Country Data Processing
This tutorial describes how to
- find free data of country on Internet
 - create new GRASS location
 - import found data into GRASS
 - create new vector layers from existing data
 - create labels
 - display map of a country
GRASS Installation
Required elements
- GRASS GIS 6.2.2 system installed
 - download SPEARFISH data http://grass.itc.it/sampledata/spearfish_grass60data-0.3.tar.gz
Create directory structure required for this tutorial
- dataset directory
$ mkdir ~/grass
- input data directory
$ mkdir ~/grass/indata
Create GRASS location using SPEARFISH data to be able create new locations
$ cd ~/grass $ tar zxf spearfish_grass60data-0.3.tar.gz
Start GRASS
$ grass -text spearfish60/PERMANENT
Obtaining Data
We assume that one wants to create UK map. Following steps can be easily applied to other countries' data.
Country related GIS data can be obtained from Digital Chart of the World.
First create country related input directory
$ mkdir ~/grass/indata/uk
Let's download UK data
- go to Digital Chart of the World
 - click Europe link
 - choose United Kingdom in select box on the right and click Continue
 - page _Digital Chart of the World Layer Interface for United Kingdom_ will be displayed
 - click Download Data button
 - another page will be shown, mark checkboxes
- Populated Places (Polygon)
 - Roads (Line)
 - Rail Roads (Line)
 - click Continue
 - on new page click Compute Data
 - on new page you will be able to obtain set of data (<NUMBER> is part of filename with data exported by DCW)
<NUMBER>.tar.Z
- do not hesistate to download data into ~/grass/indata/uk directory
Downloading Names of Cities
NGA GEOnet Names Server provides free GIS data containing positions of cities and their names.
Data can be downloaded from FTP server
ftp://ftp.nga.mil/pub/gns_data/
Direct link to UK GNS data
ftp://ftp.nga.mil/pub/gns_data/uk.zip
Download UK data into ~/grass/indata/uk directory.
Importing Data
Importing data into GRASS is two fold step
- create new location with one piece of data
 - import remaining data
Creating New Location
One can create new location using another location. We will use SPEARFISH location to create UK location.
Start GRASS
$ cd ~/grass $ grass62 -text spearfish60/PERMANENT (you need grass 6.2.x for this to work)
Enter UK input data directory and unpack downloaded data from DCW
$ cd indata/uk $ tar zxf <NUMBER>.tar.Z
You will have several files
- ponet.e00
 - country borders
 - pppoly.e00
 - populated places
 - rdline.e00
 - road network
 - rrline.e00
 - rail road network
We will create UK GRASS location using country borders. In SPEARFISH GRASS session use following commands to create location uk and layer borders
$ cd ~/grass $ v.in.ogr dsn=indata/uk/ponet.e00 layer=ARC output=borders location=uk
New location is created. Exit SPEARFISH GRASS session and start GRASS UK session
$ cd ~/grass $ grass62 -text uk/PERMANENT
You can display UK borders
$ g.region vect=borders # set region to display $ d.mon x0 # create GRASS monitor $ d.vect map=borders # display borders
Importing Rest of the Data
Having GRASS UK location we can import rest of the data (population places, road and rail networks)
$ cd ~/grass $ grass -text uk/PERMANENT $ v.in.ogr dsn=indata/uk/pppoly.e00 layer=ARC output=pcities $ v.in.ogr dsn=indata/uk/rdline.e00 layer=ARC output=roads $ v.in.ogr dsn=indata/uk/rrline.e00 layer=ARC output=rails
Display data
$ d.mon x0 $ g.region vect=borders $ d.vect map=borders color=black width=1.2 $ d.vect map=roads color=grey $ d.vect map=pcities color=brown
$ GRASS_WIDTH=1024 GRASS_HEIGHT=1024 GRASS_PNGFILE=uk.png d.mon start=PNG $ d.mon select=PNG $ d.vect map=borders color=black width=1.2 $ d.vect map=roads color=grey $ d.vect map=pcities color=brown $ d.mon stop=PNG
Import Data from GNS
Downloaded GNS data can be imported into GRASS using v.in.gns script.
Uncompress GNS data
$ cd ~/grass/indata/uk $ unzip uk.zip
Start GRASS UK session
Import data
$ v.in.gns file=indata/uk/uk.txt vect=cities
Processing Data
GNS data contains information about large amount of cities. Usually it is uncovinient to see all this data on a map. GRASS allows us to create new vector layers of cities.
Example below will show how to create new vector layer from GNS data for major country cities.
Start GRASS session
Extract data from cities vector layer to mcities vector layer
$ v.extract --o output=mcities input=cities where="(DSG='PPLA' or DSG='PPLC') and NT='N'"
Above selects those names of cities, which
- name type is 'N'
 - Feature Designation Code (DSG) is PPLA or PPLC
Create labels using FULLNAME column
$ v.label labels=mcities map=mcities column=FULLNAME size=0.1
Display map
$ d.mon x0 $ d.vect map=borders color=black width=1.2 $ d.vect map=mcities icon=basic/circle color=black fcolor=red size=4 $ d.labels labels=mcities
Other columns can be used to filter data or create labels. GNS columns are described at GNS Help page.
