PSC Meeting 2025-08-08
Participants
- Anna Petrasova
- Helmut Kudrnovsky
- Huidae Cho
- Linda Karlovska
- Nicklas Larsson
- Paulo van Breugel
- Vaclav Petras
- Veronica Andreo
Agenda
The topics proposed are:
- GRASS presence on different events
- Release 8.5
- New docs status
- Website rebranding status
- Mailing list removal? Question from Vicky in chat
- Decide on the Workspace topic and whether the solution suggested here can be implemented. This would help to finalize and merge this PR.
- Discussion on the workflow proposal. Perhaps we need a File Browser pane?
Minutes
- FOSS4G EU: Alen presented the state of GRASS talk.
- FOSS4G NL: Paulo gave a presenation about GRASS in education and research
- FOSS4G NA (Nov 3-5)
- Workshop: GRASS Addon Development with Python, Corey & Caitlin.
- Talk: GRASS Meets Longest Flow Paths, Shortest Compute Times, Huidae.
- Talk: State of GRASS, Corey.
- FOSS4G 2025 NZ:
- Alen and Luca will attend and present the state of GRASS talk (Corey as co-author as he wrote the original abstract).
- FOSS4G.be: Moritz will present a state of GRASS talk
- GRASS 8.5 Release postponed to fall
- Waiting for JSON stuff from GSoC, which needs to be reviewed before release.
- Fix r.mapcalc issues regarding parallelization.
- Mac binaries: There's an issue with code signing. Needs to be solved before the release.
- Release scripts are in addons, and they run in a Docker image. Still several steps need to be manual and they are different depending on the type of release, i.e., major, minor, micro or RC.
- Jupyter notebook integration into GUI. Some things need to be defined/solved first:
- Where to start the Jupyter server?
- Where to store the notebooks: current working directory, let users choose, outside projects, within mapsets, provide a good default?
- What happens when users do not have the dependencies installed?
- It should work in Windows (both OSGeo4W and standalone installer).
- FHS should be ready for 8.6
- New docs:
- They are up and running, but there's still something missing on the automatic upload part (currently a personal GH token of MN is used which expires every 3 months).
- There’s the question of whether we need to have docs updated all the time or only when we release. In that sense, this is not a blocker for the release, but a nice-to-have.
- For this release, we do not remove the HTML files, which are mostly used locally in the GUI or when called with g.manual from the terminal.
- Addon docs with new format: they work online.
- GSoC:
- The student and mentors are working hard on adding JSON output to C tools.
- They are obsoleting the -g flag and moving to the format option.
- More clean-up should be done before GRASS 9 + Python tools.
- CMake:
- We need 3 steps: FHS (PR WIP), GUI (Nicklas has a follow-up PR, but will need help with this), extensions (nothing done so far).
- MSVC binaries are built fine, but they don’t work out of the box because of missing environment variables; Can make them work by manually setting environment variables though; g.gui fails with Python exceptions
- Vicky's questions in the GRASS chat:
- We need to understand what they want to remove, and why; grass-user and grass-dev archives must not be removed, and neither must other list archives.
- Anna sends an email to Vicky.
- Workspace discussion:
- We agreed on having them within mapsets, but being asked if we want to save them or not - the opposite view is to save them automatically with a timer or so
- Anna proposed to remove the lock to delete maps in different mapsets from the GUI - check if this is independent from the owners of mapsets.
