Tips and Tricks
From GRASS-Wiki
Tips and Tricks
Using QGIS as a frontend to GRASS
  • QGIS started as a simple viewer for geodata. And that's really what it still is: a simple-to-use geodata viewer with some editing capabilities. That's what it was designed to be and that's what it can do really well. QGIS does not have built-in capabilities for geodata processing and analysis.
However, a while back, Radim Blazek, who was then a core developer of the GRASS 6 system, decided to write a plugin for QGIS that would make it possible to access GRASS functionality from within the QGIS GUI.
And that's what you get today, when you download a binary version of QGIS for your platform: QGIS + GRASS 6 plus a plugin that makes using GRASS from QGIS simple and fun.
QGIS can run as a frontend to GRASS. There is support for displaying maps, editing maps, and execution of simple GIS functions. The GDAL/OGR library is a requirement for that (but for GRASS anyway):
Here is a nice tutorial for editing vectors using QGIS as a frontend to GRASS: Editing_GRASS_vectors_with_QGIS (where did it go? unported from old wiki site? )
To use GDAL and GRASS together, the GDAL-GRASS plugin must be installed:
Test that the GDAL-GRASS plugin is available with this command:
  gdalinfo --formats
Look for a line like "GRASS (ro): GRASS Database Rasters (5.7+)"
Enable the QGIS GRASS plugin from QGIS:
  GUI: Plugins / Plugin Manager / Check the GRASS checkbox
The GRASS toolbar should now be visible. While not a firm requirement, it is easier to start QGIS from within a GRASS session.
Importing SRTM30plus data
See Global datasets page
GMT (The Generic Mapping Tools)
GMT (Generic Mapping Tools) is a Free software package for creating publication quality cartography.
GMT homepage: http://gmt.soest.hawaii.edu
Interfacing R-Statistics with GRASS
GRASS may be combined with R-Statistics to create a very powerful geostatistical analysis platform.
R-Statistics homepage http://www.r-project.org
Using GRASS with an on-line Web-GIS
see:
(please expand)
Starting and running GRASS from a script
See GRASS and Shell.
Running GRASS remotely on OS X
Tiger (OS 10.4) changed the default configuration of SSH from previous versions of OS X. You can no longer start an ssh session with the -X flag and display the Tcl/Tk components of the GRASS GUI remotely. If you are running grass on OS X (10.4) between hosts on a network (i.e. running it on one machine but displaying it on another), you will need to use the "trusted forwarding" mode of SSH in order for the Tcl/Tk generated graphics, such as d.m or gis.m in order for the GUI graphics to make it through your connection. This can be done using the -Y flag when you start the ssh session:
ssh -Y remotehost
or add this to ~/.ssh/config:
Host hostname
  ForwardX11 yes
  ForwardX11Trusted yes
Using the -X flag, or simply turning on X11Forwarding in the SSH configuration files, is not enough: the symptoms in this case are that a d.mon window will function fine, but none of the Tcl/Tk dialogues will work, failing with an error message complaining either about Wish not behaving as expected, or a "Bad Atom".
Quick tips
Checking categories pertaining to more than one feature
v.build op=cdump map=mymap | gawk -F"|" '{print $1}' | uniq -dc
returns, e.g.
5 35347
(5 features with cat 35347)
Applying v.edit tools on a whole map
v.edit allows many powerful geometrical manipulations. Operations are performed on certain features you must point out with arguments like ids=, cats=, coords=, and so on. When you need to run a tool on the whole map (e.g. every boundary), then it can be annoying to describe them (e.g. provide a cats list). A common way is to use the -r (reverse selection) flag in combination with pointing at feature-ids equal to zero (i.e. empty selection) :
v.edit map=mymap type=boundary tool=merge ids=0 -r
Compensate the lack of line ends symbology in ps.map
ps.map does not allow to specify line-end (from- and to-nodes) symbols oriented in the same direction as the last (resp. first) segment. Typically you want to add arrowheads to a line vector. Here we suggest a one-line gas (grep/awk/sed) solution. The idea is to output a bunch of selected lines ("where" argument), extract concerned couples of vertices, calculate a position and an angle for each tip, then import this set of data in a point vector. This point vector can latter be invoked in a ps.map command file.
The next example illustrates the process for line vector mylines. We want to be able to draw an arrow head at the to-node lines for which attribute code equals 3 or 5 :
for i in `v.out.ascii input=mylines format=standard where="code=3 or code=5" \
  | grep -n 'L  ' | sed s/\:/' '/ | sed s/'  '/' '/ | awk '{print $1+$3-1}'`; do
      | sed -n ${i},$((i+2))p | \
      awk \
        'NR == 2 {x=$1;y=$2} NR == 1 {xi=$1;yi=$2} \
         NR == 3 {cat=$2} END {pi=3.14159;OFS="|"; \
         print cat,x,y,atan2(yi-y,xi-x)/pi*180}';
done \
  | v.in.ascii -n out=myarrowheads x=2 y=3 cat=1 \
       columns='cat int, x double precision, y double precision, angle double precision'
Warning: intended to be a set of piped commands, it does not handle temporary maps/files. Obvioulsly it is not an optimized solution in terms of calculations (v.out.ascii is run within the loop as many times as the number of processed lines). But it is reasonably fast and leaves no traces when completed.
It results in a point vector named myarrowheads. Attribute field angle contains the rotation angle value fitting with to-node last segment direction.
ps.map command allowing to hardcopy arrows would look like this :
vlines mylines
	width 0.6
	color black
	end
vpoints myarrowheads
	color black
	symbol extra/n_arrow1
	rotatecolumn angle+90
	size 2
end
