Talk:Compile and Install
- Can we remove the "AIX" related info below?
- Please, if taking time to update the compilation related sections, why not move over to somewhere under https://trac.osgeo.org/grass/wiki/BuildHints?
--Nikos Alexandris 00:07, 31 March 2017 (PDT)
Ubuntu compilation hints
feedback on following the same directions under Ubuntu 8.10 amd64
- apt-get says "Couldn't find package bpng12-dev"
- HB: try "apt-cache search bpng*-dev". Probably they bumped the version number.
AIX 7.x compilation hints
Hints: Using the GNU C/C++ compiler on AIX
- conf_proj_AIX.sh:
sh configure --prefix=$HOME/bin --without-mutex
- conf_sqlite3.sh:
sh configure --prefix=$HOME/bin \ --disable-shared --disable-threadsafe --disable-tcl
- conf_gdal.sh:
export LIBICONV=/opt/freeware export CC="gcc" export CXX="g++" PREFIX=$HOME/bin CFLAGS='-DHAVE_INTTYPES_H=0' ./configure \ --prefix=$PREFIX --with-libz=internal --with-threads=no --with-geotiff=internal --with-libtiff=internal echo "Now manually edit: vim port/cpl_config.h and disable use of AIX's <inttypes.h> header file" echo "#define HAVE_INTTYPES_H 0" echo "See bug http://trac.osgeo.org/gdal/ticket/4809"
- Fix $HOME/bin/gdal-config issue (bug in GRASS GIS 7 or GDAL?): add to the 'CONFIG_LIBS' line the entry
-lstdc++
- If you want r.terraflow, patch the source code for a workaround of a gcc bug on AIX:
r.terraflow_AIX_gcc_fix.diff
Index: raster/r.terraflow/stats.h
--- raster/r.terraflow/stats.h (revision 56936)
+++ raster/r.terraflow/stats.h (working copy)
@@ -22,6 +22,16 @@
#include <sys/types.h>
+/* http://gcc.gnu.org/ml/gcc-patches/2012-09/msg01957.html */
+#if defined(_AIX) && defined(_LARGE_FILES)
+#include <fcntl.h>
+#undef open
+/* Alias the symbols using asm */
+extern "C" {
+extern int open(const char *, int, ...) __asm__("open64");
+#endif
#include <fstream>
#include <iostream>
using namespace std;
AIX 5.x compilation hints
- conf_wget_AIX.sh:
sh configure --prefix=/afs/cluster/grid/user/private/bin/ --disable-nls
- conf_proj_AIX.sh:
sh configure --prefix=/afs/cluster/grid/user/private/bin --without-mutex
- conf_gdal_AIX.sh:
export LIBICONV=/opt/freeware export CC="gcc" export CXX="g++" PREFIX=/afs/cluster/grid/user/private/bin sh configure \ --prefix=$PREFIX \ --with-libz=internal \ --with-threads=no \ --with-geotiff=internal --with-libtiff=internal
- conf_grass6_AIX.sh
#!/bin/sh # optimization # http://en.gentoo-wiki.com/wiki/Safe_Cflags/Intel MYCFLAGS="-O2 $XEON" MYCXXFLAGS="-O2" # debug #MYCFLAGS="-g" #MYCXXFLAGS="-g" ######## MYBIN=$HOME/private/bin MYNAD2BIN=$MYBIN/bin/nad2bin # 64bit: CFLAGS="$MYCFLAGS" CXXFLAGS="$MYCXXFLAGS" NAD2BIN=$MYNAD2BIN ./configure \ --prefix=$MYBIN \ --with-cxx \ --enable-largefile \ --with-gdal=$MYBIN/bin/gdal-config \ --with-includes=$MYBIN/include \ --with-proj \ --with-proj-includes=$MYBIN/include \ --with-proj-libs=$MYBIN/lib \ --with-proj-share=$MYBIN/share/proj \ --with-png=yes \ --with-tiff=yes \ --with-tcltk=yes \ --with-sqlite=yes \ --with-opengl=yes \ --with-x=yes \ --with-nls=no \ --with-freetype=no \ --with-jpeg=no \ --with-postgres=no \ --with-mysql=no \ --with-ffmpeg=no \ --with-odbc=no \ --with-fftw=no \ --with-blas=no \ --with-lapack=no \ --with-motif=no \ --with-glw=no \ --with-readline=no \ --with-opendwg=no \ --with-python=no
- conf_grass7_AIX.sh:
export LIBICONV=/opt/freeware # comment next two lines for using the IBM xlc compiler: export CC="gcc" export CXX="g++" PREFIX=$HOME/private/bin CFLAGS='-ansi -D_ALL_SOURCE=1 -D_POSIX_SOURCE=1 -D_POSIX_C_SOURCE=200809L -Dinline=' ./configure \ --prefix=$PREFIX \ --disable-shared \ --enable-largefile \ --with-cxx \ --with-proj-includes=$PREFIX/include/ \ --with-proj-libs=$PREFIX/lib/ \ --with-proj-share=$PREFIX/share/proj/ \ --with-sqlite \ --with-sqlite-includes=$PREFIX/include/ \ --with-sqlite-libs=$PREFIX/lib/ \ --with-tiff=no \ --with-png=no \ --with-fftw=no \ --with-cairo=no \ --with-freetype=no
