source code(s) are going to be stored (in our example we use a directory called src under /usr/local)
sudo mkdir /usr/local/src
- grant rwx (read-write-execute) permissions for our userid/ groupid on the directory (replace words userid and groupid with real userid):
sudo chown userid:groupid /usr/local/src
sudo chmod ug+rwx /usr/local/src
- download latest source code from GRASS SVN repository in a directory on the system (e.g. /usr/local/src)
- Above command places GRASS' source code in /usr/local/src/grass_trunk. In case of a subsequent update use the command: svn up from within the grass_trunk directory
Before attempting to compile GRASS, READ section (C) in the INSTALL file located in the main directory of GRASS source code entitled: (C) COMPILATION NOTES for 64bit platforms
- installing FFTW3 if not already on system
sudo apt-get install fftw3 fftw3-dev
FFMPEG
Note: Back in Ubuntu 7.10, installing ffmpeg through the repositories wouldn't work with grass. The following steps were successfully used.
- install FFMPEG (information taken from: http://stream0.org/2008/01/install-ffmpeg-on-ubuntu-gutsy.html)
- download source code with svn
svn checkout svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
sudo apt-get install liblame-dev libfaad2-dev libfaac-dev libxvidcore4-dev \
liba52-0.7.4 liba52-0.7.4-dev libx264-dev libdts-dev checkinstall \
build-essential subversion
- guide to ffmpeg directory
cd ffmpeg
if necessary: make distclean before configuration (look at notes below)
- configuration (note: the configuration parameter "--enable-pp" does not work anymore)
# configure FFMPEG
./configure --enable-gpl --enable-libvorbis --enable-libtheora \
--enable-liba52 --enable-libdc1394 --enable-libgsm \
--enable-libmp3lame --enable-libfaad --enable-libfaac \
--enable-libxvid --enable-pthreads --enable-libx264 \
--enable-shared
- compilation
make
- installation on /usr/local/bin -- important to remember when configuring GRASS' source code for compilation
sudo checkinstall
Go for GRASS!
- in our example we used the /usr/local/src directory to store GRASS' source code, so:
cd /usr/local/src/grass_trunk
- configuration
CFLAGS="-g -Wall" ./configure --enable-64bit \
--with-libs=/usr/lib64 --with-cxx --with-freetype=yes \
--with-postgres=no --with-sqlite=yes --enable-largefile=yes \
--with-tcltk-includes=/usr/include/tcl8.4 \
--with-opengl-libs=/usr/include/GL --with-readline \
--with-python=yes --with-ffmpeg=yes \
--with-ffmpeg-includes=/usr/local/include/ffmpeg
- if OpenGL fails then maybe it is necessary to link glxATI.h with glx.h and re-run the configuration
cd /usr/include/GL
sudo ln glxATI.h glx.h
- compilation
make
- compilation is expected to end with a statement similar to the following:
Started compilation: Wed Feb 27 00:24:36 CET 2008 -- Errors in: No errors detected.
- installation
sudo checkinstall
- launch 64-bit GRASS.6.4.svn
grass64
Notes
- in case of errors in future compilation attempts, remember to remove program binaries with
make clean
- and the files created with the "configuration" from previous compilations with
make distclean
Ubuntu 8.04 and above
Mandriva
# as root
exit
# as root
exit
Installation:
CentOS
Note: CentOS 5 comes with Python 2.4 which lacks python-config, hence two extra tweaks are needed.
Preparation:
ncurses-devel postgresql-devel
Compile and install PROJ4:
# get source code and unpack: wget http://download.osgeo.org/proj/proj-4.7.0.tar.gz tar xvfz proj-4.7.0.tar.gz rm -f proj-4.7.0.tar.gz cd proj-4.7.0/ # get and install datum files into right directory: cd nad/ wget http://download.osgeo.org/proj/proj-datumgrid-1.5.zip unzip proj-datumgrid-1.5.zip rm -f proj-datumgrid-1.5.zip cd .. # configure and compile sh configure make -j4 # install (may require "root" permissions, use "su"): make install
Compile and install GDAL:
# get source code and unpack: wget http://download.osgeo.org/gdal/gdal-1.6.3.tar.gz tar xvfz gdal-1.6.3.tar.gz rm -f gdal-1.6.3.tar.gz cd gdal-1.6.3/ # configure and compile sh configure make -j4 # install (may require "root" permissions, use "su"): make install # add /usr/local/lib/ to LD_LIBRARY_PATH, requires "root" permissions: su - echo "/usr/local/lib" > /etc/ld.so.conf.d/gdal.conf ldconfig exit # test installation by running gdalinfo
GRASS 7 compilation and installation, here 64bit example:
1. Download wxGTP and wxPython:
wget http://packages.sw.be/wxPython/wxPython-2.8.9.1-1.el5.rf.x86_64.rpm wget http://packages.sw.be/wxPython/wxPython-devel-2.8.9.1-1.el5.rf.x86_64.rpm wget http://packages.sw.be/wxGTK/wxGTK-2.8.9-1.el5.rf.x86_64.rpm wget http://packages.sw.be/wxGTK/wxGTK-devel-2.8.9-1.el5.rf.x86_64.rpm # Install: rpm -Uhv wxPython-2.8.9.1-1.el5.rf.x86_64.rpm wxPython-devel-2.8.9.1-1.el5.rf.x86_64.rpm \ wxGTK-2.8.9-1.el5.rf.x86_64.rpm wxGTK-devel-2.8.9-1.el5.rf.x86_64.rpm
2. Also required is the python library python-dateutil. As root user run:
yum install python-dateutil
3. Download and configure GRASS 7 (suggestion: save this as script). Note that PROJ4 and GDAL must be compiled first:
./configure \ --with-libs=/usr/lib64 \ --with-cxx \ --without-ffmpeg \ --with-gdal=/usr/local/bin/gdal-config \ --without-odbc \ --with-sqlite \ --with-postgres \ --without-mysql \ --with-nls \ --with-python \ --with-cairo \ --with-wxwidgets=/usr/bin/wx-config \ --without-fftw \ --with-freetype --with-freetype-includes=/usr/include/freetype2 \ --enable-largefile \ --with-pthread
4. Add manually the path to the python include directory since python-config isn't there:
# edit include/Make/Platform.make # and add manually the line PYTHONINC = -I/usr/include/python2.4
5. Compile
make or on multicore (number depends of available cores): make -j4
6. Either install with "make install" (as root user) or run directly from compile directory (substitute ARCH with i586 or x86_64):
bin.$ARCH/grass70 -wx
Gentoo
See http://gentoo-portage.com/sci-geosciences/grass
Fedora
Preparation for the compilation of GRASS GIS source code (F16, F17, F18):
yum install proj-devel gdal-devel sqlite-devel ffmpeg-devel mesa-libGL-devel \
mesa-libGLU-devel libXmu-devel libX11-devel tcl-devel tk-devel \
fftw-devel libtiff-devel lesstif-devel python-devel numpy wxPython wxGTK-devel \
gcc gcc-c++ bison flex ncurses-devel proj-epsg proj-nad xml2 python-dateutil
Note 1: that currently gdal-devel has (too) many dependencies and will lead to a massive download of extra packages (200 on a fresh Fedora 16 install).
This is an example how to configure the source code on a Fedora system:
./configure \ --with-cxx \ --with-gdal=/usr/bin/gdal-config \ --with-proj --with-proj-share=/usr/share/proj \ --with-sqlite \ --with-nls \ --with-wxwidgets=/usr/bin/wx-config \ --with-fftw \ --with-python=/usr/bin/python-config \ --with-freetype --with-freetype-includes=/usr/include/freetype2 \ --enable-largefile \ --without-odbc
An effective (but not fast) way of getting dependencies is to decide what to enable in the configuration, and then run ./config and see which files are missing. The package providing it can be found via:
yum provides */<name of the file>
and then install them with your favourite package manager frontend or yum itself.
If you want also FFMPEG support:
It requires 'yum install fftw-devel'. Then add to the configuration:
openSUSE
To build GRASS on openSUSE:
RPM packages to be installed:
sudo zypper install bison flex freetype2-devel fftw3-devel gcc-c++ \ libgdal-devel libgeos-devel libjpeg-devel libpng-devel libtiff-devel \ man proj libproj-devel readline-devel netcdf-devel ncurses-devel \ mysql-devel postgresql-devel sqlite-devel unixODBC-devel \ tcl-devel tk-devel xorg-x11-Mesa-devel libXmu-devel \ python-numpy python-dateutil python-devel python-opengl \ python-wxWidgets python-xml python-dateutil wxWidgets-devel \ zlib-devel
Source code configuration:
./configure \ --enable-largefile \ --with-proj-share=/usr/share/proj \ --with-cxx \ --with-lapack=yes \ --with-x \ --with-motif \ --with-gdal=/usr/bin/gdal-config \ --with-postgres --with-postgres-includes=/usr/include/pgsql \ --with-mysql --with-mysql-includes=/usr/include/mysql \ --with-fftw \ --with-readline \ --with-netcdf \ --with-curses \ --with-geos \ --with-nls \ --with-sqlite \ --with-freetype \ --with-freetype-includes=/usr/include/freetype2 \ --with-wxwidgets \ --with-odbc \ --with-python
Arch Linux
The easiest/fastest way is to build GRASS GIS using AUR:
https://aur.archlinux.org/packages/?O=0&K=grass (msieczka: I would recommend my set of PKBUILDs - https://aur.archlinux.org/packages/?K=czk&SeB=m. They are most feature-rich, up-to-date and allow to have various versions installed alongside each other without conflicts.)
But if you want to compile it yourself you have to keep in mind that in Arch Linux the default Python version 3.
python --version
Python 3.3.1
Therefore, to build GRASS GIS (version 7 in this example), we can use either use virtualenv or symlink python2 and python2-config in a given directory. Let's use the latter approach
sudo ln -s /usr/bin/python2 $HOME/usr/bin/python sudo ln -s /usr/bin/python2-config $HOME/usr/bin/python-config
export PATH=~/usr/bin:$PATH && \ ./configure \ --enable-debug \ --enable-64bit \ --with-libs=/usr/lib64 \ --with-cxx \ --with-readline \ --with-zlib-includes="/usr/include/" \ --with-freetype=yes \ --with-freetype-includes="/usr/include/freetype2/" \ --enable-largefile=yes \ --with-gdal=/usr/bin/gdal-config \ --with-proj-share=/usr/share/proj/ \ --with-geos=/usr/bin/geos-config \ --with-cairo \ --with-odbc \ --with-pthread \ --with-liblas=/usr/local/bin/liblas-config \ --with-fftw-includes="/usr/include/" \ --with-fftw-libs=/usr/lib/ \ --with-tcltk-includes="/usr/include/" \ --with-wxwidgets \ --with-postgres=yes \ --with-postgres-includes="/usr/include/postgresql/internal" \ --with-postgres-libs="/usr/include/postgresql/internal/libpq" \ --with-sqlite=yes \ --with-python=yes \ --with-liblas \ --with-netcdf
make sudo make install
Now the final step required to use GRASS with python2 is to create a bash script "grass" (or the name you want)
#!/bin/bash export PATH=~/usr/bin:$PATH python2 /usr/local/bin/grass70
And make it executable and copy it somewhere in the PATH
chmod+x grass sudo cp grass /usr/local/bin
It's done, you can enjoy GRASS 7 in Arch, just type "grass" (or the name you gave to the script) in the terminal to launch it.
RPM SPEC files
- ... can be found in the source code, rpm/ directory,
- or OpenSuSe
- or Fedora
- or Mandriva (there are also proj4, geos, gdal, gdal-grass-plugin, qgis etc)
Zaurus
... see here for instructions
Mac OSX
- see the source/macosx readme
- also see Compiling on MacOSX
- some notes on Packaging on MacOSX
- Download build scripts
FreeBSD / NetBSD
Solaris
11 SPARC/i86pc
LDFLAGS="-R/opt/csw/gxx/lib -R/opt/csw/lib"
10 SPARC/i86pc
- get gcc compiler and tools. There are several sources: Solaris Companion CD (SFW pkg, installs in /opt/sfw/), Blastwave ([2], CSW pkg, installs in /opt/csw/) or Sunfreeware ([3], SMC pkg, installs in /usr/local/).
- compile and install fftw-library ([4]). You need to re-compile the library with:
- compile and install gdal library (see documentation of gdal, [5]).
- compile and install any additional libraries (e. g. GEOS, [6]).
# on ultra-sparc machine:
CFLAGS="-O3 -mcpu=v9"
CXXFLAGS="-O3 -mcpu=v9"
export CFLAGS CXXFLAGS PATH
- Next configure, e. g.:
then:
make
su
make install
AIX
Mike wrote in 2009:
- GNU tar
- GNU make (>= 3.81)
- SQLite
- GRASS 7
The environment variables and configure command that worked (variables also for GDAL compilation):
export LIBICONV=/opt/freeware PREFIX=$HOME/private/bin ./configure \ --prefix=$PREFIX \ --disable-shared \ --enable-largefile \ --with-cxx \ --with-proj-includes=$PREFIX/include/ \ --with-proj-libs=$PREFIX/lib/ \ --with-proj-share=$PREFIX/share/proj/ \ --with-sqlite \ --with-sqlite-includes=$PREFIX/include/ \ --with-sqlite-libs=$PREFIX/lib/ \ --with-tiff=no \ --with-png=no \ --with-fftw=no \ --with-cairo=no \ --with-freetype=no
- GNU tar
- SQLite
- GRASS 7
export LIBICONV=/opt/freeware export CC="gcc" export CXX="g++" PREFIX=$HOME/private/bin CFLAGS='-ansi -D_ALL_SOURCE=1 -D_POSIX_SOURCE=1 -D_POSIX_C_SOURCE=200809L -Dinline=' ./configure \ --prefix=$PREFIX \ --disable-shared \ --enable-largefile \ --with-cxx \ --with-proj-includes=$PREFIX/include/ \ --with-proj-libs=$PREFIX/lib/ \ --with-proj-share=$PREFIX/share/proj/ \ --with-sqlite \ --with-sqlite-includes=$PREFIX/include/ \ --with-sqlite-libs=$PREFIX/lib/ \ --with-tiff=no \ --with-png=no \ --with-fftw=no \ --with-cairo=no \ --with-freetype=no
MS-Windows
MS-Windows/Cygwin
- See the Cygwin wiki pages
MS-Windows/native
Compile
- GRASS Windows Native Binary Building Guide (GRASS 6.4.x)
GRASS Windows Native Binary Building Guide (GRASS 6.3.x) - See/adapt idea for unattended install of QGIS (et al) from OSGeo4W from the QuantumGIS Blog.
Common problems and solutions
Static compilation
Optimization
CFLAGS=-O ./configure
or,
setenv CFLAGS -O
./configure
gcc -dumpspecs
See also: http://gcc.gnu.org/
make -j 4
GRASS-GDAL plugin
Addons
Compiled C modules
Requirements:
Either:
- a binary GRASS package, or
Scripts
